Page 1 of 5
Dashticz V3 - Automatic installation
Posted: Tuesday 18 June 2019 15:06
by Lokonli
Dashticz V3, beta branch, contains an automatic installation script, for which I need a few beta tester.
The script has been tested on a Raspberry and on a Ubuntu system.
The script:
* asks for a folder where to install Dashticz V3
* asks to install the beta or master branch : For now only beta works with the auto install!!
* Clones the Dashticz V3 repository and selected branch into a new folder
* Asks for the IP adress of your Domoticz server.
* Copies CONFIG_DEFAULT.js to CONFIG.js with the correct IP address for Domoticz
Then a Makefile is executed which:
* Installs Docker (if not installed yet)
* Creates a Dashticz V3 container, named dtv3, containing Apache and PHP
* FInd the first free port, 8082 or higher
* Starts the container on the first free port
* Mounts the dashticz_v3 folder to the web-root of the container
* Shows the Dashticz url
If you open this url then the default Dashticz dashboard becomes visible.
So no more need to configure Apache and/or PHP! It just works out-of-the box.
You need a few 100 MB free space on your system.
The first time the installation may take a while (5 - 15 minutes?): be patient.
If the default page is working then you can copy your previous CONFIG.js, custom.css, custom.js from your previous installation to dashticz/custom.
Just refresh your browser, and your new dashboard is shown. No need to rebuild the docker container.
For now, this installation scripts is only recommended for people with some Linux experience, because it was only tested on a limited number of systems.
If issues popup I'll try to fix them as quick as possible.
Instructions:
First go to a folder of choice:
mkdir test
cd test
Then start the script:
. <(wget -qO - https://raw.githubusercontent.com/Dashticz/dashticz/beta/scripts/dashticz_install.sh )
If you have tested the installation script, please leave some feedback here on the result, and on the system you are using.
See the documentation for additional info:
https://dashticz.readthedocs.io/en/mast ... stall.html
Thanks for your cooperation.
Re: Dashticz V3 - Automatic installation
Posted: Tuesday 18 June 2019 15:21
by EdwinK
Tried on Synology
Configuring Dashticz.
What is the IP:port address of your Domoticz server? (example: 192.168.178.18:8080): 192.168.0.11:8080
Finding a free port for Dashticz
-ash: ss: command not found
Port 8082 is NOT in use
Setting up Dashticz on port 8082
-ash: make: command not found
Domoticz connection OK
All done
So if I understand it correctly, you can not install it on a separate server? My domoitcz runs on a Pi, but dashticz on Synology.
Posted: Tuesday 18 June 2019 16:13
by Lokonli
EdwinK wrote: Tuesday 18 June 2019 15:21 Tried on Synology
All done
There is no need to run Domoticz and Dashticz on the same system: separate server should be fine.
To not pollute the forum too much I've created an issue on Github:
https://github.com/dashticzv3/dashticz_v3/issues/3
I'll do the follow-up there, ok?
Posted: Tuesday 18 June 2019 19:16
by brain
it works well.
nice work .
my system is a pi 3.
with Raspbian Stretch Lite
I had just done a new domoticz installation, and I had to install dashticz again.
perfect timing thanks
Posted: Tuesday 18 June 2019 19:52
by Lokonli
brain wrote: Tuesday 18 June 2019 19:16 it works well.
nice work .
ok, good to know. Thanks!
Posted: Wednesday 19 June 2019 20:24
by jake
I have followed the steps to install V3 on my xbian (Kodi) driven RPI.
Issues:
Curl wasn't installed initially. Installed it with sudo apt-get install curl
Since xbian makes regular backups of home and system folders, I tried to keep V3 out of the home folder and decided to create a folder in root. The script doesn't like this, since it returns an error with 'permission denied'. However, the script tries to continue, even while it can't 'cd' into this 'not created' folder.
I created a folder under 'home' at the end. The script goes nicely through all steps, until, at the end of the script, it says: -bash: make: command not found, and continues with the 2 lines 'Domoticz connection OK' and 'All done'
I added make by sudo apt-get install make
When I tried to restart the script, it gives the warning message that I should update Dashticz, by cancelling the installer. However, it doesn't say to use 'CTRL-C' for that.
make update didn't cut it for me (of course). I discovered to enter 'make start'. Unfortunately it ended with the following error:
xbian@xbian ~/docker/dashticz_v3 $ make start
Let's install docker first
curl -sSL https://get.docker.com | sh
# Executing docker install script, commit: 2f4ae48
+ sudo -E sh -c apt-get update -qq >/dev/null
+ sudo -E sh -c apt-get install -y -qq apt-transport-https ca-certificates curl >/dev/null
+ sudo -E sh -c curl -fsSL "https://download.docker.com/linux/raspbian/gpg" | apt-key add -qq - >/dev/null
Warning: apt-key output should not be parsed (stdout is not a terminal)
+ sudo -E sh -c echo "deb [arch=armhf] https://download.docker.com/linux/raspbian stretch stable" > /etc/apt/sources.list.d/docker.list
+ [ -n  ]
+ sudo -E sh -c apt-get install -y -qq --no-install-recommends docker-ce >/dev/null
If you would like to use Docker as a non-root user, you should now consider
adding your user to the "docker" group with something like:
  sudo usermod -aG docker xbian
Remember that you will have to log out and back in for this to take effect!
WARNING: Adding a user to the "docker" group will grant the ability to run
         containers which can be used to obtain root privileges on the
         docker host.
         Refer to https://docs.docker.com/engine/security/security/#docker-daemon-attack-surface
         for more information.
sudo docker build -t dtv3 .
ERRO[0000] failed to dial gRPC: cannot connect to the Docker daemon. Is 'docker daemon' running on this host?: dial unix /var/run/docker.sock: connect: no such file or dir
ectory
context canceled
Makefile:29: recipe for target 'start' failed
make: *** [start] Error 1
For the time being I copied the dashticz folder to my /var/www/html/ folder and run it from there in the default way.
Posted: Wednesday 19 June 2019 23:00
by Lokonli
jake wrote: Wednesday 19 June 2019 20:24 I have followed the steps to install V3 on my xbian (Kodi) driven RPI.
Issues:
+ [ -n  ]
         docker host.
ectory
context canceled
It seems the Docker daemon is not running on your system. Can you check with:
sudo systemctl status docker
If docker is not running you should be able to start it with:
sudo systemctl enable docker
sudo systemctl start docker
You can check again with:
If docker is active, you should be able to build and run the container with the following command from your dashticz_v3 folder:
make start
Posted: Wednesday 19 June 2019 23:29
by jake
Issues:
+ [ -n  ]
         docker host.
ectory
context canceled
make start
Thanks, on Xbian I had to follow this procedure from the forum http://forum.xbian.org/thread-4021.html ... ght=docker (xbian uses upstart instead of systemd). Afterwards the 'make start' ran fine.
Dashticz runs as well under port 8082 now!
So, I guess, you have to check with your script every tool used to see whether or not it is installed and if this systemd or upstart thing is used. For me this procedure was just as much of a hassle as before with PHP and apache ;) and that is not what you're aiming for of course! Keep up the good work!
UPDATE:
In my previous post I said that copying the V3 to my /var/www/html folder worked fine.
I now ran the 'Docker version' and saw that the 'garbage bin' block doesn't want to load. Going back to my /var/www/html variant, the 'garbage bin' block loads OK. I copied the /custom folder from the one into the other, so they're identical!
Posted: Wednesday 19 June 2019 23:39
by Lokonli
What is your garbage provider?
Posted: Thursday 20 June 2019 7:09
by jake
Lokonli wrote:What is your garbage provider?
Hvc
Posted: Thursday 20 June 2019 8:14
by poudenes
Did the install test.
got a error that GIT was not installed. After installed GIT manual the install went ok.
Posted: Thursday 20 June 2019 12:12
by Lokonli
poudenes wrote: Thursday 20 June 2019 8:14 Did the install test.
Good. Thanks for testing!
What kind of system do you have?
I will add the dependencies for GIT, curl, make to the script/makefile/instructions.
It seems there is one PHP module missing in the Docker container: Some garbage calendars won't work.
I will fix this within a few days.
Posted: Thursday 20 June 2019 12:21
by poudenes
Lokonli wrote: Thursday 20 June 2019 12:12
RPi 3B+
Debian Stretch Lite latest update
Domoticz:
Version: 4.10717
Build Hash: b38b49e5
Compile Date: 2019-05-09 13:04:08
dzVents Version: 2.4.19
Python Version: 3.6.4 (default, Oct 10 2018, 09:47:26) [GCC 6.3.0 20170516]
Posted: Thursday 20 June 2019 13:17
by jake
Lokonli wrote: ...
As soon as you have an update, I will test again. Since Xbian automatically makes system images, I can roll back to last week and try again with the same starting point.
Will the update also take into account the 'upstart method' to install docker?
Posted: Thursday 20 June 2019 13:31
by Lokonli
That sounds great. Do you have a reference to the Docker install upstart method? Then I'll have a look.
Posted: Thursday 20 June 2019 14:44
by jake
Lokonli wrote:That sounds great. Do you have a reference to the Docker install upstart method? Then I'll have a look.
Yes, the suggested script is mentioned in the forum in my previous message.
Posted: Friday 21 June 2019 9:00
by poudenes
Lokonli wrote: Thursday 20 June 2019 13:31 That sounds great. Do you have a reference to the Docker install upstart method? Then I'll have a look.
1 off topic question. What is the positive reason to use Docker? I read its because of containers. But why. Just install is the same right?
Posted: Friday 21 June 2019 14:45
by Lokonli
I noticed some people had difficulties with installing apache and php. The goal was to create a multi platform install script.
One of the advances of a Docker container is that we then have a more or less standard platform. That makes developing and testing of new functionality easier.
Example: add authentication for Apache, automatic test scripts, ...
But you can of course use manual install as well.
Posted: Wednesday 26 June 2019 23:34
by jake
I did a 'make update' and now the garbage is loading alright. Thankf for fixing!
I noticed something else (very minor issue):
Because I had V3 setup 'manually' and via Docker, I can load them both in different tabs. I skipped between them and found something 'moving' in the calendar. Finally I saw that in the docker version of dashticz V3 the 'all day' events have a 02:00 time after the date, where the normal version doesn't have that.
Again, equal config file, so that doesn't explain.
Posted: Thursday 27 June 2019 7:48
by Lokonli
jake wrote: Wednesday 26 June 2019 23:34 I did a 'make update' and now the garbage is loading alright. Thankf for fixing!
Yesterday I indeed released beta 3.0.1. Thanks for confirming that your garbage issue is solved.
The 02:00 time issue sounds like an incorrect timezone setting, probably inside the Docker container. I'm afraid I don't have the time to look into this in the coming 3 weeks (holiday). I'll create an issue on Github. Maybe someone else is willing to pick this up.
