Fibaro 223 Switch work but when in scene dont
Posted: Sunday 07 July 2019 9:55
by kinghuzi
Hi I have been using domo for a long time and recently wanted to.migrate it to a VM. I used the backup restore function.
On the new machine, the fibaro relay switch work fine directly and logs seem to reflect it.
2019-07-07 17:52:19.403 Status: User: Admin initiated a switch command (421/Mediaroom 1/On)
2019-07-07 17:52:20.050 (Openzwave USB) Usage (Unknown)
2019-07-07 17:52:20.050 (Openzwave USB) General/kWh (kWh Meter)
2019-07-07 17:52:20.331 OpenZWave: Domoticz has send a Switch command! NodeID: 43 (0x2b)
2019-07-07 17:52:20.332 (Openzwave USB) Light/Switch (Mediaroom 2)
2019-07-07 17:52:20.463 (Openzwave USB) Light/Switch (Mediaroom 2)
2019-07-07 17:52:20.331 Status: User: Admin initiated a switch command (424/Mediaroom 2/On)
But the same switches in Scene (group) do.not function and instead of.binary command of On/Off, a level command is issued. I have restarted system multiple times.
2019-07-07 17:54:36.386 OpenZWave: Domoticz has send a Switch command!, Level: 99, NodeID: 43 (0x2b)
2019-07-07 17:54:36.388 (Openzwave USB) Light/Switch (Mediaroom 1)
2019-07-07 17:54:36.438 Activating Scene/Group Device: Mediaroom 2 (On)
2019-07-07 17:54:36.438 OpenZWave: Domoticz has send a Switch command!, Level: 99, NodeID: 43 (0x2b)
2019-07-07 17:54:36.440 (Openzwave USB) Light/Switch (Mediaroom 2)
2019-07-07 17:54:36.455 (Openzwave USB) General/kWh (kWh Meter)
2019-07-07 17:54:36.525 (Openzwave USB) Usage (Unknown)
2019-07-07 17:54:36.526 (Openzwave USB) General/kWh (kWh Meter)
2019-07-07 17:54:36.385 Status: User: Admin initiated a scene/group command
Any ideas on how to fix ?
