Sonoff BasicR3/mini/RFR3 Domoticz integration development
Posted: Tuesday 06 August 2019 13:49
by danielzhan
Hi All,
My name is Daniel from Sonoff Marketing, Sonoff has released new products Basic R3, mini and RFR3 which support DIY MODE to integrate into third party open source platform, we have published the API protocol and a demo tool for users to develop LAN control for the devices.
Who should I contact to talk about Domoticz integration, anybody help?
Or is there any volunteer would like to develop the binding for Domoticz, I can provide the free samples.
API protocol you can access from below link
https://github.com/itead/Sonoff_Devices_DIY_Tools
Thanks very much
Daniel
Re: Sonoff BasicR3/mini/RFR3 Domoticz integration development
Posted: Tuesday 06 August 2019 19:02
by MikeF
Hi Daniel, I have several Sonoff Basics and S20s currently controlling lights (hardwired and sockets) linked to Domoticz, and I am particularly interested in the Sonoff Mini as a wife-acceptable solution if it can sit behind - and be controlled by - an ordinary rocker-type light switch.
You can contact me on mjf <dot> sw <at> btinternet <dot> com (please edit).
Mike
Posted: Thursday 08 August 2019 10:26
by danielzhan
Hi MikeF,
I have sent you the mail, look forward to hearing from you.
Daniel
Posted: Thursday 08 August 2019 21:29
by lwolf
I am wondering how this ZeroConf idea popped up at Sonoff programming division?
MQTT is an ISO standard and not a coincidence that is used by the Shelly devices and by a lot of DIY solutions, it is far more better than anything i've seen from other manufacturers...
By the way Python zeroconf is using threading which, as i know, is not really Domoticz-Python-Plugin friendly. (correct me devs if i am wrong)
FYI I have created a SonoffDiy To MQTT external translator for Domoticz.
viewtopic.php?f=51&t=27589&p=221237&hil ... r3#p221237
Posted: Wednesday 18 September 2019 22:42
by stecom
hi Daniel
what are the spec for the integration?
i have installed few mini using python DIY tool.
- after fixing few issues, my mini Diy is managed by domoticz.
cheers
Posted: Thursday 19 September 2019 14:27
by xeonpj
stecom wrote: Wednesday 18 September 2019 22:42
hi Daniel
cheers
I am very interested in this too, somewhere to find how to act from 0 to connect a mini to domoticz?
Posted: Sunday 03 November 2019 23:40
by jasujonas
Posted: Saturday 18 January 2020 7:05
by acaonweb
hi Daniel
cheers
Can you tell me how did you integrate mini into domoticz? Ive flashed it with Tasmota but I can’t find domoticz configuration
Thanx in advance.
Posted: Saturday 18 January 2020 10:09
by xeonpj
Actualiza tasmota desde el dispositivo.
Posted: Saturday 18 January 2020 10:16
by sammyke007
acaonweb wrote: Saturday 18 January 2020 7:05
hi Daniel
cheers
Thanx in advance.
In the Tasmota configuration there is a section "configure Domoticz". There you can fill in the correct IDX (device from Domoticz) to toggle. Tasmota will reboot and voila!
(Choose IDX and not Key IDX).
By default the onboard button (GPIO0) will toggle the relay and so the IDX you configured. You can attach an external switch to the Sonoff Basic R3 on the DIY pin (GPIO16) and GND, but that's a little bit more advanced...
Posted: Saturday 18 January 2020 13:53
by acaonweb
sammyke007 wrote: Saturday 18 January 2020 10:16
hi Daniel
cheers
Thanx in advance.
Unfortunately not in the last firmware-wifiman.bin where this configuration is missing.
Which bin you flashed? Which Tasmota version?
Posted: Saturday 18 January 2020 14:02
by xeonpj
Actualiza desde el mismo firmware de tasmota, y la versión que instala ya trae domoticz
Posted: Saturday 18 January 2020 14:25
by acaonweb
xeonpj wrote: Saturday 18 January 2020 14:02
solved!!!!
Thanx to everyone
Posted: Wednesday 11 March 2020 15:58
by JanGil
Dear acaonweb,
can you please explain how you have solved this problem?
Thanks in advance.
Posted: Wednesday 11 March 2020 16:46
by Ulthar
Put device in pairing mode, 2x press reset for at least 5sec, the led diode will start blinking fast
Connect to the device's wifi
Open page
http://10.10.7.1/device
You will get something like this
deviceid":"10007055xx","apikey":"xxabcdef-xxxx-4db7-abcd-xxabcdefxx","accept":"post","chipid":"00DDxxxx
deviceid/apikey is what you need (In DIY MODE you don't need apikey)
then download pysonofflanr3
https://pypi.org/project/pysonofflanr3/
In the domoticz virtual device on/off
script://pysonofflanr3.exe --device_id deviceid --api_key apikey on/off
There is no two-way communication but should be fine for enabling/disabling basic or sonoff g1 (gate controller)
PS.
Check via cmd/shell first
Posted: Wednesday 11 March 2020 17:24
by JanGil
Thanks for your response.
I already flashed the Tasmota firmware, is your solution compatible with the Tasmota firmware or only with the original firmware?
Posted: Wednesday 11 March 2020 18:02
by JanGil
I solved it by compiling the tasmota firmware from the source code where I enabled the "USE_DOMOTICZ".
This should normally work with the standard Tasmota firmware (
https://github.com/arendst/Tasmota/blob ... /BUILDS.md ), but for me it didn't.
Posted: Wednesday 11 March 2020 18:42
by Ulthar
My solution works without any flashing, it's not perfect, but well..
For Tasmosa, I guess you can use http/json in the scipt:// section of the virtual switch.
Maybe something like this:
deviceip/json.htm?status=on
Posted: Wednesday 29 April 2020 15:12
by wired
Hey Daniel
I think you have published on various sites about Sonoff integrations.
I am keen to link my Synology NAS Surveillance Station cameras to a Sonoff switch so that my floodlights come on when movement is detected.
Have you managed any such integration?
