I have a defective Xiaomi temperature sensor. I can add the new one but I'd like to keep and continue the data history on the same Domoticz device.
How the best way to do that ? I don't mind if it requires doing sqlite database update while domoticz not running.
ps : The scripts are not the problem because I always use name to identify my devices in there.
How to replace a Xiaomi Sensor keeping the same device ? Topic is solved
Bigted
- Domoticz version: 2020.1
Re: How to replace a Xiaomi Sensor keeping the same device ?
Did you read the manual, page 20
Add the new device with a new name, you will have a new idx value
On the old device edit | replace, and select the new device
All the history will transfer
Remove the old device from setup | devices
Rename the new device with the old name
this is perfect !
I just made a google search without finding anything, I feel dumb
