I found the firmware updates here:
https://github.com/fairecasoimeme/ZiGate/releases
and a tool here for Windows users to apply the updates:
https://github.com/fairecasoimeme/ZiGat ... rammer.zip
Can you please provide some more details:
- can the update be applied through the USB stick, or is it necessary to remove the radio module from the USB stick and put it into some dedicated programming device?
- is there a native tool for Linux users to do a firmware update? Can the lpcprog tool from this package be used?
https://packages.qa.debian.org/l/lpctools.html
- can the Windows tool be used under Wine on Linux? If anybody tried this, can you please share some step-by-step instructions for other users?
- is it possible that the Zigate plugin will be able to manage the firmware updates automatically in future?
updating the Zigate firmware
Daniel Pocock, Debian Developer
https://danielpocock.com
Thorgal789
- Target OS: -
Re: updating the Zigate firmware
There is a tutorial here, but in french (sorry I don't know if there is an english one), try with google translate : https://zigate.fr/documentation/mise-a- ... la-zigate/
merci, I found the Linux instructions at the very bottom
Good. As of now there is no plan to integrate the firmware update process from the plugin side as :
- hard to handle all possible type of platform Windows, Linux and all different type of Linux distribution.
If you want there is also for Zigate specific topic a forum in english on zigate.fr/forum (you need to log in with your zigate.fr credentials you used when ordering the Zigate)
