Zigate - Problems with Osram Smart Plug
Posted: Monday 17 June 2019 22:06
since updating to firmware 3.0f I have problems adding the Osram Plug. Before the update, the plugs worked fine.
The Zigate-Plugin is in the beta channel, I did a git pull before adding the devices. Domoticz is also uptodate. Is this a code issue?
The logs:
Thank you in advance!
The logs:
2019-06-17 21:56:54.303 (Zigate) Decode004d - rebind clusters for 73a4
2019-06-17 21:56:54.302 Status: (Zigate) Device Annoucement ShortAddr: 73a4, IEEE: 7cb03eaa0a02c9d3
2019-06-17 21:56:54.036 Error: (Zigate) 'onMessage' failed 'AttributeError':''dict' object has no attribute 'append''.
2019-06-17 21:56:54.036 Error: (Zigate) ----> Line 764 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onMessage
2019-06-17 21:56:54.036 Error: (Zigate) ----> Line 466 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onMessage
2019-06-17 21:56:54.036 Error: (Zigate) ----> Line 256 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function onMessage
2019-06-17 21:56:54.036 Error: (Zigate) ----> Line 384 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function processFrame
2019-06-17 21:56:54.036 Error: (Zigate) ----> Line 437 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function receiveStatusCmd
2019-06-17 21:56:54.036 Error: (Zigate) ----> Line 348 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function sendData
2019-06-17 21:56:54.036 Error: (Zigate) ----> Line 180 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function _sendData
2019-06-17 21:56:54.036 Error: (Zigate) ----> Line 101 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/APS.py', function processCMD
2019-06-17 21:56:54.036 Error: (Zigate) ----> Line 87 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/APS.py', function _addNewCmdtoDevice
2019-06-17 21:56:56.411 Error: (Zigate) 'onMessage' failed 'AttributeError':''dict' object has no attribute 'append''.
2019-06-17 21:56:56.412 Error: (Zigate) ----> Line 764 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onMessage
2019-06-17 21:56:56.412 Error: (Zigate) ----> Line 466 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onMessage
2019-06-17 21:56:56.412 Error: (Zigate) ----> Line 256 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function onMessage
2019-06-17 21:56:56.412 Error: (Zigate) ----> Line 391 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function processFrame
2019-06-17 21:56:56.412 Error: (Zigate) ----> Line 411 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function receiveDataCmd
2019-06-17 21:56:56.412 Error: (Zigate) ----> Line 348 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function sendData
2019-06-17 21:56:56.412 Error: (Zigate) ----> Line 180 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function _sendData
2019-06-17 21:56:56.412 Error: (Zigate) ----> Line 101 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/APS.py', function processCMD
2019-06-17 21:56:56.412 Error: (Zigate) ----> Line 87 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/APS.py', function _addNewCmdtoDevice
2019-06-17 21:56:56.517 Error: (Zigate) 'onMessage' failed 'AttributeError':''dict' object has no attribute 'append''.
2019-06-17 21:56:56.517 Error: (Zigate) ----> Line 764 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onMessage
2019-06-17 21:56:56.517 Error: (Zigate) ----> Line 466 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onMessage
2019-06-17 21:56:56.517 Error: (Zigate) ----> Line 256 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function onMessage
2019-06-17 21:56:56.517 Error: (Zigate) ----> Line 384 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function processFrame
2019-06-17 21:56:56.517 Error: (Zigate) ----> Line 437 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function receiveStatusCmd
2019-06-17 21:56:56.517 Error: (Zigate) ----> Line 348 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function sendData
2019-06-17 21:56:56.517 Error: (Zigate) ----> Line 180 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function _sendData
2019-06-17 21:56:56.517 Error: (Zigate) ----> Line 101 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/APS.py', function processCMD
2019-06-17 21:56:56.517 Error: (Zigate) ----> Line 87 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/APS.py', function _addNewCmdtoDevice
2019-06-17 21:56:57.233 Error: (Zigate) 'onMessage' failed 'AttributeError':''dict' object has no attribute 'append''.
2019-06-17 21:56:57.233 Error: (Zigate) ----> Line 764 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onMessage
2019-06-17 21:56:57.233 Error: (Zigate) ----> Line 466 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onMessage
2019-06-17 21:56:57.233 Error: (Zigate) ----> Line 256 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function onMessage
2019-06-17 21:56:57.233 Error: (Zigate) ----> Line 391 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function processFrame
2019-06-17 21:56:57.233 Error: (Zigate) ----> Line 411 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function receiveDataCmd
2019-06-17 21:56:57.233 Error: (Zigate) ----> Line 348 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function sendData
2019-06-17 21:56:57.233 Error: (Zigate) ----> Line 180 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function _sendData
2019-06-17 21:56:57.233 Error: (Zigate) ----> Line 101 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/APS.py', function processCMD
2019-06-17 21:56:57.233 Error: (Zigate) ----> Line 87 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/APS.py', function _addNewCmdtoDevice
2019-06-17 21:56:57.338 Error: (Zigate) 'onMessage' failed 'AttributeError':''dict' object has no attribute 'append''.
2019-06-17 21:56:57.339 Error: (Zigate) ----> Line 764 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onMessage
2019-06-17 21:56:57.339 Error: (Zigate) ----> Line 466 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onMessage
2019-06-17 21:56:57.339 Error: (Zigate) ----> Line 256 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function onMessage
2019-06-17 21:56:57.339 Error: (Zigate) ----> Line 384 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function processFrame
2019-06-17 21:56:57.339 Error: (Zigate) ----> Line 437 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function receiveStatusCmd
2019-06-17 21:56:57.339 Error: (Zigate) ----> Line 348 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function sendData
2019-06-17 21:56:57.339 Error: (Zigate) ----> Line 180 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/Transport.py', function _sendData
2019-06-17 21:56:57.339 Error: (Zigate) ----> Line 101 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/APS.py', function processCMD
2019-06-17 21:56:57.339 Error: (Zigate) ----> Line 87 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Classes/APS.py', function _addNewCmdtoDevice
