433mhz parking remote
Justino
Domoticz version: 4.10548
Post by Justino »
Hi there,
I have the following project i'm trying to get working.
At the moment, i have a 433Mhz parking rolling bar which i would like to control via Domoticz.
When i use my Pi and a 433Mhz Receiver to receive the sending remote, it does not receive a code or reply.
Simply using a KlikAanKlikUit remote does however get received on my 433Mhz receiver, and shown on my Pi
Here are some pictures of the remote.
Is does state SAW1 on top of the 433.92 chip in the left top corner
Does anyone know how i can receive any replies from these remotes?
Kind regards,
Justin
FireWizard
Re: 433mhz parking remote
Post by FireWizard »
Which 433 MHz receiver do you use?
If you check e.g. the compatibility guide of the RFXCom transceiver, you will find that the Ferport TAC 2 KR is not mentioned in the compatibility list.
Check the compatibility list of your 433 MHz receiver first.
For 433MHz there exist numerous different protocols.
The fact only that the remote functions on 433MHZ doesn't mean that it can be used by any receiver and so by Domoticz.
Justino
Post by Justino »
FireWizard wrote: Monday 20 May 2019 13:12 Hello,
I'm using a simple ebay receiver/transmitter set ($5)
I also have a RFXCom but it does not recognize the remote :cry:
Could i clone the signal with a RTL-SDR? Was thinking about this, since it's compatible with the whole signal (if i'm correct?)
FireWizard
If you can clone the signal I don't know. Too little experience with that.
You can contact RFXCom and ask if they can include the protocol of this unit in a future software release.
Justino
Post by Justino »
I will contact them, would be great.
If someone else has ideas, please let me know
FireWizard
While thinking about and some "googling I came across the following topic:
viewtopic.php?f=74&t=27260
Might be work for your remote as well.
