Sorry for what is probably a stupid question, but as a very new user attempt at blocky I cannot get the below to work.
If I disable the second timing block the light switches on ok, but with timing block enabled the light does nothing although log shows script running.
What I simply want to do is switch on light for a few second or minutes then have it switch off again.
Thanks for any help.
Timer not working
AnthonyD
Timer not working
- Screenshot 2019-05-22 14.30.07.png (36.26 KiB) Viewed 1328 times
besix
Re: Timer not working
Hello, I think you should try this
AnthonyD
Thank you for the fast and very useful reply.
That works perfectly.
My original wording could have been clearer in that I wanted a fixed time, but your reply was actually more useful as I had not spotted the
random option which is useful in security sensing situations.
Tony
Tony
