cleaning up script advice to use locals
Posted: Tuesday 09 July 2019 21:13
In one of the last topics i got the advise to use locals, so i am updating all my scripts...
1. do i also have to add
local colors and
local actions and what value do i have to give them by default?
2. does local controlVar = "controlVar" -- var, define as type string ...........have to be declared before ........return {
or can i put this rule with the rest of the local declarations.
3. is there a difference where to place the local declarations?
local colors and
-- maak variable controlVar Aan
-- dz.helpers.alertLidl(dz, "paars", 12) daarmee kun je t licht n kleur geven
-- let op ook scripts/dzVents/scripts/global_data.lua
on = { devices = { "usb lamp" }, -- controller , define as virtual selector Switch with all level as named in action table
variables = { controlVar }, -- var, define as type string
logging = { level = domoticz.LOG_ERROR,
marker = "Lidl" },
execute = function(dz, item, info)
local triggerDevice_Off = dz.devices('$usb_lamp_uit')
local triggerDevice_Aan = dz.devices('$usb_lamp_aan')
local triggerDevice_Kleur = dz.devices('$usb_lamp_kleur')
local triggerDevice_Kleuren= dz.devices('$usb_lamp_kleur')
local triggerDevice_Wit = dz.devices('$usb_lamp_wit')
local triggerDevice_Flame = dz.devices('$usb_lamp_flame')
local triggerDevice_Play = dz.devices('$usb_lamp_play')
local triggerDevice_Dim = dz.devices('$usb_lamp_dim')
local triggerDevice_Speed = dz.devices('$usb_lamp_speed')
local logcode = 3
local messageTable = {}
local add = 'add'
local del = 'del'
local chg = 'chg'
local function globalMessage(action, message, logcode)
if logcode == nil then logcode = 3 end
if action == add and logcode > 0 then
messageTable = dz.helpers.addMessage(dz, item, info, message, messageTable, logcode)
elseif action == del then
dz.globalData.mylogging = message
dz.devices('timerlog').updateText(message)
elseif action == chg then
dz.helpers.dumpMessages(dz, messageTable)
local controlVar = dz.variables(controlVar)
colors = { rood = 1,
groen = 2,
blauw = 3,
oranje = 4,
grijs = 5,
roze = 6,
paars = 7,
actions = { Off = function() triggerDevice_Off.switchOn() return end,
Aan = function() triggerDevice_Aan.switchOn() triggerDevice_Flame.switchOn() return end,
Kleuren = function() triggerDevice_Aan.switchOn() triggerDevice_Kleuren.switchOn() return end,
Kleur = function(color)
local repeats = (( colors[color] or 1 ) - 1)
dz.log("Color requested :" .. tostring(color) .. "==>> repeats required " .. repeats ,dz.LOG_DEBUG )
triggerDevice_Kleur.switchOn().repeatAfterSec(0.1, repeats )
return
end,
Wit = function() triggerDevice_Aan.switchOn() triggerDevice_Wit.switchOn() return end,
Flame = function() triggerDevice_Aan.switchOn() triggerDevice_Flame.switchOn() return end,
Play = function() triggerDevice_Aan.switchOn() triggerDevice_Play.switchOn() return end,
Dim = function() triggerDevice_Aan.switchOn() triggerDevice_Dim.switchOn() return end,
Snel = function() triggerDevice_Aan.switchOn() triggerDevice_Speed.switchOn() return end,
local function setVar( request )
if controlVar.value ~= request then
controlVar.set(request).silent()
local function isColorAction( action )
for color, number in pairs(colors) do -- check if called with one of the defined colors
if action == color then
globalMessage(add, ' USB LAMP: krijgt waarde: ' .. action,logcode)
setVar(color)
actions["Kleur"](color)
return true
return false
local function doAction( action )
if actions[action] then
setVar(action)
actions[action]() -- Call required function with key = action
globalMessage(add, ' USB LAMP: heeft een onbekende waarde: ' .. action,logcode)
return false
if item.isDevice and ( not ( isColorAction(item.levelName) ) ) then
globalMessage(add, ' USB LAMP: krijgt waarde: ' .. item.levelName,0)
doAction(item.levelName)
elseif item.isVariable and ( not ( isColorAction(item.value) ) ) then
globalMessage(add, ' USB LAMP: krijgt waarde: ' .. item.value,0)
doAction(item.value)
globalMessage(chg) -- dump
