Problem with Zwave Devices Roller Shutters
Posted: Sunday 11 August 2019 14:37
I hava a Problem again with my Domoticz.
Some Time ago I pressed the wrong butten on Zwave Device,
and all my registered Devices where gone.
So bad, I had to register everthing new, new learn every Device.
Ok, this done now, I take the same Names, so my dzvents Scripts should working fine.
One Day long, everything was ok.
Then, I did not know what happend, my Shutters begin to shut down complete,
some Minutes later, they going up complete open.
Some Minutes, sometimes more than 30 Minutes, then they shut down again, and going up again some minutes later.
All 3 at the same Time.
When I look at he logs, I see only something like this:
2019-08-11 09:50:00.274 OpenZWave: Domoticz has send a Switch command! NodeID: 10 (0x0a)
or
2019-08-11 09:50:00.293 OpenZWave: Domoticz has send a Switch command!, Level: 0, NodeID: 12 (0x0c)
But I never pressed any buton and I cant find any Script (dzvents, Blockly or anything) that caused this action.
Please, Help, I have no Ideas, and it really stresses me.
BR
Clemens
2019-08-11 09:49:51.544 (RFLink01) Temp + Humidity (Cresta)
2019-08-11 09:49:51.551 (RFXCOM) Temp + Humidity (Terrasse)
2019-08-11 09:49:51.718 (DomoticzSlave01) General/Percentage (Unknown)
2019-08-11 09:49:51.848 (ZWave) Usage (Unknown)
2019-08-11 09:49:51.852 (ZWave) General/kWh (Verbrauch Rolladen Theo)
2019-08-11 09:49:51.890 (ZWave) Usage (Unknown)
2019-08-11 09:49:51.895 (ZWave) General/kWh (Verbrauch Rolladen Schlafzimmer)
2019-08-11 09:49:51.903 (ZWave) Usage (Unknown)
2019-08-11 09:49:51.909 (ZWave) General/kWh (Verbrauch Rolladen Nassia)
2019-08-11 09:49:53.911 (ZWave) Light/Switch (Unknown)
2019-08-11 09:49:53.790 Status: OpenZWave: Received timeout notification from HomeID: 4113634733, NodeID: 13 (0x0d)
2019-08-11 09:49:54.950 (RFLink01) Temp + Humidity (Cresta)
2019-08-11 09:49:54.962 (RFXCOM) Temp + Humidity (Vorgarten)
2019-08-11 09:49:55.021 (ZWave) Usage (Unknown)
2019-08-11 09:49:55.024 (ZWave) General/kWh (kWh Meter)
2019-08-11 09:49:55.065 (ZWave) Usage (Unknown)
2019-08-11 09:49:55.068 (ZWave) General/kWh (kWh Meter)
2019-08-11 09:50:00.280 (ZWave) Usage (Verbrauch Heizung Bad OG)
2019-08-11 09:50:00.282 (ZWave) General/kWh (kWh Meter)
2019-08-11 09:50:00.292 (ZWave) Light/Switch (Heizung Bad OG)
2019-08-11 09:50:00.294 (ZWave) Usage (Unknown)
2019-08-11 09:50:00.299 (ZWave) General/kWh (Verbrauch Rolladen Schlafzimmer)
2019-08-11 09:50:00.305 (ZWave) Light/Switch (Rolladen Schlafzimmer)
2019-08-11 09:50:00.571 (ZWave) Light/Switch (Rolladen Schlafzimmer)or
BR
Clemens
