global_data
Posted: Monday 27 May 2019 18:47
by poudenes
Hi All,
Question, I want change 1 hardware device for my Milight bulbs. I have all my lights in global_data file to create nice names.
I want test the new hardware, so idea is to create a second global_data in dzVent Gui. Disable the current one and enable the second.
Only what I change there is the IDX for the bulbs. Then all scripts and everything will work.
When the new hardware is failing, I disable the global_data and enable the (current working) one again.
Will this work, or does Domoticz dzVent system will be in conflict, or problems because of 2 global_data files?
Re: global_data
Posted: Monday 27 May 2019 19:19
by waaren
poudenes wrote: Monday 27 May 2019 18:47 Question, I want change 1 hardware device for my Milight bulbs. I have all my lights in global_data file to create nice names.
If you keep your current global_data.lua in the scripts directory dzVents will process it. A way to temporarily disable the current one is to rename it to global_data.disabled; with this extension, dzVents will not process it.
Re: global_data
Posted: Monday 27 May 2019 19:25
by poudenes
thanks. So if im right. I rename it on command line.
cp global_data.disabled global_data
change the IDX in global_data
when go wrong, delete running want and rename the disabled one back.
restart Domoticz
Re: global_data
Posted: Monday 27 May 2019 19:31
by waaren
poudenes wrote: Monday 27 May 2019 19:25 thanks. So if im right. I rename it on command line.
restart Domoticz
sudo cp <domoticz dir>/scripts/dzVents/scripts/global_data.lua  <domoticz dir>/scripts/dzVents/scripts/global_data.disabled
Re: global_data
Posted: Monday 27 May 2019 19:36
by poudenes
disable global_data in webgui dzvent event system
then create new one
This will work. Did the test :)
My global_data is generated by event system
