Can openzwave be linked statically on windows?
Posted: Sunday 28 July 2019 8:05
Is it possible to create one visual studio solution with 2 projects in it, one for openzwave library and the other for domoticz. And the library statically linked to domoticz (i.e. not like a dll)?
If so, can anyone give some hints or even a walkthrough? I'm having trouble getting a proper setup in which i can debug the both together.
The reason why i want to have openzwave as a library and not a dll is because of the warnings vs2019 gives on strings in the openzwave class declaration. Googleing these warnings i found several items saying the warning can be safely ignored only if you are sure the exe and dll are always compiled with the exact same debug flag setting. Having different setting can result (as per the items) in errors like memory corruption and invalid string operations. Both are reported more than once in the forum. Ultimately i think it would be best to change the declaration for openzwave's exposed classes to have their string members correctly declared. But a simpler (temporary?) solution is to have the openzwave lib linked statically with the domoticz exe so that both are always compiled with the same setting.
1>OpenZWave.cpp
1>E:\Github\domoticz\hardware\openzwave\Msg.h(228,21): warning C4251: 'OpenZWave::Internal::Msg::m_logText': class 'std::basic_string<char,std::char_traits<char>,std::allocator<char>>' needs to have dll-interface to be used by clients of class 'OpenZWave::Internal::Msg'
1>C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\VC\Tools\MSVC\14.21.27702\include\xstring(4231): message : see declaration of 'std::basic_string<char,std::char_traits<char>,std::allocator<char>>'
1>E:\Github\domoticz\hardware\openzwave\Driver.h(328,27): warning C4251: 'OpenZWave::Driver::m_controllerPath': class 'std::basic_string<char,std::char_traits<char>,std::allocator<char>>' needs to have dll-interface to be used by clients of class 'OpenZWave::Driver'
1>E:\Github\domoticz\hardware\openzwave\Driver.h(332,27): warning C4251: 'OpenZWave::Driver::m_libraryVersion': class 'std::basic_string<char,std::char_traits<char>,std::allocator<char>>' needs to have dll-interface to be used by clients of class 'OpenZWave::Driver'
1>E:\Github\domoticz\hardware\openzwave\Driver.h(333,28): warning C4251: 'OpenZWave::Driver::m_libraryTypeName': class 'std::basic_string<char,std::char_traits<char>,std::allocator<char>>' needs to have dll-interface to be used by clients of class 'OpenZWave::Driver'
1>E:\Github\domoticz\hardware\openzwave\Notification.h(376,20): warning C4251: 'OpenZWave::Notification::m_comport': class 'std::basic_string<char,std::char_traits<char>,std::allocator<char>>' needs to have dll-interface to be used by clients of class 'OpenZWave::Notification'
1>E:\Github\domoticz\hardware\openzwave\Options.h(253,16): warning C4251: 'OpenZWave::Options::m_xml': class 'std::basic_string<char,std::char_traits<char>,std::allocator<char>>' needs to have dll-interface to be used by clients of class 'OpenZWave::Options'
1>E:\Github\domoticz\hardware\openzwave\Options.h(254,24): warning C4251: 'OpenZWave::Options::m_commandLine': class 'std::basic_string<char,std::char_traits<char>,std::allocator<char>>' needs to have dll-interface to be used by clients of class 'OpenZWave::Options'
1>E:\Github\domoticz\hardware\openzwave\Options.h(255,23): warning C4251: 'OpenZWave::Options::m_SystemPath': class 'std::basic_string<char,std::char_traits<char>,std::allocator<char>>' needs to have dll-interface to be used by clients of class 'OpenZWave::Options'
1>E:\Github\domoticz\hardware\openzwave\Options.h(256,22): warning C4251: 'OpenZWave::Options::m_LocalPath': class 'std::basic_string<char,std::char_traits<char>,std::allocator<char>>' needs to have dll-interface to be used by clients of class 'OpenZWave::Options'
