Qubino ZMNHDD1 / ZMNHADx not working
Posted: Tuesday 16 July 2019 23:21
I have 4 Qubino Flush Dimmer+ ZMNHDD1
1 of them seems to work properly:
when I press the push button, the light switches on and the next time off => OK
and each time the widget goes on and after off quickly => OK
and each time the event is triggered (with dzVents) => OK
when I click the widget, the light goes on and the next time off, the events are triggered => OK
2 of them seems not to work properly
when I press the push button, the light switch on and the next time off => OK
and each time the widget DON'T go on and after off => KO
and NO event is triggered (with dzVents) => KO
The last on was not tested with a push button because not easy to reach.
I've aligned the configuration of the 4 devices and checked with a "request current stored values from device"
Version: 4.11010
Build Hash: 287c46eb6
Compile Date: 2019-07-16 08:05:11
dzVents Version: 2.4.26
Z-Wave Plus Z-Stick Gen5 Version: 1.6-808-gbb0a4bf7-dirty
I also have a Qubino (Goap) ZMNHSDx Din Dimmer+ that works fine
Version: 4.11010
