[error] Too many lines
Posted: Tuesday 09 July 2019 12:19
by Varazir
Found a old post about this but it's a year back or so I guess the system has changed and better to start a new one
I get this error
2019-07-09 12:09:10.372 Error: dzVents: Error: (2.4.24) IKEARemote: An error occurred when calling event handler IKEARemote
2019-07-09 12:09:10.372 Error: dzVents: Error: (2.4.24) IKEARemote: ...omoticz/scripts/dzVents/generated_scripts/IKEARemote.lua:179: Lua script execution exceeds maximum number of lines
But only when I call this function
        local function findGroup(groupname)
            local GroupNumber = 0
            repeat
                local GroupNumber = GroupNumber + 1
                Group = groups[GroupNumber]
                for device, attributes in pairs(control[Group]) do
                    if device == "name" then
                        if attributes == groupname then
                            selectedGroupNumber = GroupNumber
                            return
            until GroupNumber == maxGroup
it's part of my IKEA remote control script.
I added a selector switch to select the room(it's the part that isn't working) as well as I can see in the GUI which group that is correct active.
The function is to for matchning the selected name to the group to control.
groups = {'group1', 'group2', 'group3', 'group4', 'group5', 'group6' }
return  {
    on = {  devices = { 'IKEA Remote*' }},
    logging = { level = domoticz.LOG_DEBUG,
                marker = "IKEARemote" },
    data = { currentGroup = { initial = 1 }},
    execute = function(dz, item)
        control =
            group3 = --Hallway
                name            = 'Taklampa Hall',
                IKEAlamp        = { idx = 40, blink = true },
                IKEAlampGroup   = { idx = 65, toggle = true, dimmer = true},
				--spot2         = { idx = 17, toggle = true, dimmer = true},
				--spot3         = { idx = 19, toggle = true, dimmer = true},
            group1 = --Bedroom
                name            = 'Taklampa Sovrum',
                IKEAlamp        = { idx = 13, toggle = true, blink = true, dimmer = true}
            group5 = --Lilvingroom
                name            = 'Taklampa Vardagsrum',
                --spot1         = { idx = 65, toggle = true, dimmer = true},
                IKEAlampGroup   = { idx = 36, toggle = true, dimmer = true, blink = true}
                --spot3         = { idx = 25, toggle = true, dimmer = true}
			group4 = --Computeroom
                name            = 'Taklampa Datorrum',
                IKEAlamp        =  { idx = 73, toggle = true, blink = true, dimmer = true}
			group6 = --TvBench
                name            = 'Tv Bänk',
                lamp            = { idx = 42, toggle = true, blink = true},
                TvGroup         = { idx = 2,  toggle = true, group = true}
			group2 = --BedroomBlilnder
               name            = 'Rullgardin Sovrum',
               blinder = { idx = 59, toggle = true, blinder = true },
        local selectedGroupNumber = dz.data.currentGroup
        local maxGroup = #groups
        local dummyDimmer = dz.devices(82)
        local function doAction(action, direction)
            selectedGroup = groups[selectedGroupNumber]
            dz.log("Current selected group is." .. selectedGroup)
            dz.log("Current acction is........" .. action)
            for device, attributes in pairs(control[selectedGroup]) do
                    dz.log('Name:.....................'  .. attributes)
                    selectedGroupName = attributes
                    dz.devices('IKEA Remote Groups').switchSelector(attributes).silent()
                    dz.log("Current typ is............" .. device)
                    currentIDx = attributes["idx"]
                    dz.log("Current device IDx is....." .. currentIDx)
                    if attributes["group"] then currentDevice = dz.groups(currentIDx) else  currentDevice = dz.devices(currentIDx) end
                    dz.log("Current device name is........." .. currentDevice.name)
                    for attribute, value in pairs(attributes) do
                        dz.log("Current attribute is......" .. attribute)
                        if attribute == action then
                            dz.log("Current acction is " .. action)
                            -- Blinking
                            if action == 'blink' then
    							local blinkDevice = dz.devices(currentDevice.name)
    							local blinkLevel = currentDevice.level
    							dz.log("Device " .. blinkDevice.name .. " will blink")
    							if blinkDevice.state == "Off" then
    								blinkDevice.switchOn()
    								blinkDevice.switchOff().afterSec(0.5)
    								blinkDevice.switchOn().afterSec(0.5)
    				        elseif action == 'dimmer' then
    							local dimDevice = dz.devices(currentDevice.name)
    							local dimLevel = dimDevice.level
    							local delay = 0
                                dz.log(dimDevice.name .. " direction is " .. direction)
    							if direction == "stop" then
    							    dimDevice.cancelQueuedCommands()
    							    dz.log('Stop dimming of ' .. dimDevice.name .. ' at ' .. dimLevel ..'%')
    							elseif direction == 'down' then
    								repeat
    									delay = delay + 0.1
    									if direction == "down" then dimLevel = dimLevel - 1	else dimLevel = dimLevel + 1 end
    									dz.log('Set ' .. dimDevice.name .. ' to dimLevel '.. dimLevel .. '%, after ' .. delay .. ' seconds', dz.LOG_INFO)
    									dimDevice.dimTo(dimLevel).afterSec(delay)
    								until dimLevel <= 0
    						    elseif direction == 'up' then
                                    repeat
                                        delay = delay + 0.1
                                    until dimLevel >= 100
                            elseif action == 'toggle' then
                                local toggleDevice = currentDevice
                                    toggleDevice.toggleGroup()
                                    toggleDevice.toggleSwitch()
                                --if toggleState  == 'On' then
                                --    dz.log("toggle device " .. toggleDevice.name)
                                --    toggleDevice.toggleSwitch()
                                -- end
            repeat
                            return
        local action = 'blink'
        local direction = 'up'
        if item.state == 'Click' and item.name == 'IKEA Remote Left' then
            selectedGroupNumber = selectedGroupNumber - 1
            if selectedGroupNumber == 0 then selectedGroupNumber = maxGroup end
        elseif item.state == 'Click' and item.name == 'IKEA Remote Right' then
            selectedGroupNumber = selectedGroupNumber + 1
            if selectedGroupNumber > maxGroup then selectedGroupNumber = 1 end
        elseif item.name == 'IKEA Remote' then
            action = 'toggle'
        elseif item.state == 'Hold' and item.name == "IKEA Remote Up"  then
            action = 'dimmer'
        elseif item.state == 'Hold' and item.name == 'IKEA Remote Down' then
            action = 'dimmer'
            direction = 'down'
        elseif item.state == 'Release' and item.name == 'IKEA Remote Down' or item.name == 'IKEA Remote Up' then
            action = 'dimmer'
            direction = 'stop'
        elseif item.name == 'IKEA Remote Groups' then
            findGroup(item.levelName)
            dz.log('Unknown action requested; ignored' )
            return
        if item.state ==  'Click' then
            dz.log('Turning off ' .. item.name)
            dz.devices(item.name).switchOff().silent()
        dz.data.currentGroup = selectedGroupNumber
Re: [error] Too many lines  [Solved]
Posted: Tuesday 09 July 2019 13:15
by waaren
Varazir wrote: Tuesday 09 July 2019 12:19 I get this error
/quote]
In the function you declare two local variables with the name GroupNumber
if you use local you say to Lua: 'this variable only exist within the scope of this block'
The first time you declare local GroupNumber it will exist only in the function
The second time you declare local GroupNumber it will exist only in the repeat - until block.
So despite the fact that they have the same name for Lua they are two separate variables with each there own scope. Luckily easy to solve by removing the word local in line 138. Change
to
Posted: Tuesday 09 July 2019 14:44
by Varazir
waaren wrote: Tuesday 09 July 2019 13:15
to
Thanks, basic scripting syntax mistake .
Learn by doing is works best for me.
