Zigate / OSRAM Lightify SMART+ Switch Mini
Posted: Monday 12 August 2019 11:18
by pocock
I've got one of the OSRAM Lightify (now SMART+) Switch Mini switches
The manual says you can press the Up and Down buttons for 10 seconds to join it to a bulb using ZLL Touchlink. I tried this with an OSRAM bulb that is already connected to the Zigate and the touchlink didn't work, it seems the switch can't control the bulb any more.
Another thread mentions you can press the Up and Middle button together to make it join a network. I put the Zigate in permit join mode and tried pressing Up and Middle buttons together and didn't see anything in the Domoticz Zigate logs so I don't think the switch is trying to join.
Does anybody know any more about making this switch work in either way?
Re: Zigate / OSRAM Lightify SMART+ Switch Mini
Posted: Monday 12 August 2019 17:17
by Thorgal789
I don't have this remote, but the touchlink feature need the remote be close to the bulb (less than 50cm), and need sometime powercycle.
Posted: Tuesday 13 August 2019 10:14
by pipiche
I don't have this remote nor the Lighify, but is that not the same as the Ikea Bulb with the Ikea Remote 5 buttons ?
So for me,
(1) does it work in standalone ? Lightify and Mini switch ? ;
(2) If that work, then we need to understand why the Mini Switch do not pair with the Zigate ? Dont' you have a Pairing and a Reset procedure ?
Posted: Monday 28 October 2019 20:41
by pocock
Another problem with this switch: even though it won't control the bulb, when I perform the pairing procedure (holding down buttons on the switch) it joins with all the smart sockets and relays in the network. If I press the on or off button, everything in the house switches on or off. I went back to the shop and the man in the shop told me he is having exactly the same problem with Osram Switch Mini (he didn't tell me if he is using Zigate/Domoticz or some other hub). He immediately agreed to refund because he knows the problem.
Posted: Monday 28 October 2019 21:10
by pipiche
pocock wrote: Monday 28 October 2019 20:41
Could be as the INNR RC110 in SCENES mode, where the remote is broadcasting the ON/Off/LvlControl and Scene to all devices responding to cluster On/Off or level control.
Posted: Monday 12 October 2020 22:56
by razmoket89
Hi. I'm getting the same problems, eventhough I'm not on domoticz but jeedom. I successfully paired it to my zigate, but when pressing On or off,it switches all my aqara relays linked to the zigate... Any workaround on your side ?
Posted: Tuesday 23 March 2021 12:58
by gert3d
I have been able to pair the (now) Ledvance Switch mini (smart+ indoor) with a cc2531 gateway, zigbee2mqtt and Domoticz.
I do see the device in the list for the switch state, voltage, signal and percentage, but using the device does not change the switch state to any of the many choices that can be seen under the switch tab for the device.
What could be the problem here, and how can it be solved. Do I need a seperate plugin for this device?
Posted: Tuesday 23 March 2021 14:16
by pipiche
Sorry , but it will be hard for me to help you with a CC2531
With the ZiGate, you might want to try some special settings
enable doUnbindBind
then do a pairing from scratch. But if the device is broadcasting to all device capable of Off/On (cluster 0x0006 ), nothing much can be done
