FAN icon with slider in Floorplan (like dimmer)
Posted: Tuesday 30 July 2019 17:27
by gryzli133
Hi There,
I have fans that have speed control. Now I use only standard dimmer icons, while the FAN icon are not working well. The fan displays the %, but there is no possibility to change speed from Floorplan. I used to control my house only from floorplans, because I have hundred of switches in my house (every light, blind etc is controlled from Domoticz). Using the floorplan I do not need to scroll all the time. I used to control the fans from standard dimmer icon, but in some rooms there is hard to know which is light and which is fan or blind. I have attached screenshots using dimmer icon and fan icon. As you can see while using FAN icon there is no slider for percentage control. Can it be somehow adjusted?
Thanks in advance!
Re: FAN icon with slider in Floorplan (like dimmer)
Posted: Tuesday 30 July 2019 18:41
by felix63
If you use a dimmer switch to control your fan and that works as you want, couldn't you just change the icon?
Schermafbeelding 2019-07-30 om 18.40.31.png (150.12 KiB) Viewed 1833 times
Posted: Tuesday 30 July 2019 18:46
by felix63
Ahh.. I tried it. It doesn't work. Changing the icon on a dimmer switch changes the behaviour on a floor plan. That is weird. Isn't this just a bug?
Posted: Thursday 01 August 2019 11:57
by gryzli133
I open also an issue on Github: https://github.com/domoticz/domoticz/issues/3555
