custom js
Posted: Saturday 13 July 2019 17:47
by pvklink
Hi, i have a switch (usage kwh) id 982_1 that i show in Dashticz. Normally it the icon is white and it uses always 0.6 kw.
When the wasmachine is executing it uses more than 0,8 i like it to be red.
I added the following code to custom.js.
When the machine is activate (and a washing program it uses more power then 0,8 ... but the switch does not get red...
//add custom javascript in here
function afterGetDevices(){
// 1 powerusage then red
function getChange_982_1(idx,value,device){
if(parseFloat(device['Power Usage'])>1){
blocks['982_1']['icon'] = 'fas fa-thermometer-full';
else {
blocks['982_1']['icon'] = 'fas fa-thermometer-half';
these are exported csv data from the wasmachine
DateTime,"Energieverbruik","Power Usage"
2019-07-12 19:00:00,0,0,7
2019-07-12 19:05:00,,0,7
2019-07-12 19:10:00,,0,7
2019-07-12 19:15:00,,0,7
2019-07-12 19:20:00,,0,6
xls
DateTime Energieverbruik Power Usage Energieverbruik Power Usage
12-7-2019 19:00 0,00
12-7-2019 19:05 0,70
12-7-2019 19:10 0,70
12-7-2019 19:15 0,70
12-7-2019 19:20 0,60
12-7-2019 19:25 0,70
12-7-2019 19:30 0,70
12-7-2019 19:35 0,70
Re: custom js
Posted: Saturday 13 July 2019 23:02
by pvklink
Think i solved it..
i did a
http://192.168.20.35:82/json.htm?type=devices&rid=982
and saw that the property of this kwh device = Usage, so i used that!
// add custom javascript in here
// check properties en kijk welke wijzigt evt lastupdate nemen
// "Usage" : "3 Watt", neemt js wel t getal en heeft het geen last van Watt als text?
function getExtendedBlockTypes(blocktypes){
//blocktypes.Type['Lighting 2'] = { icon: 'fa fa-lightbulb-o', title: '<Name>', value: 'ds' }
return blocktypes;
//0,8
//if(parseFloat(device['Power'])>1){
if(parseFloat(device['Usage'])>1){
else {
Re: custom js
Posted: Friday 26 July 2019 23:40
by HansieNL
I have multiple devices where I want add/remove the same class.
Is it possible to simplify/reduce this code?
//Notebook PC
if (alldevices[350].Data == 'Off') {
$('.block_350 .col-data').addClass('data-off');
else {
$('.block_350 .col-data').removeClass('data-off');
//Desktop PC
if (alldevices[351].Data == 'Off') {
$('.block_351 .col-data').addClass('data-off');
else {
$('.block_351 .col-data').removeClass('data-off');
...and some more devices...
Any help welcome. Thanks.
Re: custom js
Posted: Tuesday 30 July 2019 15:41
by Vomera
Tnx for this post, i was also stuck on the power, now i understand the "device['Usage']" part haha.
Is this also possible with the data from "longfonds" I want to color this too, but the data is not pushed from domoticz.
Re: custom js
Posted: Tuesday 30 July 2019 16:06
by Lokonli
Vomera wrote: Tuesday 30 July 2019 15:41
No, that's not possible.
What I could make is the addition of a custom class depending on a value of the block. For instance:
Blocks['longfonds'] = {
classRules: {
'green': '<2',
'orange: '<6',
'red': '>6'
Then you can use this class in custom.css to set the visual properties.
First valid class rule will be applied.
This should work for all blocks ...
Interested?
Re: custom js
Posted: Tuesday 30 July 2019 19:50
by EdwinK
Lokonli wrote: Tuesday 30 July 2019 16:06
classRules: {
'green': '<2',
'orange: '<6',
'red': '>6'
Interested?
Sounds good enough for me
Re: custom js
Posted: Tuesday 30 July 2019 21:22
by Vomera
Would be very nice!!
Re: custom js
Posted: Tuesday 30 July 2019 22:01
by HansieNL
Can the icon for Longfonds made customizable (icon/image)? Or can we easily change that by css?
Re: custom js
Posted: Tuesday 30 July 2019 23:16
by Lokonli
HansieNL wrote: Tuesday 30 July 2019 22:01
I will add this to the feature request list.
Re: custom js
Posted: Tuesday 30 July 2019 23:41
by HansieNL
Lokonli wrote: Tuesday 30 July 2019 23:16
Thanks,
I think I've got some kind of icon fetishism
Re: custom js
Posted: Wednesday 31 July 2019 10:12
by Vomera
HansieNL wrote: Tuesday 30 July 2019 23:41
Thanks,
Haha that would be a nice icon !!
Re: custom js
Posted: Wednesday 31 July 2019 11:57
by EdwinK
How about a skull if the airquality is in the red's
Re: custom js
Posted: Thursday 01 August 2019 10:13
by Vomera
EdwinK wrote: Wednesday 31 July 2019 11:57
we requested this a few post back, i'll hope they make it
Re: custom js
Posted: Thursday 13 February 2020 16:54
by Vomera
Vomera wrote: Thursday 01 August 2019 10:13
Any news about this ? didn't see it in the release notes ?
or is it still on the list ?
