Splitting up P1 meter [Solved]  [Solved]
gielie
Domoticz version: latest β
Post by gielie »
Im looking for a way to split up my P1 meter in used and recieved (from solar).
This is the output from the P1 device.
   "ActTime" : 1559633492,
   "AstrTwilightEnd" : "00:00",
   "AstrTwilightStart" : "00:00",
   "CivTwilightEnd" : "22:46",
   "CivTwilightStart" : "04:33",
   "DayLength" : "16:36",
   "NautTwilightEnd" : "00:02",
   "NautTwilightStart" : "03:16",
   "ServerTime" : "2019-06-04 09:31:32",
   "SunAtSouth" : "13:39",
   "Sunrise" : "05:21",
   "Sunset" : "21:57",
   "app_version" : "4.10854",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "Counter" : "11640.097",
         "CounterDeliv" : "159.898",
         "CounterDelivToday" : "0.024 kWh",
         "CounterToday" : "3.398 kWh",
         "CustomImage" : 0,
         "Data" : "5951794;5688303;41891;118007;297;0;",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 14,
         "HardwareName" : "Toon2",
         "HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
         "HardwareTypeVal" : 15,
         "HaveTimeout" : false,
         "ID" : "1459F",
         "LastUpdate" : "2019-06-04 09:31:01",
         "Name" : "Stroom 2",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "SubType" : "Energy",
         "SwitchTypeVal" : 0,
         "Timers" : "false",
         "Type" : "P1 Smart Meter",
         "TypeImg" : "counter",
         "Unit" : 1,
         "Usage" : "297 Watt",
         "UsageDeliv" : "0 Watt",
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "1359"
   "status" : "OK",
   "title" : "Devices"
i tried some dzvents script but i cant get to work, so the idea is to create 2 dummy meters with the data from the P1 splitted into used and recieve.
Any help is much appreciated.
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
freijn
Domoticz version: Stable
Re: Splitting up P1 meter
Post by freijn »
Not sure what version you are running, this is standard output in my version 4.10717.
Re: Splitting up P1 meter  [Solved]
gielie wrote: Tuesday 04 June 2019 11:12 I'm looking for a way to split up my P1 meter in used and received (from solar).
In it's most simple form
return
    on = { devices = { 'Power' }}, -- 'name' or id  of your P1 device
    logging = {level = domoticz.LOG_ERROR, marker = P1Splitter },
    execute = function(dz,item)
        local p1Delivery = dz.devices(2085) -- 'name' or id of your virtual P1 for delivery to the grid
        local p1Usage = dz.devices('Usage') -- 'name' or id of your virtual P1 for usage
        p1Delivery.updateP1(item.return1, item.return2, 0, 0,  item.usageDelivered, 0)
        p1Usage.updateP1(item.usage1, item.usage2, 0, 0, item.usage, 0)
gielie
Post by gielie »
waaren wrote: Tuesday 04 June 2019 12:49
return
Tnks a lott, this works like a charm and i learned some dzvents scripting.
- FIBARO FGS223
- Toon
- Kodi Media Server
marigo
Post by marigo »
What kind of virtual device did you added to your configuration? I have now added the virtual "slimme meter elektra" and used this script, but I get an error. I want only to make usage of the current delivery
2019-06-13 19:48:39.163 Status: dzVents: Info: Handling events for: "P1 power usage", value: "9184621;10783590;400724;816877;0;30"
2019-06-13 19:48:39.163 Status: dzVents: Error (2.4.19): An error occured when calling event handler delivery
2019-06-13 19:48:39.164 Status: dzVents: Error (2.4.19): .../domoticz/scripts/dzVents/generated_scripts/delivery.lua:11: attempt to call field 'updateP1' (a nil value)
I am new to dzvents but I think I am missing something simple.
I have used only the delivery lines of the script:
return
    on = { devices = { 'P1 power usage' }}, -- 'name' or id  of your P1 device
        local p1Delivery = dz.devices(82475) -- 'name' or id of your virtual P1 for delivery to the grid
Can someone see what's wrong here?
marigo wrote: Thursday 13 June 2019 20:00 What kind of virtual device did you added to your configuration? I have now added the virtual "slimme meter elektra" and used this script, but I get an error. I want only to make usage of the current delivery
The P1 device you defined should work. Can you please double check the device idx. the number you used (82475) seems very high.
marigo
Post by marigo »
Changed the id to idx, but the log tells me it can't understand the "updatep1" parameter.
After changing "name of your target device" to the actual name you have for your target device (keep the quotes), can you please run this one and report back the results from the logfile ? That might help in finding the problem.
return
        local p1Delivery = dz.devices("name of your target device")
        p1Delivery.dump()
marigo
Post by marigo »
That's odd. This seems to work immediately. Now the dummy gets updated with the power delivery from the root "P1 power usage".
Great, thank you very much.
The script seems to be triggerd every 10 seconds. I have comment out the .dump. It was filling up my logfile.
marigo wrote: Friday 14 June 2019 9:39 That's odd. This seems to work immediately. Now the dummy gets updated with the power delivery from the root "P1 power usage".
👍 Great ! Likely that the device number was wrong or entered using quotes ?
Good; this was only needed during debug to identify what device was referenced.
marigo
Post by marigo »
I have now entered only the idx (without qoutes) instead of the name of the virtual device and it is also working.
In the first place I had entered the "ID" of the virtual device. (some hex number)
It's working perfectly.
Thanks.
marktn
Post by marktn »
I have 2 device that i like to split to a separate device, a P1 meter and one of the solar panels.
The P1 device, is a Toon thermostaat,
CounterDelivToday "2.592 kWh"
CounterToday "7.710 kWh"
Solar Panels,
CounterToday "10.669 kWh"
How to do that?
regards,
Mark
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
marktn wrote: Friday 06 October 2023 19:13 Hi,
Solar Panels,
How to do that?
regards,
Mark
What do exactly want to achieve?
Because a P1 device already shows returned energy to the grid.
And your solar panels already show the produced energy.
marktn
Post by marktn »
I want it separate in my dashboard, if possible.
For the P1 splitting usage and delivery the script and instructions are in this topic.
For the solar production you just put it on your dashboard. Or am I missing something here?
marktn
Post by marktn »
waltervl wrote: Friday 06 October 2023 22:48 For the P1 splitting usage and delivery the script and instructions are in this topic.
I don't have any expierence with dzevents... sorry. The most is done in node red.
For the Solar i need to make a seperate script.
return
on = { devices = { 'Toon Stroomverbruik' }}, -- 'name' or id of your P1 device
local CounterDelivToday = dz.devices('Toon stroomverbruik vandaag') -- 'name' or id of your virtual P1 for delivery to the grid
local CounterToday = dz.devices('Toon teruglevering vandaag') -- 'name' or id of your virtual P1 for usage
CounterDelivToday.updateP1(item.return1, item.return2, 0, 0, item.usageDelivered, 0)
CounterToday.updateP1(item.usage1, item.usage2, 0, 0, item.usage, 0)
that gives this error,
2023-10-07 14:44:48.233 Error: dzVents: Error: (3.1.8) Method updateP1 is not available for device "Toon stroomverbruik vandaag" (deviceType=General, deviceSubType=Managed Counter). If you believe this is not correct, please report.
You probably can do this too in node red....but I have 0 experience with this.
Edit: you have made new counter devices instead of P1 devices.
PierreT
Post by PierreT »
@marktn
Necroposting is a really bad habit, especially if you are raising a problem in a topic that is already marked as solved.
On your issue, I really have no clue what you are aiming to accomplish. Only thing that seems interesting is to create a virtual counter that shows net usage, i.e. usage P1 + the difference between solar input and P1 return. However, as far as I understand your script you are attempting to insert a multi-value into a singular meter. That doesn't work for obvious reasons, you need to extract the one value you require from the multi-value (there are actually two - one for each tariff - that you'll need to add together) and push that to your virtual device.
RonkA
Domoticz version: 2025.1
Post by RonkA »
Is this what you want?
    logging = {
        marker = "P1Splitter"
        devices = {
    execute = function(dz, item)
        local Verbruik = dz.devices('Toon Stroomverbruik').counterToday
        local Teruglevering = dz.devices('Toon stroomverbruik').counterDeliveredToday
        dz.devices('Toon stroomverbruik vandaag').updateCounter(Verbruik)
        dz.devices('Toon teruglevering vandaag').updateCounter(Teruglevering)
SolarEdge ModbusTCP - Kaku - Synology NAS - Watermeter - ESPEasy - DS18b20
Work in progress = Life in general..
