Hi, here is my plugin. I'm sure its not pretty but it works!
Copy it into a folder in your plugins directory, restart domoticz and see how you go.
# Basic Python Plugin Example
# Author: GizMoCuz
<plugin key="BasePlug" name="IntesisBox WMP-1 Protocol" author="CV8R" version="0.0.9" >
<description>
<h2>IntesisBox WMP-1</h2><br/>
<ul style="list-style-type:square">
<li>IntesisBox WMP-1 interface for air conditioners into IP based control systems</li>
</ul>
<h3>Configuration</h3><br/>
<li>IP Address and Port number default 3310 </li>
</ul>
</description>
<params>
<param field="Address" label="IP Address" width="200px" required="true" default=""/>
<param field="Port" label="Port" width="30px" required="true" default="3310"/>
<param field="Mode1" label="Debug" width="75px">
<options>
<option label="True" value="Debug"/>
<option label="False" value="Normal" default="true" />
</options>
</param>
</params>
</plugin>
from typing import List
# Global var definitions
InitHeartbeatCount = 0
unitmode = "N/A"
oustandingPings = -1
lastHeartbeat = 0
# Limits as Global vars
minTempLimit = 180
maxTempLimit = 280
import Domoticz
import base64
import datetime
import re
class BasePlugin:
enabled = True
powerOn = 0
runCounter = 0
WMPConn = None
oustandingPings = 0
lastHeartbeat = datetime.datetime.now()
def __init__(self):
#self.var = 123
return
def onStart(self):
Domoticz.Log("onStart called")
Domoticz.Heartbeat(20) # Set heartbeat interval slower than default
if Parameters["Mode1"] == "Debug":
Domoticz.Debugging(1)
if (len(Devices) == 0):
Domoticz.Device(Name="Power", Unit=1, Image=16, TypeName="Switch", Used=1).Create()
Domoticz.Device(Name="Ambient Temp", Unit=2, TypeName="Temperature", Used=1).Create()
Options = {"LevelActions" : "|||||",
"LevelNames" : "|Auto|Heat|Dry|Cool|Fan",
"LevelOffHidden" : "true",
"SelectorStyle" : "0"}
Domoticz.Device(Name="Mode", Unit=3, TypeName="Selector Switch", Image=16, Options=Options, Used=1).Create()
Options = {"LevelActions" : "||||",
"LevelNames" : "|Auto|L1|L2|L3",
Domoticz.Device(Name="Fan Speed", Unit=4, TypeName="Selector Switch", Image=7, Options=Options, Used=1).Create()
Domoticz.Device(Name="Set Temp", Unit=5, Type=242, Subtype=1, Image=16, Used=1).Create()
Domoticz.Device(Name="Error LED", Unit=6, Image=13, TypeName="Switch", Used=1).Create()
Domoticz.Device(Name="Error Text", Unit=7, TypeName="Text", Used=1).Create()
Domoticz.Log("Device created.")
DumpConfigToLog()
def onStop(self):
Domoticz.Log("onStop called")
def onConnect(self, Connection, Status, Description):
Domoticz.Log("onConnect called")
global ConnectState
Domoticz.Log("Connecting")
if (Connection == self.WMPConn):
if (Status == 0):
Domoticz.Log("Connected successfully to: " + Connection.Address + ":" + Connection.Port)
self.WMPConn.Send('ID\n') # Get ID at startup
else:
if (Description.find("Only one usage of each socket address") > 0):
Domoticz.Log(Connection.Address + ":" + Connection.Port + " is busy, waiting.")
else:
Domoticz.Log("Failed to connect (" + str(Status) + ") to: " + Connection.Address + ":" + Connection.Port + " with error: " + Description)
self.WMPConn = None
def onMessage(self, Connection, Data):
Domoticz.Debug("onMessage called")
global unitmode
global oustandingPings
global lastHeartbeat
global minTempLimit
global maxTempLimit
strData = Data.decode("utf-8", "ignore")
Domoticz.Debug("onMessage called with Data: '" + str(strData) + "'")
#msgDataListRaw = re.split(r':+|,', strData) # type: List[str]
msgDataListRaw = re.split(r':+|,+|\[+|\]', strData) # split string to list of strings
msgDataList = list(filter(None, msgDataListRaw)) # Remove consecutive delimiters note: filter does not return a list, use list to turn into list
# Dump stripped messages in to Domoticz Log
count = 0
for msgData in msgDataList:
Domoticz.Debug("Stripped Message[" + str(count) + "] = " + msgData ) # Log the messages incoming and their stripped count
count = count + 1
Domoticz.Debug("Resetting Ping to 0")
oustandingPings = 0 # Reset ping counter onmessage for making sure connection is up in Heartbeat
# Is it a status update
if (msgDataList[0] == 'ACK'):
Domoticz.Debug("Message Acknowledged with response: " + msgDataList[0])
elif (msgDataList[0] == 'ERR'):
Domoticz.Error("WMP Message ########## SENDING MESSAGE ERROR ########## with response: " + msgDataList[0])
Devices[6].Update(nValue=1, sValue="100") # Set the Error LED switch to ON to flag for a send error
elif (msgDataList[0] == 'LIMITS'): #Get the limits from the AC unit
DataValues = '|'.join(msgDataList[2:])
if (msgDataList[1] == 'ONOFF'): #Get the ONOFF limits from the AC unit
Domoticz.Log("ONOFF Limits from unit: " + DataValues)
elif (msgDataList[1] == 'MODE'): #Get the MODE limits from the AC unit
Domoticz.Log("MODE Limits from unit: " + DataValues)
elif (msgDataList[1] == 'FANSP'): #Get the FANSP limits from the AC unit
Domoticz.Log("FANSP Limits from unit: " + DataValues)
elif (msgDataList[1] == 'VANEUD'): #Get the VANEUD limits from the AC unit
Domoticz.Log("VANEUD Limits from unit: " + DataValues)
elif (msgDataList[1] == 'VANELR'): #Get the VANELR limits from the AC unit
Domoticz.Log("VANELR Limits from unit: " + DataValues)
elif (msgDataList[1] == 'SETPTEMP'): #Get the SETPTEMP temp limits from the AC unit
Domoticz.Debug("SETPTEMP Temp limit values from unit: " + DataValues)
minTempLimit = int(msgDataList[2])
maxTempLimit = int(msgDataList[3])
Domoticz.Status("Min Temp Limit: " + str(minTempLimit) + " Max Temp Limit: " + str(maxTempLimit))
if (msgDataList[0] == 'CHN'):
Domoticz.Debug("Status Update - Unit: " + msgDataList[1] + " Function: " + msgDataList[2] + " Value = " + msgDataList[3])
# Update the status to Domoticz
if (msgDataList[2] == 'ONOFF'):
if (msgDataList[3] == 'ON'):
Domoticz.Status("Update status to On")
Devices[1].Update(nValue=1, sValue="100") # AC Power
elif (msgDataList[3] == 'OFF'):
Domoticz.Status("Update status to Off")
Devices[1].Update(nValue=0, sValue="0")
elif (msgDataList[2] == 'AMBTEMP'):
ambtemp = str(float(msgDataList[3])/10)
Domoticz.Log("Ambient temp")
Domoticz.Debug("Current ambient temp: " + ambtemp + " Degrees")
Devices[2].Update(nValue=0, sValue=ambtemp)
#Domoticz.Debug("Resetting Ping to 0") # using AMBTEMP
#oustandingPings = 0 # Reset ping counter for making sure connection is up in Heartbeat
elif (msgDataList[2] == 'SETPTEMP'):
settemp = str(int(msgDataList[3])/10)
if (unitmode != 'FAN'):
Domoticz.Status("Set temp is set to: " + settemp + " Degrees")
Devices[5].Update(nValue=1, sValue=settemp) # Update the temp display in the set temp device
else:
Domoticz.Debug("FAN MODE setting temp to not display")
Devices[5].Update(nValue=1, sValue="22") # N/A to have a temp displayed
elif (msgDataList[2] == 'MODE'):
unitmode = msgDataList[3]
if (unitmode == "AUTO"):
Domoticz.Status("Mode to: " + unitmode)
Devices[3].Update(nValue=1, sValue="10") # Auto
elif (unitmode == "HEAT"):
Devices[3].Update(nValue=1, sValue="20") # Heat
elif (unitmode == "DRY"):
Devices[3].Update(nValue=1, sValue="30") # Dry
elif (unitmode == "COOL"):
Devices[3].Update(nValue=1, sValue="40") # Cool
elif (unitmode == "FAN"):
Devices[3].Update(nValue=1, sValue="50") # Fan
Devices[3].Refresh()
elif (msgDataList[2] == 'FANSP'):
fspeed = msgDataList[3]
if (fspeed == "AUTO"):
Domoticz.Status("Fan Speed to: " + fspeed)
Devices[4].Update(nValue=1, sValue="10") # Fan Auto
elif (fspeed == "1"):
Devices[4].Update(nValue=1, sValue="20") # Fan Level 1
elif (fspeed == "2"):
Devices[4].Update(nValue=1, sValue="30") # Fan Level 2
elif (fspeed == "3"):
Devices[4].Update(nValue=1, sValue="40") # Fan Level 3
Devices[4].Refresh()
elif (msgDataList[2] == 'VANEUD'):
vaneud = msgDataList[3]
Domoticz.Status("Vane Up/Down: " + vaneud)
elif (msgDataList[2] == 'VANELR'):
vanelr = msgDataList[3]
Domoticz.Status("Vane Left/Right: " + vanelr)
elif (msgDataList[2] == 'ERRSTATUS'):
errorstatus = msgDataList[3]
if (errorstatus != "OK"):
Domoticz.Status("Error Status: " + errorstatus)
Devices[6].Update(nValue=1, sValue="100") # Set the Error LED switch to ON to flag for an ERROR
elif (errorstatus == "OK"):
Devices[6].Update(nValue=0, sValue="0") # Set the Error LED switch to OFF to clear ERROR
elif (msgDataList[2] == 'ERRCODE'):
errorcode = msgDataList[3]
Domoticz.Status("Error Code: " + errorcode)
Devices[7].Update(nValue=1, sValue=errorcode) # Set error text
else:
Domoticz.Error("Unrecognised status command")
def onCommand(self, Unit, Command, Level, Hue):
Domoticz.Log("onCommand called for Unit " + str(Unit) + ": Parameter '" + str(Command) + "', Level: " + str(Level))
if (Unit == 1):
if (Command == "On"):
Domoticz.Status("Sending Power ON")
self.powerOn = 1
self.WMPConn.Send('SET,1:ONOFF,ON\n')
elif(Command == "Off"):
Domoticz.Status("Sending Power OFF")
self.powerOn = 0
self.WMPConn.Send('SET,1:ONOFF,OFF\n')
elif (Unit == 3):
if (Command == "Set Level"):
Domoticz.Debug("Sending Mode")
if (str(Level) == '10'):
Domoticz.Status("Sending Mode Auto")
self.WMPConn.Send('SET,1:MODE,auto\n')
elif (str(Level) == '20'):
Domoticz.Status("Sending Mode Heat")
self.WMPConn.Send('SET,1:MODE,heat\n')
elif (str(Level) == '30'):
Domoticz.Status("Sending Mode Dry")
self.WMPConn.Send('SET,1:MODE,dry\n')
elif (str(Level) == '40'):
Domoticz.Status("Sending Mode Cool")
self.WMPConn.Send('SET,1:MODE,cool\n')
elif (str(Level) == '50'):
Domoticz.Status("Sending Mode Fan")
self.WMPConn.Send('SET,1:MODE,fan\n')
self.WMPConn.Send('LIMITS:SETPTEMP\n') # Check temp limits again when changing modes
elif (Unit == 4):
Domoticz.Debug("Sending Fan Speed")
Domoticz.Status("Sending Fan Speed Auto")
self.WMPConn.Send('SET,1:FANSP,AUTO\n')
Domoticz.Status("Sending Fan Speed Level 1")
self.WMPConn.Send('SET,1:FANSP,1\n')
Domoticz.Status("Sending Fan Speed Level 2")
self.WMPConn.Send('SET,1:FANSP,2\n')
Domoticz.Status("Sending Fan Speed Level 3")
self.WMPConn.Send('SET,1:FANSP,3\n')
elif (Unit == 5):
settemp = Level
Domoticz.Debug("String of Set Temp raw value = " + str(Level))
settemp = round((int((float(settemp) * 10)))/5)*5 #includes complex rounding to nearest 5
Domoticz.Debug("Set Temp converted value = " + str(settemp))
if settemp < minTempLimit: #Adjusting for minLimit of unit
Domoticz.Status("Set temp point less than min limit setting to min value = " + str(minTempLimit / 10) + " Degrees")
settemp = minTempLimit #Send the minimum of unit
if settemp > maxTempLimit: #Adjusting for minLimit of unit
Domoticz.Status("Set temp point greater than max limit setting to max value = " + str(maxTempLimit / 10) + " Degrees")
settemp = maxTempLimit
Domoticz.Status("Setting Temp to: " + str(settemp / 10) + " Degrees")
Domoticz.Debug("Sending Set Temp to: " + str(settemp))
self.WMPConn.Send('SET,1:SETPTEMP,' + str(settemp) + '\n')
elif (Unit == 6):
if (Command == "Off"):
Domoticz.Log("User cleared the ERROR Status LED")
Devices[6].Update(nValue=0, sValue="0") # Set the Error LED switch to Off
else:
Domoticz.Error("No command available to send")
def onNotification(self, Name, Subject, Text, Status, Priority, Sound, ImageFile):
Domoticz.Log("Notification: " + Name + "," + Subject + "," + Text + "," + Status + "," + str(Priority) + "," + Sound + "," + ImageFile)
def onDisconnect(self, Connection):
Domoticz.Log("onDisconnect called")
self.WMPConn = None
def onHeartbeat(self):
global InitHeartbeatCount # Counter for first heartbeats
global oustandingPings # Counter for the Pings for check alive using AMBTEMP
Domoticz.Debug("onHeartbeat called")
Domoticz.Debug("onHeartbeat called, last response seen " + str(oustandingPings) + " heartbeats ago.")
Domoticz.Debug("Heartbeat Init Count = " + str(InitHeartbeatCount))
if (self.WMPConn == None):
Domoticz.Log("Connect to WMP")
InitHeartbeatCount = 0 # reset heartbeat count
oustandingPings = -1 # reset ping count
self.handleConnect()
else:
if (self.WMPConn.Name == "WMP_Connection") and (self.WMPConn.Connected()):
oustandingPings = oustandingPings + 1 # Increment Ping Counter, reset at AMPTEMP Status
if InitHeartbeatCount <= 6:
InitHeartbeatCount = InitHeartbeatCount + 1
Domoticz.Debug("Heartbeat Init Count Incremented now = " + str(InitHeartbeatCount))
if InitHeartbeatCount == 1: #Need to delay these inital messages or some are missed
Domoticz.Debug("Heartbeat Init Count = " + str(InitHeartbeatCount) + " Getting ONOFF")
self.WMPConn.Send('GET,1:ONOFF\n')
Domoticz.Debug("Heartbeat Init Count = " + str(InitHeartbeatCount) + " Getting MODE")
self.WMPConn.Send('GET,1:MODE\n')
Domoticz.Debug("Heartbeat Init Count = " + str(InitHeartbeatCount) + " Getting SETPTEMP")
self.WMPConn.Send('GET,1:SETPTEMP\n')
Domoticz.Debug("Heartbeat Init Count = " + str(InitHeartbeatCount) + " Getting FANSP")
self.WMPConn.Send('GET,1:FANSP\n')
if InitHeartbeatCount == 3:
Domoticz.Debug("Heartbeat Init Count = " + str(InitHeartbeatCount) + " Getting VANEUD")
self.WMPConn.Send('GET,1:VANEUD\n')
Domoticz.Debug("Heartbeat Init Count = " + str(InitHeartbeatCount) + " Getting VANELR")
self.WMPConn.Send('GET,1:VANELR\n')
Domoticz.Debug("Heartbeat Init Count = " + str(InitHeartbeatCount) + " Getting ERRSTATUS")
self.WMPConn.Send('GET,1:ERRSTATUS\n')
if InitHeartbeatCount == 4:
Domoticz.Debug("Heartbeat Init Count = " + str(InitHeartbeatCount) + " Getting ERRCODE")
self.WMPConn.Send('GET,1:ERRCODE\n')
if InitHeartbeatCount == 5:
Domoticz.Debug("Heartbeat Init Count = " + str(InitHeartbeatCount) + " Getting LIMITS ONOFF")
self.WMPConn.Send('LIMITS:ONOFF\n')
Domoticz.Debug("Heartbeat Init Count = " + str(InitHeartbeatCount) + " Getting LIMITS MODE")
self.WMPConn.Send('LIMITS:MODE\n')
Domoticz.Debug("Heartbeat Init Count = " + str(InitHeartbeatCount) + " Getting LIMITS FANSP")
self.WMPConn.Send('LIMITS:FANSP\n')
Domoticz.Debug("Heartbeat Init Count = " + str(InitHeartbeatCount) + " Getting LIMITS VANEUD")
self.WMPConn.Send('LIMITS:VANEUD\n')
if InitHeartbeatCount == 6:
Domoticz.Debug("Heartbeat Init Count = " + str(InitHeartbeatCount) + " Getting LIMITS VANELR")
self.WMPConn.Send('LIMITS:VANELR\n')
Domoticz.Debug("Heartbeat Init Count = " + str(InitHeartbeatCount) + " Getting LIMITS SETPTEMP")
Domoticz.Heartbeat(20) # Extending heartbeat at last Limit
if InitHeartbeatCount == 7: # when count gets to this number and is connected, it will not increment and commence AMBTEMP Heartbeats
Domoticz.Debug("Getting Ambient Temp")
self.WMPConn.Send('GET,1:AMBTEMP\n') # Get AMBTEMP at Heartbeat to confirm connected
if (oustandingPings == 3):
Domoticz.Log(self.WMPConn.Name + " has not responded to 3 heartbeats terminating connection.")
if (self.WMPConn.Connected()):
self.WMPConn.Disconnect()
self.WMPConn = None
def handleConnect(self):
self.WMPConn = None
Domoticz.Debug("Settings shorter heartbeat to speed up initialisation")
Domoticz.Heartbeat(5) # Setting the inital hearbeat timeout used for delaying startup messages - extended in onHeartbeat after counter reached
self.WMPConn = Domoticz.Connection(Name="WMP_Connection", Transport="TCP/IP", Protocol="Line", Address=Parameters["Address"], Port=Parameters["Port"])
self.WMPConn.Connect()
global _plugin
_plugin = BasePlugin()
def onStart():
global _plugin
_plugin.onStart()
def onStop():
global _plugin
_plugin.onStop()
def onConnect(Connection, Status, Description):
global _plugin
_plugin.onConnect(Connection, Status, Description)
def onMessage(Connection, Data):
global _plugin
_plugin.onMessage(Connection, Data)
def onCommand(Unit, Command, Level, Hue):
global _plugin
_plugin.onCommand(Unit, Command, Level, Hue)
def onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile):
global _plugin
_plugin.onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile)
def onDisconnect(Connection):
global _plugin
_plugin.onDisconnect(Connection)
def onHeartbeat():
global _plugin
_plugin.onHeartbeat()
# Generic helper functions
def DumpConfigToLog():
for x in Parameters:
if Parameters[x] != "":
Domoticz.Debug( "'" + x + "':'" + str(Parameters[x]) + "'")
Domoticz.Debug("Device count: " + str(len(Devices)))
for x in Devices:
Domoticz.Debug("Device: " + str(x) + " - " + str(Devices[x]))
Domoticz.Debug("Device ID: '" + str(Devices[x].ID) + "'")
Domoticz.Debug("Device Name: '" + Devices[x].Name + "'")
Domoticz.Debug("Device nValue: " + str(Devices[x].nValue))
Domoticz.Debug("Device sValue: '" + Devices[x].sValue + "'")
Domoticz.Debug("Device LastLevel: " + str(Devices[x].LastLevel))
return
