Sunset light switch does not work
jellex87
I’m very new to Domoticz and Blockly, so can anyone tell me why this script isn’t working?
- D2600EC6-B03B-40F2-90F5-597FF66984C9.jpeg (80.16 KiB) Viewed 1950 times
jellex87
Re: Sunset light switch does not work
‘Sunset actief’ is a dummy switch that turns on at sunset.
- Treve
- Domoticz version: v4.11474
Try, if time = sunset then .......
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
jellex87
allready tried this one, but does not work as well.
- Naamloos.jpg (25.34 KiB) Viewed 1938 times
- waaren
- Time = sunset
jellex87
Allready tried it... does not work. Is the script good?
- waaren
You should also look where the AND is placed. In your first post it is in the wrong place.
If you can share the exported blockly I can test
jellex87
Googled for it, but can't find the way to export the Blocky. Please let me know.
- waaren
Press the export button, [ctrl]a, [ctrl]c, goto forum, [ctrl] v, strip garbage before <xml, strip out last line (Ok)jellex87 wrote: Friday 28 June 2019 15:46 can't find the way to export the Blocky. Please let me know.
jellex87
Don't have that menu on Synology. I will look for an update first.
- waaren
You could use the time in between to split-up the Blockly.jellex87 wrote: Friday 28 June 2019 16:04 Don't have that menu on Synology. I will look for an update first.
So create a small Blockly where you only check if time > sunset and write something to the log and a second small blockly where you check the other condition and write something to the log. If they both work you can try with an AND between the two conditions.
