IKEA Trådfri Remote control [Solved]
Posted: Tuesday 25 June 2019 16:04
This is my(and waaren and others ) solution on using 1 IKEA Trådfri Remote to control several groups/devices.
I guess you can scale this to have several remotes, example one for each room that has it's own set of groups
Hardware
ZigBee usb device with firmware https://github.com/Koenkk/Z-Stack-firmw ... _Home_1.2/
Software
Zigbee2MQTT
This is my IKEA Trådfri devices in Domoticz
Script
Using the dim action for Blinders isn't the best solution.
I have to look into another solution for it.
Added it to GitHub
https://github.com/varazir/Domoticz-Script
Hardware
Software
Zigbee2MQTT
Script
groups = {'group1', 'group2', 'group3', 'group4', 'group5', 'group6' }
on = { devices = { 'IKEA Remote*' }},
logging = { level = domoticz.LOG_DEBUG,
marker = "IKEARemote" },
data = { currentGroup = { initial = 1 }},
execute = function(dz, item)
control =
group3 = --Hallway
lamp = { idx = 40, toggle = true, dimmer = true, blink = true },
--spot1 = { idx = 15, toggle = true, dimmer = true},
--spot2 = { idx = 17, toggle = true, dimmer = true},
--spot3 = { idx = 19, toggle = true, dimmer = true}
group1 = --Bedroom
lamp = { idx = 13, toggle = true, blink = true, dimmer = true}
group4 = --Lilvingroom
--spot1 = { idx = 21, toggle = true, dimmer = true},
spot2 = { idx = 36, toggle = true, dimmer = true, blink = true}
--spot3 = { idx = 25, toggle = true, dimmer = true}
group6 = --Computeroom
lamp = { idx = 73, toggle = true, blink = true, dimmer = true}
group5 = --TvBench
lamp = { idx = 42, toggle = true, blink = true},
onkyoHW = { idx = 74, toggle = true},
tv = { idx = 45, toggle = true},
onkyo = { idx = 43, toggle = true}
group2 = --BedroomBlilnder
blinder = { idx = 59, toggle = true, dimmer = true },
local selectedGroupNumber = dz.data.currentGroup
local maxGroup = #groups
local function doAction(action, direction)
selectedGroup = groups[selectedGroupNumber]
dz.log("Current selected group is." .. selectedGroup)
dz.log("Current acction is........" .. action)
for device, attributes in pairs(control[selectedGroup]) do
dz.log("Current typ is............" .. device)
currentIDx = attributes["idx"]
currentDevice = dz.devices(currentIDx)
dz.log("Current device is........." .. currentDevice.name)
dz.log("Current device IDx is....." .. currentIDx)
for attribute, value in pairs(attributes) do
dz.log("Current attribute is......" .. attribute)
if attribute == action then
dz.log("Current acction is " .. action)
-- Blinking
if action == 'blink' then
local blinkDevice = dz.devices(currentDevice.name)
local blinkLevel = currentDevice.level
dz.log("Device " .. blinkDevice.name .. " will blink")
if blinkDevice.state == "Off" then
blinkDevice.switchOn()
blinkDevice.switchOff().afterSec(0.5)
blinkDevice.switchOn().afterSec(0.5)
elseif action == 'dimmer' then
local dimDevice = dz.devices(currentDevice.name)
local dimLevel = dimDevice.level
local delay = 0
dz.log(dimDevice.name .. " direction is " .. direction)
if direction == "stop" then
dimDevice.cancelQueuedCommands()
dz.log('Stop dimming of ' .. dimDevice.name .. ' at ' .. dimLevel ..'%')
elseif direction == 'down' then
repeat
delay = delay + 0.1
if direction == "down" then dimLevel = dimLevel - 1 else dimLevel = dimLevel + 1 end
dz.log('Set ' .. dimDevice.name .. ' to dimLevel '.. dimLevel .. '%, after ' .. delay .. ' seconds', dz.LOG_INFO)
dimDevice.dimTo(dimLevel).afterSec(delay)
until dimLevel <= 0
elseif direction == 'up' then
repeat
delay = delay + 0.1
until dimLevel >= 100
elseif action == 'toggle' then
local toggleDevice = dz.devices(currentDevice.name)
local toggleState = toggleDevice.state
if toggleState == 'On' then toggleDevice.switchOff() else toggleDevice.switchOn() end
local action = 'blink'
local direction = 'up'
if item.state == 'Click' and item.name == 'IKEA Remote Left' then
selectedGroupNumber = selectedGroupNumber - 1
if selectedGroupNumber == 0 then selectedGroupNumber = maxGroup end
elseif item.state == 'Click' and item.name == 'IKEA Remote Right' then
selectedGroupNumber = selectedGroupNumber + 1
if selectedGroupNumber > maxGroup then selectedGroupNumber = 1 end
elseif item.name == 'IKEA Remote' then
action = 'toggle'
elseif item.state == 'Hold' and item.name == "IKEA Remote Up" then
action = 'dimmer'
elseif item.state == 'Hold' and item.name == 'IKEA Remote Down' then
action = 'dimmer'
direction = 'down'
elseif item.state == 'Release' and item.name == 'IKEA Remote Down' or item.name == 'IKEA Remote Up' then
action = 'dimmer'
direction = 'stop'
dz.log('Unknown action requested; ignored' )
return
if item.levelName == 'Click' then
dz.log('Turning off' .. item.name)
dz.devices(item.name).switchOff().silent()
dz.data.currentGroup = selectedGroupNumber
}https://github.com/varazir/Domoticz-Script
