Neo Coolcam PIR Motion Sensor V2
poudenes
Domoticz version: 3.8993
Post by poudenes »
Hi All,
It was not possible to disable the LED of the device. And read some articles.
Change the INDEX number from 10 to 11. In manual I read that INDEX 10 is Ambient Temperature Differential Report
nano /home/pi/domoticz/Config/shenzen_neo/nas-pd02z.xml
change the line:
<Value type="list" genre="config" instance="1" index="10" label="Motion detection LED indication" value="1" size="1">
to
<Value type="list" genre="config" instance="1" index="11" label="Motion detection LED indication" value="1" size="1">
now I can disable the LED Flashing when there is motion
There is also a last option written in manual:
Function: Ambient Temperature Differential Report
Parameter Number: 10
Parameter Size: 1 Byte
Available Settings: 0 ~ 127
Default Setting: 5
t
    <Value type="byte" genre="config" instance="1" index="10" label="Ambient Temperature Differential Report" value="5" min="0" max="127" size="1">
      <Help>
        DESCRIPTION HERE
        Available Settings: 0 ~ 127.
      </Help>
    </Value>
Function: Ambient Light Intensity Calibration
Parameter Number: 99
Parameter Size: 2 Byte
Available Settings: 1 ~ 65536
Default Setting: 1000
t
    <Value type="byte" genre="config" instance="1" index="99" label="Ambient Light Intensity Calibration" value="1000" min="1" max="65536" size="2">
      <Help>
        DESCRIPTION HERE
        Available Settings: 1 ~ 65536.
      </Help>
    </Value>
Tried to add this one as well but then the configuration part is blank when goto the ZWave Control Panel
Here info on the site:
https://products.z-wavealliance.org/pro ... 20/configs
tonbor
Re: Neo Coolcam PIR Motion Sensor V2
Post by tonbor »
Well ozw has fixed the config two days ago. index 10 and 11 has different functions according to the version of the pir hardware, with or without temperature. Now domoticz has to pickup this new xml
poudenes
Post by poudenes »
Yes They inform me about it. :) good to see the change.
