The IOAF (Internet of Air Fresheners)!
Posted: Sunday 14 July 2019 13:53
Those Airwick things do their refresh-cycle based on a timer, so it spits out perfume when not needed (when not at home, in your face in the middle of the night, etc). Obviously Airwick wants you to buy their containers. So let's lobotomize their evil invention and control it through a Sonoff SV, with Domoticz as its master brain.
Our volunteer:
And its evil brain:
Hardware Components
Refreshingly, that seems to be all!
Software Components
Software Config
In the Tasmota console through the Sonoff SV webpage enter: and to prepare a 0.4 sec burst of power, instead of normal on/off operation. Subsequently the command in the console
or from MQTT/Node red: with will arrange a short power-on refreshment; assuming mqtt topic changed to
Prepare Node Red to convert a Domoticz MQTT message (assuming switch id in domoticz is 13
In Domoticz make a virtual switch with a ‘Push on Button’ to control the freshener by hand
And make Domoticz do some intelligent stuff in an event script based on presence.
Feel refreshed!
Our volunteer:
And its evil brain:
Hardware Components
- Lobotimised Airwick with only motor-leads hanging out
- Either an USB Powerbank without low-power shut-off (most powerbanks are not usable!)
or a fancy self-mode charge circuit, with an 3.7v battery of a powerbank and buck voltage converter circuit to 5V
or an adapter for the more faint of heart
- Sonoff SV (prepared for isolated mode by removing resistors; isolated mode works better than feed-through as the Airwick motor needs quite some power and the SV circuitry can not handle this)
Software Components
- Tasmotised Sonoff SV for its MQTT capability, among others
- Node Red to convert the MQTT command from domoticz towards the Sonoff SV
- Domoticz with all the intelligent stuff
- Mosquito as an MQTT broker
- Attach the Airwick to the Sonoff SV 5V relay output
- Attach 5V power to the Sonoff SV and the relay pass thru circuit
Software Config
Blinkcount 1Code: Select all
Blinktime 4Code: Select all
power 3 Code: Select all
cmnd/sonoffsv/powerCode: Select all
msg.payload=3Code: Select all
sonoffsvPrepare Node Red to convert a Domoticz MQTT message (assuming switch id in domoticz is 13
[{"id":"4e57340c.a15bbc","type":"mqtt out","z":"c3a3974.b558268","name":"","topic":"cmnd/sonoffsv/power","qos":"","retain":"","broker":"362f1eb8.2dcf02","x":894,"y":362,"wires":[]},{"id":"82b0d672.cf81f8","type":"inject","z":"c3a3974.b558268","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":300,"y":255,"wires":[["ba6e104b.89fef"]]},{"id":"ba6e104b.89fef","type":"function","z":"c3a3974.b558268","name":"power","func":"msg.payload = {};\nmsg.payload = 3;\nreturn msg;","outputs":1,"noerr":0,"x":627,"y":365,"wires":[["4e57340c.a15bbc"]]},{"id":"58f4701.3eb859","type":"mqtt in","z":"c3a3974.b558268","name":"","topic":"domoticz/out","qos":"2","broker":"362f1eb8.2dcf02","x":144,"y":461,"wires":[["2fa99da8.e94102"]]},{"id":"2fa99da8.e94102","type":"json","z":"c3a3974.b558268","name":"","pretty":false,"x":299,"y":459,"wires":[["8a4ef0e8.90563"]]},{"id":"8a4ef0e8.90563","type":"switch","z":"c3a3974.b558268","name":"","property":"payload.idx","propertyType":"msg","rules":[{"t":"eq","v":"13","vt":"num"}],"checkall":"true","outputs":1,"x":461,"y":468,"wires":[["bb7bfb6a.a7fe18"]]},{"id":"bb7bfb6a.a7fe18","type":"switch","z":"c3a3974.b558268","name":"","property":"payload.nvalue","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"}],"checkall":"true","outputs":1,"x":600,"y":472,"wires":[["ba6e104b.89fef"]]},{"id":"362f1eb8.2dcf02","type":"mqtt-broker","z":"","broker":"127.0.0.1","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"willTopic":"","willQos":"0","willPayload":"","birthTopic":"","birthQos":"0","birthPayload":""}]
local myLightIDX = 13 -- Your light's idx
local myPresIDX = 4 -- Your presence idx
timer = {
'every 15 minutes at daytime',
'every 60 minutes at nighttime'
execute = function(dz, timer)
myLight = dz.devices(myLightIDX)
myPres= dz.devices(myPresIDX)
if (myPres.state=='On')
then
myLight.switchOff().checkFirst().afterSec(1).silent()
myLight.switchOn().checkFirst().forSec(1).silent()
