Domoticz error! Cross-Origin? Topic is solved
dcc86
Post by dcc86 »
Hi All,
I have domoticz running on my synology and this works perfect.
I want to expand with Dashticz but i can't get it worked i tried different version (master, beta and v3) but it doesn't sort my problem.
Also tried different browers...
i followed the following guide to install:
Steps
* Install/activate WebStation via Package Station
* Install/activate PHP via Package Station
* Via Main Menu -> Web station select your preferred HTTP backend server
(assumption: nginx)
* At the same page verify that an PHP version is activated.
* In "Web station" -> "PHP settings" verify that the curl extension is selected.
* Download the latest Dashticz beta branch and copy the complete branch to the web folder.
* Edit custom/CONFIG.js with the basic settings according the installation instructions on the Wiki
Now Dashticz should run on http://[IP of Synology-nas]/dashticz_v2
Well dashticz does run but i can't get connected with domoticz (get the: Domoticz error!
Please, double check the path to Domoticz in Settings!), the ip adress is absolutely right get the following information when debugged (firefox):
Synchrone XMLHttpRequest op de hoofdthread wordt niet meer ondersteund vanwege de nadelige effecten op de eindgebruikerservaring. Zie http://xhr.spec.whatwg.org/ voor meer informatie jquery.min.js:4:15143
Cross-Origin-aanvraag geblokkeerd: de Same Origin Policy staat het lezen van de externe bron op http://192.168.178.12:8084/json.htm?typ ... order=Name niet toe. (Reden: ontbrekend token ‘content-type’ in CORS-header ‘Access-Control-Allow-Headers’ van CORS-preflight-kanaal).
Cross-Origin-aanvraag geblokkeerd: de Same Origin Policy staat het lezen van de externe bron op http://192.168.178.12:8084/json.htm?typ ... order=Name niet toe. (Reden: CORS-aanvraag is niet gelukt).
Google chrome debugging gives:
(index):1 Access to XMLHttpRequest at 'http://192.168.178.12:8080/json.htm?typ ... order=Name' from origin 'http://192.168.178.12' has been blocked by CORS policy: Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource.
main.js?v=1563084782796:1012 Domoticz error!
error @ main.js?v=1563084782796:1012
Domoticz error!
when i open http://192.168.178.12:8084/json.htm?typ ... order=Name in the browser i get all the information from domoticz right....
Can please someone help me with this?
Many thanks in advance,
dcc86
Re: Domoticz error! Cross-Origin?
Post by dcc86 »
still no luck.... i used https://crossorigin.me/ & https://cors-anywhere.herokuapp.com/ in the settings as default CORS url but still got the same problem? Anyone who can help me with this?
dcc86
Post by dcc86 »
I can't sort it myself..... €50,- for the one who can fix it for me f.e. with teamviewer....
dcc86 wrote: Monday 15 July 2019 20:56 I can't sort it myself..... €50,- for the one who can fix it for me f.e. with teamviewer....
Suggest you spend the 50 Euro on a Raspberry :D Connect it with berryboot to your Synology and you will have the best of both worlds + some additional advantages like hourly snapshots and the option to compile domoticz from source.
HansieNL
Post by HansieNL »
I agree with waaren. I think a Raspi is easier to configure.
Blah blah blah
dcc86
Post by dcc86 »
To be honest i got a raspberry pi unused. I swapped from raspberry to synology. So install bootberry and then install domoticz and dashticz on the raspberry? Thanks in advance for your help!
Verstuurd vanaf mijn SM-G960F met Tapatalk
HansieNL
Post by HansieNL »
dcc86 wrote: Tuesday 16 July 2019 20:15
Or just install webserver and Dashticz on the Raspberry. Than you can keep Domoticz running on your Synology.
Blah blah blah
dcc86
Post by dcc86 »
waaren wrote: Suggest you spend the 50 Euro on a Raspberry :D Connect it with berryboot to your Synology and you will have the best of both worlds + some additional advantages like hourly snapshots and the option to compile domoticz from source.
Going to give it a try! Thanks for your help!
HansieNL
Post by HansieNL »
@dcc86: Tip: Setting up an NGINX web server on a Raspberry Pi (with PHP) https://www.raspberrypi.org/documentati ... r/nginx.md
For Dashticz make the following changes: $ sudo apt-get install php7.0-curl php7.0-xml
Set permissions on the web directory /var/www/html:
$ sudo chown www-data:www-data /var/www/html
$ sudo chmod 775 /var/www/html
$ sudo usermod -a -G www-data pi
Blah blah blah
dcc86
Post by dcc86 »
HansieNL wrote:@dcc86: Tip: Setting up an NGINX web server on a Raspberry Pi (with PHP) https://www.raspberrypi.org/documentati ... r/nginx.md
Thanks! Berryboot is not necesarry in that case? Just the webserver and after that dashticz?
HansieNL
Post by HansieNL »
dcc86 wrote: Tuesday 16 July 2019 21:28
Nope, just install Raspbian Stretch Lite and webserver and Dashticz ofcourse. Because the Buster version is only shown on the Raspberry download page you have to download it from here: https://downloads.raspberrypi.org/raspbian/images/
Blah blah blah
dcc86
Post by dcc86 »
This problem is solved. Apparantly domoticz say it's updating on a synology by loading and completing the update screen but doesn't do a thing! updated to the latest version manually and dashticz works! many thanks for help guys!
