what is wrong with this os.execute statement
Posted: Friday 28 June 2019 16:03
by Gravityz
domoticz is complaining about this os statement.
2019-06-28 15:56:32.024 Error: dzVents: Error: (2.4.23) error loading module 'habridge' from file '/usr/local/domoticz/var/scripts/dzVents/generated_scripts/habridge.lua':
2019-06-28 15:56:32.024 ...oticz/var/scripts/dzVents/generated_scripts/habridge.lua:22: ')' expected near '{'
i really ccan not see where the problem lies
active = true,
-- de devices die dit script triggeren
devices = {
'Vitrinekast',
'Plafondspots'
local devicename = device.name
local devicestatus = device.state
local devicelevel = device.level
if devicestatus == 'On' then devicestatus ='true'
if devicestatus == 'Off' then devicestatus ='false'
if (devicename == 'Vitrinekast') then
os.execute('curl -X PUT -d '{"on": true}' "http://192.168.1.50:8082/api/8d84b9c378c94dd6afbf0180b73ecba9/lights/106/bridgeupdatestate"')
the thing is when i execute this complete command from ash it works
also when i comment out the os.execute rule the script does not generate errors
root@DISKSTATION:~# curl -X PUT -d '{"on": true}' http://192.168.1.50:8082/api/8d84b9c378c94dd6afbf0180b73ecba9/lights/106/bridgeupdatestate
[{"success":{"/lights/106/state/on":true}}]root@DISKSTATION:~#
Re: what is wrong with this os.execute statement
Posted: Friday 28 June 2019 16:35
by waaren
Gravityz wrote: Friday 28 June 2019 16:03
DzVents does encounter an unmatched quote and therefor cannot continue
Can you try this ?
active = true,
devices = {
'Vitrinekast',
'Plafondspots'
curlString = 'curl -m5 -X PUT -d \'{"on": true}\' "http://192.168.1.50:8082/api/8d84b9c378c94dd6afbf0180b73ecba9/lights/106/bridgeupdatestate"'
domoticz.log("processing " .. curlString)
os.execute(curlString)
Posted: Friday 28 June 2019 16:46
by Gravityz
yes,
that works. so what was wrong with my example?
also have you an idea how to replace the true status with the variable devicestatus
i got this working in another script without the backslashes but is seems when the \ is used al things change (do not understand the logic.
i want to use this script to update habridge status so it needs to pass true/false and briightness(bri)
Posted: Friday 28 June 2019 17:08
by waaren
Gravityz wrote: Friday 28 June 2019 16:46
The 2nd
' in this line close the string. dzVents (Lua) then expect either a
) to close the function parameter to os.execute() or
.. to concatenate with another string but is does get a
By putting a
\ in front of a quote you tell Lua to take that quote literal and do not interpret it (it's called escaping).
Probably a double quote following a single quote or vice versa.
Like this ?
active = true,
devices = {
'Vitrinekast',
'Plafondspots'
curlString = 'curl -m5 -X PUT -d \'{"on": ' .. tostring( device.state == 'On' ) ..' }\' "http://192.168.1.50:8082/api/8d84b9c378c94dd6afbf0180b73ecba9/lights/106/bridgeupdatestate"'
Don't understand this question
Posted: Friday 28 June 2019 17:13
by Gravityz
no i mean i want to replace the statement true with a variable.
curlString = 'curl -m5 -X PUT -d \'{"on": $devicestatus}\' "
http://192.168.1.50:8082/api/8d84b9c378 ... pdatestate"'
when variable devicestatus is true it switches the lightstate to true
when variable is false it switches the lightstate to false
of course i know i can not use $devicestatus but because of al those \\\ i do not know what to put there to get it working
Posted: Friday 28 June 2019 17:24
by waaren
Gravityz wrote: Friday 28 June 2019 17:13
tostring( device.state == 'On' ) should evaluate to either 'true' or 'false'
What do you see in the log ?
Re: what is wrong with this os.execute statement [Solved]
Posted: Friday 28 June 2019 17:32
by jvdz
Something like this?:
curlString = 'curl -m5 -X PUT -d \'{"on": ' .. devicestatus .. '}\' "http://192.168.1.50:8082/api/8d84b9c378 ... pdatestate"'
Jos
Posted: Friday 28 June 2019 17:43
by Gravityz
Thanks Jos.
your example is easier to read for my brain(probably because i think a bit old school)
Posted: Friday 28 June 2019 18:11
by Gravityz
thanks Jos and waaren.
got it working with both on/off and brightness.
need to convert it to other levels but that should not be that hard.
fyi, i recently implemented habridge and openhab so that i could control domoticz through google home.
working very nice but it only suncs from openhab to domoticz, not the other way around.
i am going to use this script to update the openhab device status
