Page 1 of 5
Aeotec Alarm 6 and Doorbell 6
Posted: Monday 22 July 2019 16:34
by pimseb
Hello
I'd like to buy an Aeotec Doorbell 6 (or alarm 6) but it seems not to work with domoticz yet.
Here is the official site of the device :
https://aeotec.com/z-wave-doorbell/
This french online shop has tested it :
https://www.domotique-store.fr/fr/domot ... &results=1
It seems impossible to include the device in domoticz.
How can we make it work ? Who shall we contact to add it in the supported devices Zwave list ?
Thank you
Re: Aeotec Alarm 6 and Doorbell 6
Posted: Friday 26 July 2019 11:15
by realmorre
I have bought the siren 6 and it's possible to include the siren, but there is no configuration file and I cannot set the siren on status " ON". I get a error message: "Error sending switch command, check device/hardware !".
So I hope the siren will be supported soon, because this is the only siren with the options I need.
Posted: Friday 26 July 2019 11:25
by realmorre
Strange thing that on another site they mention there is support for Domoticz...
https://www.robbshop.nl/sirene-z-wave-p ... b-aeonlabs
Posted: Wednesday 31 July 2019 14:01
by darkell
I am also about to buy Aeotec Doorbell 6 and am very much interested in domoticz support.
Posted: Wednesday 31 July 2019 16:17
by cogliostrio
Domoticz has had support for this since December 2018. Which version are you guys runnning?
Posted: Thursday 01 August 2019 16:56
by realmorre
Version: 4.10717
When including Domoticz sees the device as Aeotec Unknown.
Posted: Wednesday 07 August 2019 13:01
by raymond1972
I'm running version 4.10717
I just ordered a doorbell 6 and I hope to receive it tomorrow.
In my manufacturer_specific.xml there is already the correct product id.
<Product type="0003" id="00a2" name="ZW162 Doorbell 6" config="aeotec/zw162.xml"/>
According to
https://products.z-wavealliance.org/products/3292 .
So it should work out of the box.
Today I received my doorbell 6 and I was able to add it to domoticz out-of-the-box.
Please read this (
https://www.domoticz.com/forum/viewtopi ... 28&t=28969) for further information. Doorbell 6 needs open z-wave 1.6 support which is currently not available in domoticz.
Kind regards,
Raymond
Posted: Wednesday 07 August 2019 13:11
by raymond1972
realmorre wrote: Friday 26 July 2019 11:15
you could verify your domoticz/Config/manufacturer_specific.xml file
If necessary you could add a line under the correct manufacturer.
In the attachments you find mine and the corresponding zw162.xml file
After correcting the files you should remove de doorbell and then re- add it again.
Then it should work correctly.
Kind regards,
Raymond.
Posted: Thursday 08 August 2019 20:45
by Bart84
Hello Raymond,
thank you for sharing this information.
I have the same module but it's not reconized.
Im new at raspberry/domoticz.
Could you tell me how to see/ change the
domoticz/Config/manufacturer_specific.xml ?
Or is there an topic about this?
Thanks in advanced.
Bart
Posted: Saturday 10 August 2019 23:16
by realmorre
Doorbell is added now, but only a lot of parameters which are not corresponding with the manual. Standard volume level is way too high (distortion), but no option too decrease the volume level. Hope that the new openzwave version is coming to Domoticz.
Posted: Friday 16 August 2019 14:33
by raymond1972
Bart84 wrote: Thursday 08 August 2019 20:45
Hello Raymond,
Thanks in advanced.
Bart
Hi Bart,
I can certainly tell you more where you can find the files needed (feel free to pm me directly), but as mentioned before:
Please read this (
Posted: Friday 16 August 2019 18:02
by darkell
it is available in beta, I'm using domoticz 4.11200 with OpenZWave 1.6-881-ga2f8a143-dirty
but I am still unable to properly control the volume or engage the alarms through browse switches, other than playing tones through BASIC SET.
Triggering switches gives following errors
2019-08-11 16:32:11.194 Error: OpenZWave: Internal Node Device not found! (NodeID: 19, 0x13)
Adjusting volume in OpenZWave Control panel although available in menus does nothing.
bunch of errors
2019-08-16 17:52:15.637 Status: OpenZWave: Unhandled class: 0x79 (NO OPERATION), NodeID: 19 (0x13), Index: 1, Instance: 4
2019-08-16 17:52:15.738 Status: OpenZWave: Alarm received (Doorbell 2 Siren: Clear), NodeID: 19 (0x13)
2019-08-16 17:52:15.637 Error: OpenZWave: Value_Changed: Tried adding value, not succeeded!. Node: 19 (0x13), CommandClass: NO OPERATION, Label: Doorbell 2 Tones, Instance: 4, Index: 1
Posted: Friday 16 August 2019 21:11
by Pvhelden
Exact same problem here.
Logfile shows “Manufacturer_specific.xml out of Date”
Solution would be appreciated.
Posted: Saturday 17 August 2019 10:55
by Bart84
raymond1972 wrote: Friday 16 August 2019 14:33
Hi Bart,
Please read this (
Hello Raymond, thank you for your answer, i have done an update to the beta version 4.11207 and now the alarm seems to be reconized.
can you explain how to set the alarm or an doorbell? im using the system as alarm.
with for example
http://ipadress:8080/json.htm?type=comm ... tchcmd=Off i can switch on an light, but i can not switch on any alarm or doorbell sound like this.
thanks in advanced!
Best regards,
Bart
Posted: Wednesday 21 August 2019 17:45
by Bart84
I have send an e-mail to Aeotec, they only say that they did not test with Domoticz.
Is there anyone who has it running and can use the sounds?
Posted: Sunday 01 September 2019 19:08
by Hencor
I just registern for this forum just because I'd really like to get this Doorbell work!!
I just worked through the "Engineerung Specification" from Aoetec. Am I right that there are existing two different documents, where the newer one (rev 8) seems to be older... I found a rev 5 which is from the 2019-01-17 whereas the rev 8 is from the 2018-11-14?
So I figured out the volume is NOT configurable over the device config. So we really have to wait until the "volume change command class" is integraded into domoticz right?
Posted: Tuesday 03 September 2019 21:07
by Hencor
I just managed to configure the volume and the tone witch is trigged with the button.
Its a solution past domoticz. I used the windows software "Z-Wave PC Controller 5" to send the right commands to the doorbell. I just downloaded the software and plugged my Aeotec Z-Stick in. So I could communicate with each device in my Zwave network. With the help of the Aeotec Engineering Specifications (from the 2019-01-17) it's easily possible to detect the right command (classes) to configure each tone and volume for each trigger (Button 1-3, Tamperalarm, Zwave Alarm, etc).
Well, I just forgot to make some screenshots...
Posted: Wednesday 04 September 2019 15:42
by raymond1972
Hi Hencor,
Good to read/see your persistence on this issue.
Nevertheless things should work out-of-the-box in domoticz.
I hope the open z-wave 1.6 and corresponding sound classes for the aeotec doorbell/siren 6 will work in the future.
For now the only thing I can do is sit and wait...
By the way could you post or mail me the specifications?
Posted: Thursday 05 September 2019 14:14
by Gertjan
I would love to get this working, when is the update going to be released?
Posted: Saturday 07 September 2019 9:36
by Hencor
Hi raymond,
I just try to get all information / steps into a screenshot:
- Doorbell Config Change.png (164.86 KiB) Viewed 10046 times
The send button is hidden by the Select Command window.
You can see that the SoundSwitch creates 8 different devices. Each device configure one trigger action.
The volume can be changed from 0 to 100 dec and the sound from 0 to 30 dec.
