Solivia Gateway to get inverter counters
bjornp
Post by bjornp »
If someone else want to read the Solivia Gateway counters of inverters you can use this.
Edit: do not use os.exit() :? .. It kills Domoticz. Use return instead. Changed code below.
-- Get Solivia inverter counters
-- Change weburl and inverter device name
    on      =   {   timer   = { "every 5 minutes"}},
    execute = function(dz)
        local inverter = dz.devices("Solivia invertername")
        weburl='http://<IP_ADRES_OF_GATEWAY>/ID_<ID_OF_INVERTER>'
        local f = assert(io.popen("curl -s " .. weburl, 'r'))
        local s = assert(f:read('*a'))
        f:close()
        -- Exit script if inverter is offline or unavailable
        if s:match('Operation failed') then return end
        power=s:match('Actual Power.-<td width="190">(.-)</td>') -- in W
        energy=s:match('Total Energy.-<td width="190">(.-)</td>') -- in kWh
        -- Exit script if inverter returns no data available value
        if power == "no data available" or energy == "no data available" then return end
        -- print("Power= " .. power .. " W | Energy = " .. energy .. " kWh")
        -- Solivia returns Total energy in kWh but Domoticz expects energy in Wh so multiply by 1000
        inverter.updateElectricity(power,energy*1000)
sincze
Domoticz version: 2024.4
Re: Solivia Gateway to get inverter counters
Post by sincze »
Tnx for sharing!
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
