Raspbian Buster. The bash script does not start with rc.local
All kinds of 'OS' scripts
elpaul
Domoticz version: 2020.1
Post by elpaul »
Hi everyone.
Domoticz V4.10982. RPi 3B+ SanDisc 16GB card, 3A power supply
Until now, I used raspbian Stretch without any problems. Yesterday I went to Buster, and there was a problem with the autostart.
In the home / pi directory, I have a script in bash that runs BLE (chmod 711) iNode.sh
#!/bin/bash
# iBeacon Scan by Radius Networks
# written by Michał Dobrzyński
# modified by iNode.pl 03.12.2017
declare -i cnt
declare -i dcnt
declare -i bcnt
declare -i tl
declare -i bl
declare -i bc
declare -i bt
declare -i DTYPE
if [[ $1 == "parse" ]]; then
  packet=""
  capturing=""
  count=0
  while read line
  do
    count=$[count + 1]
    if [ "$capturing" ]; then
      if [[ $line =~ ^[0-9a-fA-F]{2}\ [0-9a-fA-F] ]]; then
        packet="$packet $line"
	#echo RAW: $packet
	cnt=0
	dcnt=0
	bl=0
	bt=0
        bc=0
	np=""
	mp=""
	DTYPE=0
        for i in $packet; do
            if [[ "$cnt" -eq "13" ]]; then
	      tl=`echo "ibase=16; $i"|bc`
	      #echo TL $tl
            fi
            if [[ "$cnt" -gt "13" ]]; then
	      np+=$i
	      if [[ "$bl" -eq "0" ]]; then
		if [[ "$DTYPE" -eq "130" ]]; then # iNode Energy Meter
		       #echo DTYPE
	               MAC=`echo $packet | awk '{print $13$12$11$10$9$8}'`
	               #echo $mp
		       #CONST
                       HEX=`echo $mp | awk '{ print $12$11 }'`
                       DEC=`echo "ibase=16; $HEX"|bc`
		       CONST=$DEC
		       #echo CONST $CONST
                       #WATY
                       HEX=`echo $mp | awk '{ print $6$5 }'`
		       #echo MINUTE POWER $DEC
                       CALC=`echo $DEC $CONST | awk '{ w=(($1*60.0)/$2*1000); printf"%0.2f\n",  w  }'`
                       #IMPULSY
                       HEXIM=`echo $mp  | awk '{ print $10$9$8$7 }'`
		       #echo TOTAL POWER $HEXIM
                       DECIM=`echo "ibase=16; $HEXIM"|bc`
		       #echo TOTAL POWER $DECIM
                       CALCIM=`echo $DECIM $CONST | awk '{ kWh=($1/$2); printf"%0.3f\n", kWh  }'`
		       #echo CALCIM $CALCIM
                       TODOMOTICZ=`echo $CALCIM | sed -r 's/\.//g'`
                       #domoticz
                       /usr/bin/curl -s -o /dev/null  "http://192.168.0.10:8080/json.htm?type=command&param=udevice&idx=109&nvalue=0&svalue=$CALC;$TODOMOTICZ"
                       #emoncms
                       #/usr/bin/curl -s -o /dev/null  "http://emoncms.org/input/post.json?json={meterpower:$CALC}&apikey=XYZ"
                       #/usr/bin/curl -s -o /dev/null  "http://emoncms.org/input/post.json?json={meterkwh:$CALCIM}&apikey=XYZ"
                       #logowanie do lokalnego sysloga
                       logger POWER: $CALC W $CALCIM kWh -p local2.info
                       #print na ekranie
					   echo MAC: $MAC POWER: $CALC W TOTAL: $CALCIM kWh | awk '{ print strftime("%Y-%m-%d %H:%M:%S"), $0; fflush(); }'
		       DTYPE=0
	        fi
		if [[ "$dcnt" -lt "$tl" ]]; then
		  bl=`echo "ibase=16; $i"|bc`
	          bcnt=0
		  #echo BL $bl
  		  mp=$i" "
                fi
		if [[ "$bcnt" -eq "0" ]]; then
		  bc=`echo "ibase=16; $i"|bc`
		  #echo BC $bc
		fi
		if [[ "$bc" -eq "255" ]]; then
	          if [[ "$bcnt" -eq "2" ]]; then
		    DTYPE=`echo "ibase=16; $i"|bc`
		    #echo DTYPE $DTYPE
		  fi
		fi
		bcnt=$bcnt+1
		bl=$bl-1
		mp+=$i" "
	      fi
	      dcnt=$dcnt+1
            fi
	    cnt=$cnt+1
	done
        capturing=""
        packet=""
      fi
    fi
    if [ ! "$capturing" ]; then
      if [[ $line =~ ^\> ]]; then
        packet=`echo $line | sed 's/^>.\(.*$\)/\1/'`
        capturing=1
      fi
    fi
  done
  hcitool lescan --duplicates --passive 1>/dev/null &
  if [ "$(pidof hcitool)" ]; then
    hcidump --raw | ./$0 parse $1
  fi
fi
I add to rc.local:
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
# Print the IP address
_IP=$(hostname -I) || true
if [ "$_IP" ]; then
  printf "My IP address is %s\n" "$_IP"
fi
sudo /home/pi/iNode.sh
exit 0
and everything works fine on raspnian Strech!
I did the same on Raspbian Buster but the script does not start! When will I issue the command: systemctl status rc-local.service I get what is in the picture below
Can anyone help me?
(The iNode.sh script running manually in the console is working correctly.)
elpaul
Re: Raspbian Buster. The bash script does not start with rc.local
Post by elpaul »
'sleep 10' solved the problem
