I have a fibaro Smoke sensor which in zwave frontend show the temperature and some other option.
But in Domoticz it shows up as a switch, but it doest show the temperature/smoke?
Can i add the tempteratur some other way, and the switch is triggerd by the settings such as
Default value: MEDIUM Sensitivity
There are 3 levels of sensitivity to smoke presence. Level 1 means the highest sensitivity.
Nº 83 - Black Box sensitivity level : HIGH Sensitivity MEDIUM Sensitivity LOW Sensitivity
I understand that in the fibaro home server you could be able to see the amount of smoke that is detected, is there also such a option here ?
Fibaro Smoke sensor fgss-001
Re: Fibaro Smoke sensor fgss-001
I'd like to know this as well...
Hi! I've got 3 of these babies as well. Would be really cool if Domoticz can generate a graphical report of detected smoke levels, the same way as logged temperatures are presented for temperature-sensors. Fibaro does that in their so called Black Box, indeed. Pretty awesome
Commercial picture of Black Box:
http://www.fibaro.com/sites/all/themes/ ... 16_eng.png
I would also like to see these options from the device.
i got 4 of these at the moment, 4 more will come.
So also like to see this option
Sorry to bump up an old topic, but I've just bought 2 fibre smoke sensors from Amazon Italy and it appears they are the FGSS-001 type.
When I add them with the z-stick gen5 i see the light flash successfully when included into the network.
When I check in domoticz i see it only listed as Unknown under hardware, and the only configuration to change for this node is "wake up interval":
008 (0x08) Unknown 2015-11-05 09:17:08
Checked the open zwave files and I only see a config for the fgss-101 sensor.
I can't find any manufacturer id in the domoticz logs.
Anyone got a clue where i need to look or have an xml file I can use?
Hi guys,
As far as I understand, the FGSS only sends out 'real time' temperature data when wired to an external power source.
this is done to save battery life.
When running on battery, it will only send an 'alarm' signal when triggered by smoke.
Hope this helps..
Hope this helps..
- Domoticz version: 3.6857
I too would like to see the smoke levels recorded from these smoke alarms in Domoticz.
Now setup on a RPI3.
Also using Evohome HGI80, RFXTRX433E and a Aeotec Gen5 stick. Mainly a Gen5 Z-Wave system.
My weather (Davis vantage Pro2) data is obtained by weatherunderground
Now collecting rtl_433 data from Apollo Ultrasonic meter
