Uncertain how to check temperatures in blockly
Posted: Sunday 07 July 2019 20:53
by FearNaBoinne
First I tried numbers:
Then I tried strings:
But in both cases the temperature is apparently simultaneously above and below 25ºC!
Only thing I haven't tried yet is compare to another sensor, but that'd be silly!
Re: Uncertain how to check temperatures in blockly
Posted: Sunday 07 July 2019 21:18
by waaren
FearNaBoinne wrote: Sunday 07 July 2019 20:53
Number should work. Suggest to first test without time and with just a logmessage. If that works add time condition and last step is to add message to notification subsystem.
Posted: Sunday 07 July 2019 22:52
by FearNaBoinne
waaren wrote: Sunday 07 July 2019 21:18
Without the time I have to wait for it to change, which happens once a day at most, not a valid solution...
Log or notification makes no difference.
Number should work.
As you can see, the system *does* see the correct value (17, {{temperaturedevice[360]}}=="Max Today"), but comparing it to a value doesn't work.
Blockly is a great concept, but the execution is
terribly buggy...
I've got 16 event scripts (and counting), including this one, and only got
ONE Blockly concept to work, all others I had to (reluctantly) go to LUA/dzEvents scripts, because Blockly just doesn't work...
I'll
go redo redid this in dzEvents, because I really do not want to waste more time on this, when I can get this working in dzEvents in 2-3 minutes!
Posted: Monday 08 July 2019 1:07
by waaren
FearNaBoinne wrote: Sunday 07 July 2019 22:52
Just tested and with a differently placed time condition the Blockly solution works.
- temp check Blockly
- tempcheck.png (101.21 KiB) Viewed 1575 times
2019-07-08 00:57:00.496 Status: Time > 00:50 and temperature < 60 -- Time triggered
2019-07-08 00:57:00.497 Status: 21.4;45;1
2019-07-08 00:57:38.411 (Aeotec Zwave stick) Temp + Humidity (Badkamer (Zwave)) -- device triggered
2019-07-08 00:57:38.696 Status: Time > 00:50 and temperature < 60
2019-07-08 00:57:38.696 Status: 21.4;45;1
2019-07-08 00:58:00.528 Status: Time > 00:50 and temperature < 60 -- time triggered
2019-07-08 00:58:00.528 Status: 21.4;45;1
I'll redid this in dzVents, because I really do not want to waste more time on this, when I can get this working in dzVents in 2-3 minutes!
Fully agree but for some domoticz users without any previous programming experience, the learning curve for Lua / dzVents / PHP / Python might scare them a bit.
Posted: Monday 08 July 2019 8:34
by FearNaBoinne
waaren wrote: Monday 08 July 2019 1:07
I'll try this, just for testing, but the other way *should* work as well!
That's why I think it is a great concept, and why I keep trying it... mostly unsuccesfully...
Posted: Monday 08 July 2019 8:41
by FearNaBoinne
FearNaBoinne wrote: Monday 08 July 2019 8:34
Quick update: Yes, the other way works for me as well... But nested IFs should work as well, esp. as it reduces the number of tests*... It looks that's where it broke... It just executed everything inside the outer IF, without taking the inner IF in to consideration...
*) In my version it only needs to do the time check, and only if it is the right time will it retrieve the temperature and do those comparisons... In the working version, it always has to check the time twice and always has to retrieve and check the temperature as well.
Posted: Monday 08 July 2019 11:41
by waaren
FearNaBoinne wrote: Monday 08 July 2019 8:41
This remark triggered my memory. There are quite a number of posts on this forum that nested if's in Blockly does not seem to work. If you search for nested Blockly in the search window, you will find >= 57 posts
Posted: Monday 08 July 2019 22:18
by FearNaBoinne
waaren wrote: Monday 08 July 2019 11:41
Sounds like a bug that needs to be fixed!
Posted: Monday 08 July 2019 22:47
by waaren
FearNaBoinne wrote: Monday 08 July 2019 22:18
True but for some reason I think this will not get to the top of the list of things that needs urgent fixing any time soon..
Posted: Monday 08 July 2019 22:53
by FearNaBoinne
If only I had buckets of spare time...
