Lucci Airfusion Climate II DC Ceiling fan
Posted: Friday 14 June 2019 23:14
by zuluman
I got myself a Lucci airfusion climate II DC ceiling fan. Initially i thought the fan would work in domoticz. i found out this is not so. The fan doesnt respond. i tried all settings as mentioned in another tread. i even tried learning the commands but domoticz fails to recognize the signal.
After contact with the RFXCOM helpdesk i got the fan working with the RFXmngr in windows 10. the fan has 6 speeds, a reverse and a light function.
The RFXCOM helpdesk suggested that i should make a request to have the fan added to domoticz.
This is my first request and i hope i have supplied sufficient information for such a request.
Re: Lucci Airfusion Climate II DC Ceiling fan
Posted: Friday 19 June 2020 19:15
by solarboy
I also have this fan, very efficient 5W on minimum. I read it was compatible with Domoticz somewhere but I haven't tried yet myself.
Posted: Wednesday 11 November 2020 20:48
by solarboy
I have just received an RFXtrx433E which is able to control the fan, however this is not implemented in Domoticz, only the earlier 2 Lucci fans have been implemented. From what I can tell there are no platforms that can control this fan, asides from Rfmgr. I have also noticed there is very minimal documentation for RFXcom, some articles reference a Vesternet page that is no longer available. There is not even a guide to install RFXcom and add switches anywhere I can find, which seems odd as I was led to believe this is the origin of Domoticz.
Posted: Wednesday 11 November 2020 23:35
by FireWizard
Hi, @solarboy
If you go to the RFXCom website, you will find more than sufficient information of the products.
See: http://www.rfxcom.com/epages/78165469.s ... /Downloads
You can also try, if Node Red supports it.
See: https://flows.nodered.org/node/node-red-contrib-rfxcom
Posted: Thursday 12 November 2020 17:44
by solarboy
Hi Firewizard, thanks for your reply, I was more referring to Domoticz+RFXcom information. I will certainly check out this node red stuff, I haven't known of it until now, thanks.
