dzVents for-loop doesn't trigger
Posted: Tuesday 16 July 2019 13:18
I'm trying to get this function to work; but it doesn't trigger due to some logic problem or other error. Someone who could help me out with this.
When I change the timer to every minute and turn on debug I only get the following information.
All LEDs are off.
The actual script
The previous checks are commented right now and I have adjusted my code to resemble the example from the wiki.
Status: dzVents: Info: Nintendo: ------ Start external script: Nintendo.lua:, trigger: every minute
Status: dzVents: Debug: Nintendo: Processing device-adapter for $blink_blauw: Switch device adapter
Status: dzVents: Debug: Nintendo: Processing device-adapter for $blink_geel: Switch device adapter
Status: dzVents: Debug: Nintendo: Processing device-adapter for $Vloer-LED-B: Switch device adapter
Status: dzVents: Debug: Nintendo: Processing device-adapter for $Vloer-LED-Y: Switch device adapter
Status: dzVents: Info: Nintendo: ------ Finished Nintendo.luaThe actual script
Nintendo
als de switch of wii langer dan 35 minuten aanstaat, dan de blauwe LED laten knipperen. Als dat apparaat uit is dan LED weer uitzetten.
active = true,
devices = { 'Wii', 'N_Switch' },
timer = { 'every 5 minutes' },
logging = {
level = domoticz.LOG_ERROR, -- change to LOG_ERROR when script executes OK
-- domoticz.LOG_DEBUG
marker = 'Nintendo',
-- dzVents 2.4 functie:
execute = function(domoticz,item)
local blauwblink = domoticz.devices('$blink_blauw')
local geelblink = domoticz.devices('$blink_geel')
local blauw = domoticz.devices('$Vloer-LED-B')
local geel = domoticz.devices('$Vloer-LED-Y')
-- local deviceToCheck = domoticz.devices().forEach(function(devicesToCheck)
local devicesToCheck = { 'Wii', 'N_Switch' }
local thresholdx = 35
local Time = require('Time')
-- setup
if ( item.isTimer ) then
for i, deviceToCheck in pairs(devicesToCheck) do
-- local minuten = domoticz.devices(deviceToCheck).lastUpdate.minutesAgo
local minuten = Time(deviceToCheck.lastUpdate)
-- Actual check!
-- if ( deviceToCheck.active and minuten.minutesAgo > thresholdx ) then
if ( blauw.active ) then
domoticz.log('De blauwe LED staat al aan!')
blauwblink.switchOn()
domoticz.log('De blauwe LED knippert...')
domoticz.notify("Domoticz", "De " .. domoticz.devices(deviceToCheck) .. "staat al meer dan 35 minuten aan", domoticz.PRIORITY_NORMAL,domoticz.SOUND_DEFAULT, "" , "telegram")
if ( item.isDevice and not item.active ) then
blauwblink.switchOff().checkFirst()
-- blauw.switchOff().checkFirst()
domoticz.log('De blauwe LED knippert niet meer!')
