New industrial Symcod Wireless 900 mhz Temperature sensor (2 km)
Posted: Thursday 08 August 2019 18:51
If it may interest someone, I made compatible via MQTT our industrial Symcod wireless temperature sensor Neuron-Air 900 mhz
Product manual: http://www.symcod.com/openfile.aspx?fil ... man_en.pdf
Retail price:
Neuron-Air ETHERNET MQTT GATEWAY (Master Antenna): 470$ USD
Neuron-Air Temperature sensor: 150$ USD
*** It is possible to purchase the Neuron-Air GATEWAY USB (FTDI Virtual Serial Port) for 270$ but the communication via serial Port is not build with Domoticz.
Product webpage: http://www.symcod.com/data-collection/p ... n-air.aspx
Our Domoticz server with Neuron-Air temperature sensor live: http://www.symcod.com/neuron/
- Each Neuron-Air Gateway (master antenna) can communicate with up to 50 Neuron-Air temperature sensors.
- A maximum of 9 masters can be present on the same site to reach 450 sensors.
- The maximum distance between a temperature sensor and the gateway is +- 2 km linear feet without obstacle.
- The Neuron-Air temperature sensor can be placed directly in a freezer or in a refrigerator, the long-range radio wave can pass through most metal or stainless-steel walls.
- The temperature sensors are powered by two AA batteries that give it autonomy 10 years (sending the temperature every 10 minutes).
- Sensor IP65 waterproof ABS case.
- Temperature sensor can resist to harsh industrial environments.
- Sensor operating temperature is -40 to 60 degrees Celsius.
- Accuracy of + - .5 degrees Celsius (no calibration required).
- Gateway and Sensors addresses and the various parameters are chosen via rotary switches directly on the Neuron-Air.
- No additional hardware, software or subscription is required.
Retail price:
