'Contact Inverted' switch type
hamster
Post by hamster »
Can you add a "Contact Inverted" switch type to allow for 'normally open' contact switches?
For example, a leak sensor is normally open as the circuit is not connected by default. When there is water, the circuit closes and this is when the switch should be on/open/etc.
Currently, my leak sensor is showing "Open" when there is no water. If there is already a way to accomplish this without manually editing the sql database, please let me know.
hamster
Re: 'Contact Inverted' switch type
Post by hamster »
Just bumping since this didn't make it to latest Stable. Hopefully devs will see eventually :)
