Domoticz port changed
Posted: Tuesday 28 May 2019 20:59
by maciekk
I have probably stupid problem, but I checked in the different portal and didn't find solution of my problem...
I have installed Domoticz into my docker. During the installation I tried to change default port for Domoticz (from -p 8080:8080 \ to -p 8085:8085 \). After the Domoticz is installed I see the chosen port (portainer.io - Domoticz running, port 8085:8085) - but when I try to login on web 192.168.1.44:8085 I see "This site can't be reached" ERR_CONNECTION_REFUSED. I changed domoticz.sh file also - there is the same port as I see on the portainer.
I checked if port 8085 is open - I see that this port is open. Domoticz service is running..
If I install the same with default port 8080 - there is no problem -all works correctly.
I have no idea what can be the reason such situation and what I should do to change default port for another one.
Regards,
Maciek
