Local variable not recognized?
Posted: Saturday 15 June 2019 8:30
All I try to use the within_min() command and use a local variable at the beginning of the script.
But there is always this log that the Value is "a nil value" it seems the local variable is not recognized.
Someone any idea how to solve this? See script and log below.
local RANDOM_DELAY_MINS = 20
on = { timer = { 'at nighttime at 07:00 on mon, tue, wed, thu, fri',
'at nighttime at 08:20 on sat, sun',
'at sunrise',
'at sunset',
'at 15 minutes before sunset',
'at 22:00 at nighttime on mon, tue, wed, thu, fri, sat, sun',
'at 23:15' }
-- timer = { 'at sunrise' },
-- timer = { 'at 23:00 at nighttime on mon, tue, wed, thu, fri, sat, sun'}
execute = function(domoticz, timer)
domoticz.log(timer.trigger)
if (domoticz.time.matchesRule('at 07:00')) then
domoticz.log('Dit werkt om 7:00 uur')
domoticz.groups('Binnen-Lampen').switchOn().repeatAfterSec(1,3)
elseif (domoticz.time.matchesRule('at 08:20')) then
domoticz.log('Dit werkt om 8:20 uur op Zaterdag en Zondag')
elseif (domoticz.time.matchesRule('at sunrise')) then
domoticz.log('Zonsopkomst')
domoticz.groups('Binnen-Lampen').switchOff().repeatAfterSec(1,3)
elseif (domoticz.time.matchesRule('at 15 minutes before sunset') and domoticz.time.matchesRule('at 00:00-23:00')) then
domoticz.log('15 minuten voor Zonsondergang')
elseif (domoticz.time.matchesRule('at 23:15') and domoticz.devices('$Hulp-Laat-Thuis').state == 'Off') then
domoticz.log('Slaaplekker')
domoticz.groups('Binnen-Lampen').switchOff().within_min(RANDOM_DELAY_MINS)
domoticz.groups('Binnen-Lampen').switchOff().aftermin('30')
domoticz.log('Slaaplekkerrrrrr binnen')
}Code: Select all
2019-06-14 23:15:00.611 Status: dzVents: Error (2.4.19): An error occured when calling event handler DZ_SfeerVerlichtingBinnen
2019-06-14 23:15:00.611 Status: dzVents: Error (2.4.19): .../dzVents/generated_scripts/DZ_SfeerVerlichtingBinnen.lua:30: attempt to call field 'within_min' (a nil value)
2019-06-14 23:15:00.611 Status: dzVents: Info: ------ Finished DZ_SfeerVerlichtingBinnen
2019-06-14 23:15:00.612 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
