Writing a file with a value to /home/pi/Documents on Raspberry
Posted: Thursday 27 June 2019 14:17
by paul402
I have scripts working from switch triggers in /home/pi/domoticz/scripts/python.
The file value written allows a Python program to freeze certain garden window shutters. All well and good.
I would like a Dzvents script to directly write a value to a python file in /home/pi/Documents on a Raspberry so that another python script accessing that file (not in the Domoticz scripts directory) can work with the data.
I couldn't find any info about this. Does it mean that it is not possible?
Re: Writing a file with a value to /home/pi/Documents on Raspberry
Posted: Thursday 27 June 2019 16:17
by waaren
paul402 wrote: Thursday 27 June 2019 14:17
Sure it is but this is not specific to domoticz or dzVents so you will find the information on how to do that in more generic Lua documentation. I cannot see in your post what kind of value you need and if you want to (re)create a file or insert a value in an existing file. The example below just create a file when it does not exist and append a text line including a variable (here a date/time).
-- write value to file
return
on = { timer = { 'every minute' }}, -- just for the example
logging = { level = domoticz.LOG_DEBUG, marker = 'value2File' },
execute = function( dz )
local out = '/home/pi/Documents/"Python file"'
local function osCommand(cmd)
local fileHandle = assert(io.popen(cmd, 'r'))
local commandOutput = assert(fileHandle:read('*a'))
local returnTable = {fileHandle:close()}
dz.log('\nCommand: ' .. cmd ..
'\nReturnCode: ' .. returnTable[3] ..
'\ncommandOutput: ' .. commandOutput,
dz.log_debug)
return commandOutput,returnTable[3] -- rc[3] contains returnCode
osCommand ('echo dzVents was here at ' .. dz.time.rawDate .. ' ' .. dz.time.rawTime .. ' >> ' .. out .. '; chmod a+r ' .. out )
Posted: Thursday 27 June 2019 16:43
by Egregius
The pass2php version
lg('Pass2PHP whas here at '.strftime("%F %T", TIME));
Sorry, can't help it. It's stronger than myself
Re: Writing a file with a value to /home/pi/Documents on Raspberry [Solved]
Posted: Friday 28 June 2019 10:06
by paul402
A big thanks to both of you for a) putting me on the right track. It's so easy when you know how, and b) giving me a new avenue of php to explore!
