unwanted devices in dashticz
pvklink
- Domoticz version: latest b
Hi, i jyst added a zwave sensor to my dashticz that displays the wattage of my washing machine/ I measure this for testing if my machine is ready and then gives a message by let my google assistant speaks an turning a led lamp red.
i want to display this to check if my algoritmes are working.
But when i add this device (it is displaying) i get two more devices (kwh and onother one)..
How do i delete these from dashticz?
Jablotron connection, Ikea
- EdwinK
- Domoticz version: BETA
Re: unwanted devices in dashticz
I think the device is giving 2 or more data-streams. So you have one with the kwh and another one. You can use the following (adapt the idx to your idx
'IDX_1' Running latest BETA on a Pi-3 | Toon® Thermostat (rooted) | Hue | Tuya | IKEA tradfri | Dashticz V3 on Lenovo Huawei Tablet | Conbee
pvklink
i tried 982-1 and 982_1 no switch at all
- EdwinK
Try with '928_1' with the ' at the beginning and end
pvklink
yep works! thanks!
pvklink
1) Is there an other way to give the icons for devices with a datastream another color?
2) also hide_data does not work...
my trials:
blocks['982_1'] = {}
blocks['982_1']['title'] = 'Was machine';
blocks['982_1']['icon'] = 'fas fa-bolt';
blocks['982_1']['hide_data'] = true;
blocks['982_1']['width'] = 3;
and in css
.fa-bolt.on {color: red !important;}
.fa-bolt.off {color: green !important;}
last part does not work...
this also does not work
.block_982_1 .fa-bolt.on {color: red;}
.block_982_1 .fa-bolt.off {color: lightgrey;}
my trials:
and in css
- HansieNL
Can you try: .fas.fa-bolt.on {color: red !important;}
Blah blah blah
pvklink
thanks, but did not work...
/* .fa-bolt.on {color: red !important;} */
/* .fa-bolt.off {color: green !important;} */
.fas.fa-bolt.on {color: green !important;}
- HansieNL
@pvklink: Can you try: .block_982_1 .icon.on {color: red;}
Blah blah blah
pvklink
noop, still does not work..
here is my config...
i did remove de /* ... */ to activate it...
these are all the trials...
the attached image is a little bit older then the config (no update date anymore , i added: last_update....
blocks['982_1']['switch'] = true;
blocks['982_1']['last_update'] = false;
blocks[1025] = {}
blocks[1025]['title'] = 'Zolder radiator';
blocks[1025]['hide_data'] = true;
blocks[1025]['switch'] =true;
blocks[1025]['width'] = 3;
blocks[1025]['last_update'] = false;
css
/* .block_982 .fa-bolt.on {color: red;} WERKT NIET */
/* .block_982 .fa-bolt.off {color: lightgrey;} WERKT NIET*/
/* .block_982_1 .icon.on {color: red !important;} WERKT NIET */
/* .block_982_1 .icon.off {color: red !important;} WERKT NIET */
/* .fa-bolt.on {color: red !important;} WERKT NIET*/
/* .fa-bolt.off {color: green !important;} WERKT NIET*/
/* .fas.fa-bolt.on {color: red !important;} WERKT NIET*/
/* .fas.fa-bolt.on {color: green !important;} WERKT NIET*/
blocks[1025] = {}
css
- Naamloos.png (6 KiB) Viewed 1296 times
Lokonli
If you want to change the icon color for block 982_1 add the following to custom.css:pvklink wrote: Monday 08 July 2019 16:07 noop, still does not work..
blocks[1025] = {}
css
.block_982_1 .col-icon {
If you want to change the color depending on the data, then first add a class to the block via the afterGetDevices() function in custom.js:
function afterGetDevices(){
var device = alldevices['982'];
console.log(device);
var usage = parseFloat(device['Usage']);
console.log(usage);
if( usage >20){
$('div.block_982_1').addClass('warning');
else {
$('div.block_982_1').removeClass('warning');
.warning .col-icon {
color: blue !important
}If it's working you can remove the two console.log statements.
pvklink
when i arrive on my holiday address..i am going to try it..thanks!
