Game Countdown Switch
Posted: Thursday 30 May 2019 21:48
by AlleyCat
After unsuccessful long research, I am going to the community for help. I set switches in Domoticz to Parental Control my kid's internet. The post is here: https://www.domoticz.com/forum/viewtopi ... ol#p209453
The system works great, and my son is learning responsibility by telling me himself when he gets off his games. Nevertheless, there are days when he would not get off and I still need to cut off the internet manually.
There are a few issues with my current system:
- The current Internet scheduling is not flexible. It goes on and off on a pre-configured schedule using Dummy Switches and scripts.
- Sometimes I turn the internet outside of the "regular" schedule and it goes on unscheduled.
- For unscheduled access, I have a reminder script that sends notifications every 10min that the internet is still on.
I am looking to improve my system by implementing a smart count-down switch. Preferably, a User variable to set how long the Internet will be on (e.g. 30min, 90min, etc.) It will allow me to keep my scheduling system, but expand the flexibility and turn-on or extend the time by a pre-set number of minutes. Can anyone provide references for suggestions on how to implement this kind of a count-down?
The count-down needs to detect the following:
1) Is the Internet on (Dummy Switch)? If yes, keep the Dummy on for add additional time (User Variable)
2) Is the internet is off (again, just checking the status of the Dummy switch): If off, turn the switch on for the duration of the timer.
If a User variable is too complex, I was thinking to have a simple solution with multiple count-down timers for 15min, 30min, 60min, 90min, 120min.
Thank you in advance,
AlleyCat
Re: Game Countdown Switch
Posted: Monday 03 June 2019 22:10
by waaren
AlleyCat wrote: Thursday 30 May 2019 21:48 The count-down needs to detect the following:
Maybe this dzVents script combined with selector switch and uservar can get you started.
local scriptVar = 'Parental control'
local selector = 'Internet access' -- new virtual selector switch See attached image
local switch =  'Parental internet access control' -- your existing dummy switch
local variable = 'Internet access minutes set' -- define as type integer; initial value 0
    on =
            devices =
                selector, -- Selector switch ( set timer )
                switch    -- Control switch (switching access on / off)
            variables =
                variable
    logging =
        level   = domoticz.LOG_DEBUG,
        marker  = scriptVar,
    execute = function(dz, item)
        selector = dz.devices(selector)
        switch = dz.devices(switch)
        variable = dz.variables(variable)
        local function stop(reason)
            dz.log("Stopping internet access triggered by " .. reason,dz.LOG_DEBUG)
            variable.cancelQueuedCommands()
            variable.set(0).silent()
            switch.switchOff().silent()
            selector.switchSelector(0).silent()
        if item.isVariable then
            if item.value > 0 then
                item.cancelQueuedCommands()
                item.set(0).afterMin(item.value) -- This will trigger script again after the set minutes
                dz.log("Internet access activated for " .. item.value .. " minutes")
                switch.switchOn().silent()
                stop("variable =< =")  -- var 0 ==> close internet access
        elseif item == selector then
            if item.level == 0 then stop("selector set to 0")
            elseif item.level < 70 then variable.set(item.level)
            elseif item.level == 70 then variable.set(120)
            elseif item.level == 80 then variable.set(240)
            elseif item.level == 90 then variable.set(variable.value - variable.lastUpdate.minutesAgo + 10)
            item.switchSelector(0).silent()
        elseif not(item.active) then
            stop("manually (or timer) closed control switch") -- selector or switch set to Off ==> close internet access
Posted: Tuesday 11 June 2019 3:07
by AlleyCat
Thank you. Please let me test and provide feedback.
AlleyCat
Posted: Tuesday 11 June 2019 8:45
by emme
to detect if internet i son or off use a PING hardware and add a ping to 8.8.8.8...
that will create a switch on and of if the ping response is true or false
Posted: Wednesday 12 June 2019 13:12
by AlleyCat
The script is working great. I want to improve the UI and usability.
1) How can I turn the Selector status to show On, and it will go off when the timer is out? When I set the Selector the script runs well, but the selector status remains Off.
2) How can I change the script to control a Scene instead of a switch? There are multiple devices connecting to the internet under one scene. It will be useful to control the scene.
3) How can I show a count-down in the Selector Switch Title bar? If the selector was set to 20 min, can I show the count-count value to zero in the Right top bar?
Thank you very much for a great script.
AlleyCat
Posted: Friday 21 June 2019 21:38
by waaren
AlleyCat wrote: Wednesday 12 June 2019 13:12 I want to improve the UI and usability.
change line 55 from
to
-- item.switchSelector(0).silent()
There is no scene.switchOff() so you want probably a group to do this.
if you change line 28 from
to
 switch = dz.groups('your groupname')
it will probably work.
You could force this with the new dz.devices(nnn).rename() method that will become available in dzVents 2.4.24 but the GUI is probably not able to deal with this as the refresh rate of the GUI screen is at least 10 seconds.
Posted: Friday 21 June 2019 22:07
by AlleyCat
Thank you.
Posted: Saturday 24 July 2021 11:46
by snetekombinerke
I want to use this script for my garden irrigation system.
Please someone help me with this.
If i press image of a switch (when it is on), off option by pressing on image doesn't work.
I try adding
elseif item.state == "Off" then
stop("manual stop") -- selector or switch set to Off ==> close internet access
before the last two "end"
I have low understanding of scripting.
Also is it now supported in domoticz -> I would like to add count down value to zero functionality as mentioned by "AlleyCat"
Thanks in advance
