I'am using a relay board with a raspberry pi 3.
I can't get the mi- light wifi module to work so instead i use another remote and solder 3 wires so i can use the on and off button for my led strips.
I've set up 2 relays through gpio.
One to switch on and the other to swith off.
I've setup a push button with a delay to swith off the relay so it looks like you really push the remote.
When i push off, the led strip switches off but in the dark you can see a glow coming from the led strips.
Now it seems that when you push a little to long on the remote the led strips aren't fully switched off.
Unfortunately the minimum time (push button settings) for delay in domoticz is 1 second.
Is there another way to fix this?
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
Switch off time
imdos
- Domoticz version: 2023.2
Re: Switch off time
Making use of: Raspbian(SSD), dz Beta, Woonveilig, Z-Wave(alarm+multi-sensor), RFLink(blinds), P1, Yeelight, Xiaomi temp sensors, Tasmota(SonoFF, Blitzwolf SHP2, Shelly1)
