Aeotec Z5 stick picky for frequencies nearby
Posted: Monday 22 July 2019 20:53
by Solderbro
Found out that the Z-Stick dislike other frequency emitters nearby, it crumble the reach down.
1. My dualband wifi router although it look far away from 868Mhz.
2. Plastic covered switching psu, like the pi one
30cm seems to be the minimal keep out zone to avoid extreme crumbling. So my question for today is
Have someone played with a better antenna for z-wave? To open the stick and solder something better to the pins
Solderbro
Re: Aeotec Z5 stick picky for frequencies nearby
Posted: Monday 29 July 2019 9:42
by lost
Solderbro wrote: Monday 22 July 2019 20:53
My own gen5 stick is in the 10-20cm range from my wifi+wired router, because the PI3 is powered by the router USB port (using a short cable to avoid "low voltage" issues in the PI logs). No issues on my side.
I think this would be easier to use a 1m USB extension cable to be able to separate the stick from the radios of your router if they are not correctly filtered & you experience troubles out of their expected radio range.
Posted: Wednesday 31 July 2019 19:49
by Solderbro
Found out some emc hotspot that the pi fires into it's environment. So today i build it into a Icybox metal case for shielding, first experience is that the device collection after database backup is faster
You seem to have a really good router, my has no capability to serve 2.5 amps for the pi. So i use a copper shielded power supply.
Solderbro
