attempt to index local 'variable' (a number value)  [Solved]
imdos
Domoticz version: 2023.2
Post by imdos »
wii charger if last seen more than 5 days ago, then turn on for 1 hour.
If wii is turned off; then turn on for 2 hours.
wii heet Wii en heeft IDX: 62
wii charger heet Wii-charger en heeft IDX: 63
      timer = { 'at 00:58' },
      -- wii heet Wii en heeft IDX: 62
      devices = { 'Wii' }
             logging =   {
                        level   =   domoticz.LOG_ERROR,    -- change to LOG_ERROR when script executes OK
                        marker  =   wii_charger,
        local charger = domoticz.devices('Wii-charger')
        local wii = domoticz.devices('Wii')
        -- local wii = 62
      if (item.isTimer) then
			-- denkfout! De Wii-charger gaat elke nacht uit ivm scheduled task
			-- if (charger.lastUpdate.daysAgo > 4) then
			-- dit zou moeten werken
			if (wii.lastUpdate.daysAgo > 4) then
					charger.switchOn()
					-- force an update otherways it will trigger each following night.
					wii.switchOff().silent()
      elseif (item.isDevice and not item.active) then
         -- do charge if (wii.state == 'Off')
                charger.switchOn().forHour(2)
         -- end
This is the output from the IDX. It should start charging. But instead I get this error.
/var/log/domoticz/domoticz.log.11:2019-06-11 00:58:00.357 Status: dzVents: Error (2.4.22): An error occured when calling event handler wii
/var/log/domoticz/domoticz.log.11:2019-06-11 00:58:00.357 Status: dzVents: Error (2.4.22): /domoticz/scripts/dzVents/scripts/wii.lua:25: attempt to index local 'wii' (a number value)
line 25 is equal to: "if (wii.lastUpdate.daysAgo > 4) then"
However I don't see a difference with the second example underneath the link to the wiki.
Copied it here for a reference.
         if (domoticz.devices('My PIR').lastUpdate.minutesAgo > 5) then
                domoticz.devices('Bathroom lights').switchOff()
curl "http://127.0.0.1:8080/json.htm?type=devices&rid=62"
   "ActTime" : 1560448733,
   "AstrTwilightEnd" : "00:00",
   "AstrTwilightStart" : "00:00",
   "CivTwilightEnd" : "22:49",
   "CivTwilightStart" : "04:31",
   "DayLength" : "16:41",
   "NautTwilightEnd" : "00:06",
   "NautTwilightStart" : "03:14",
   "ServerTime" : "2019-06-13 19:58:53",
   "SunAtSouth" : "13:40",
   "Sunrise" : "05:19",
   "Sunset" : "22:00",
   "app_version" : "4.10856",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "DimmerType" : "none",
         "Favorite" : 1,
         "HardwareID" : 4,
         "HardwareName" : "Dummy",
         "HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
         "HardwareTypeVal" : 15,
         "HaveDimmer" : true,
         "HaveGroupCmd" : true,
         "HaveTimeout" : false,
         "ID" : "00014129",
         "Image" : "Light",
         "IsSubDevice" : false,
         "LastUpdate" : "2019-05-24 17:21:07",
         "Level" : 0,
         "LevelInt" : 0,
         "MaxDimLevel" : 100,
         "Name" : "Wii",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "Switch",
         "SwitchType" : "On/Off",
         "SwitchTypeVal" : 0,
         "Timers" : "false",
         "Type" : "Light/Switch",
         "TypeImg" : "lightbulb",
         "Unit" : 1,
         "Used" : 1,
         "UsedByCamera" : false,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "62"
   "status" : "OK",
   "title" : "Devices"
Making use of: Raspbian(SSD), dz Beta, Woonveilig, Z-Wave(alarm+multi-sensor), RFLink(blinds), P1, Yeelight, Xiaomi temp sensors, Tasmota(SonoFF, Blitzwolf SHP2, Shelly1)
Re: attempt to index local 'variable' (a number value)
imdos wrote: Thursday 13 June 2019 20:30 This is the output from the IDX. It should start charging. But instead I get this error.
I don't see anything fundamentally wrong in your script. Only real issue is that you did not use quotes around the marker string.
Can you check this ?
return
    on =
        timer = { 'at 00:32' },
        devices = { 'Wii' }
    logging =
        level   =   domoticz.LOG_DEBUG,    -- change to LOG_ERROR when script executes OK
        marker  =   'wii charger',
        local wii = domoticz.devices('Wii')  -- local wii = 62
        if item.isTimer and wii.lastUpdate.daysAgo > 4  then
            charger.switchOn().checkFirst().forHour(2)
            wii.switchOff().silent()        -- force an update otherwise it will trigger each following night.
        elseif item.isDevice
imdos
Post by imdos »
2019-06-14 10:20:00.554  Status: dzVents: Info:  wii charger: ------ Start external script: wii.lua:, trigger: at 10:20
2019-06-14 10:20:00.579  Status: dzVents: Debug: wii charger: Processing device-adapter for Wii-charger: Switch device adapter
2019-06-14 10:20:00.581  Status: dzVents: Debug: wii charger: Processing device-adapter for Wii: Switch device adapter
2019-06-14 10:20:00.581  Status: dzVents: Info:  wii charger: ------ Finished wii.lua
Hi waaren,
It worked out. Strange thing is that I must have changed something in between since I didn't get an error message, last night.
I first thought there is something wrong with your addition of the script since the wii is updated but it doesn't start charging.
But while inspecting the logs from yesterday:
2019-06-14 00:58:00.343  (Dummy) Light/Switch (Wii-charger)
2019-06-14 00:58:00.354  (Dummy) Light/Switch (Wii)
2019-06-14 02:00:01.584  Status: Schedule item started! Name: Wii-charger, Type: On Time, DevID: 63, Time: 2019-06-14 02:00:01
2019-06-14 02:00:01.594  (Dummy) Light/Switch (Wii-charger)
And the IDX
         "LastUpdate" : "2019-06-14 00:58:00",
         "Name" : "Wii",
"LastUpdate" : "2019-06-14 02:00:01",
"Name" : "Wii-charger",
It worked out perfectly.
imdos
Post by imdos »
Have an update question about this code. I have too many false charges due to the sonoff which sends it's status. Therefore I modified my script to check whether a boolean has been set
https://www.domoticz.com/forum/viewtopic.php?f=71&p=217143
https://www.domoticz.com/forum/viewtopic.php?f=59&t=28730&p=219525&hilit=Nintendo#p219525
return
    on =
        devices = { 62 } -- 'Wii' }
    logging =
--        level   =   domoticz.LOG_ERROR,    -- change to LOG_ERROR when script executes OK
        local charger = domoticz.devices(63) -- 'Wii-charger')
        -- local wii = domoticz.devices(62) -- 'Wii')  -- local wii = 62
        -- variabele om constant opladen te voorkomen.
        local wiion = false
        if (item.isTimer and wii.lastUpdate.daysAgo > 4 )  then
			    domoticz.log('Charging the Wii controllers periodically',domoticz.LOG_FORCE)
        elseif (item.isDevice and item.active) then
             wiion = true
        elseif (item.isDevice and wiion and not item.active) then
             wiion = false
			     domoticz.log('Charging the Wii controllers after usage',domoticz.LOG_FORCE)
And the error
2019-12-10 20:01:30.256  Status: dzVents: Debug: wii charger: Processing device-adapter for Wii-charger: Switch device adapter
2019-12-10 20:01:30.257  Error: dzVents: Error: (2.4.29) wii charger: An error occurred when calling event handler wii
2019-12-10 20:01:30.257  Error: dzVents: Error: (2.4.29) wii charger: /domoticz/scripts/dzVents/scripts/wii.lua:29: attempt to concatenate global 'wiion' (a nil value)
2019-12-10 20:01:30.257  Status: dzVents: Info: wii charger: ------ Finished wii.lua
imdos wrote: Tuesday 10 December 2019 20:20 Have an update question about this code. I have too many false charges due to the sonoff which sends it's status. Therefore I modified my script to check whether a boolean has been set
And the error
Are you sure you show us the same script that produced this error? Line 29 of this script cannot have this error because line 29 does not contain code that concatenates anything. (local wiion = false -- is not a concatenation)
You also commented the declaration of the wii as domoticz.devices(62)in line 27, but still try switching it off in line 33. That will not work
Please understand that the value of the wiion variable is not persistent over multiple executions of this script. No script variables are kept after the script finished. If you want to keep variable content over different runs of a script have a look at the persistent data section of the dzVents wiki
imdos
Re: attempt to index local 'variable' (a number value)  [Solved]
Post by imdos »
waaren wrote: Tuesday 10 December 2019 20:49 Are you sure you show us the same script that produced this error? Line 29 of this script cannot have this error because line 29 does not contain code that concatenates anything. (local wiion = false -- is not a concatenation)
You're absolutely correct. I had adjusted the script already a bit. Have fixed both items and did a data section; but I get no charging event started.
waaren wrote: Tuesday 10 December 2019 20:49 Please understand that the value of the wiion variable is not persistent over multiple executions of this script. No script variables are kept after the script finished. If you want to keep variable content over different runs of a script have a look at the persistent data section of the dzVents wiki
This is the current version, with the persistent data added.
return
    on =
    data = { wiion = { initial = false } },
    logging =
    --   level   =   domoticz.LOG_DEBUG,
        local wiion = false
             wiion = true
             wiion = false
But I found out that I had another issue, which is why I had to make the system foolproof. I get sudden reboots (and thus power restore settings) due to what appears a failed flash update of a Sonoff Basic.
But I guess I have found the error myself. I declare the value at the top (line 17), and on each run on line 29 I overwrite the setting with the same value. Thereby overwriting what would be set on line 34/35 which is the correct value.
imdos
Post by imdos »
Damn; I thought I had solved my problem. But it still doesn't work exactly. I must be doing something wrong with the persistent data. Could someone have a look.
https://www.domoticz.com/forum/viewtopic.php?f=59&t=28730&p=219525&hilit=Nintendo#p219525       <-- variabele
https://www.domoticz.com/forum/viewtopic.php?f=59&t=28347&p=230959#p230959                      <-- error debugged
return
    on =
    logging =
        -- local wiion = false --'wordt nu in regel 17 gezet als persistent value.
        if (wiion == true ) then domoticz.log('wiion variabele is: True') else domoticz.log('wiion variabele is: False') end
             wiion = true
                domoticz.log('wiion is waar')
             wiion = false
                domoticz.notify('Wii', 'Charging the Wii controllers after usage', domoticz.PRIORITY_NORMAL, domoticz.SOUND_NONE, nil,domoticz.NSS_PUSHOVER)
I have tested turning On and then Off and this produces the following log:
2019-12-20 10:20:05.797  Status: User: Admin initiated a switch command (62/Wii/On)
2019-12-20 10:20:05.804  (Dummy) Light/Switch (Wii)
2019-12-20 10:20:05.938  Status: dzVents: Info: Handling events for: "Wii", value: "On"
2019-12-20 10:20:05.941  Status: dzVents: Info: wii charger: ------ Start external script: wii.lua: Device: "Wii (Dummy)", Index: 62
2019-12-20 10:20:05.942  Status: dzVents: Debug: wii charger: Processing device-adapter for Wii-charger: Switch device adapter
2019-12-20 10:20:05.943  Status: dzVents: Info: wii charger: wiion variabele is: False
2019-12-20 10:20:05.943  Status: dzVents: Info: wii charger: wiion is waar
2019-12-20 10:20:05.943  Status: dzVents: Info: wii charger: ------ Finished wii.lua
2019-12-20 10:20:38.971  Status: User: Admin initiated a switch command (62/Wii/Off)
2019-12-20 10:20:38.976  (Dummy) Light/Switch (Wii)
2019-12-20 10:20:39.102  Status: dzVents: Info: Handling events for: "Wii", value: "Off"
2019-12-20 10:20:39.104  Status: dzVents: Info: wii charger: ------ Start external script: wii.lua: Device: "Wii (Dummy)", Index: 62
2019-12-20 10:20:39.105  Status: dzVents: Debug: wii charger: Processing device-adapter for Wii-charger: Switch device adapter
2019-12-20 10:20:39.105  Status: dzVents: Info: wii charger: wiion variabele is: False
2019-12-20 10:20:39.106  Status: dzVents: Info: wii charger: ------ Finished wii.lua
imdos wrote: Friday 20 December 2019 10:38 Damn; I thought I had solved my problem. But it still doesn't work exactly. I must be doing something wrong with the persistent data. Could someone have a look.
If you read from or write to persistent data you need to be aware that persistent variables only exist in domoticz.data. So in your case use domoticz.data.wiion
return
    on =
    logging =
        -- Persistent var om constant opladen te voorkomen.
        if domoticz.data.wiion == true then
             domoticz.data.wiion = true
             domoticz.log('Persistent wiion set to true', domoticz.LOG_DEBUG)
        elseif (item.isDevice and domoticz.data.wiion == true and not(item.active)) then
             domoticz.data.wiion = false
[/quote]
imdos
Post by imdos »
Thanks as always waaren and happy Christmas!
