graph by mail
Posted: Thursday 16 May 2019 10:04
by flyertoon
I would like to receive this by mail. Can you help me? Thanks!!!
see attached file: temp graph
Re: graph by mail
Posted: Thursday 16 May 2019 10:23
by emme
print it as PDF or save it as image and attach it into an email
Re: graph by mail
Posted: Thursday 16 May 2019 20:23
by flyertoon
Hello, thanks
My question was not clear. I would like to receive this graphic every day in my mailbox. Automatically, by script I think
Re: graph by mail
Posted: Thursday 16 May 2019 20:34
by waaren
flyertoon wrote: Thursday 16 May 2019 20:23
I don't think it's possible to get it as a graphic. Closest you can get is get the underlying data.
Re: graph by mail
Posted: Friday 17 May 2019 13:07
by flyertoon
... how can i get underlying data please ? or where are stored the log ?
thanks
Re: graph by mail
Posted: Friday 17 May 2019 14:17
by waaren
flyertoon wrote: Friday 17 May 2019 13:07
A dzVents script to do this could look like the one in the code window below.
When not yet familiar with dzVents please start with reading
Get started Before implementing. Special attention please for
"In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents disabled' is not checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
local scriptVar = "mailTemplog"
on = { timer = { "every 5 minutes" },
httpResponses = { scriptVar .. "*" },
logging = { level = domoticz.LOG_DEBUG, -- change to LOG_ERROR when script executes OK
marker = scriptVar},
execute = function(dz, item)
local temperatureSensor = 842 -- idx or "name" of your tempSensor
local emailAddress = '[email protected]' -- Your Email address
local function resultTable2String(t)
str = ""
for _, record in ipairs(t.result) do
str = str .. record.d .. "," .. record.te .. "\\n" -- convert table to comma / LF separated
return str
local function getTempLog(idx)
url = dz.settings['Domoticz url'] .. "/json.htm?type=graph&sensor=temp&range=day&idx=" .. idx
dz.openURL({ url = url,
method = "GET",
callback = scriptVar .. "_graph"}) -- collect graph data from domoticz
if item.isTimer or item.isDevice then
getTempLog(temperatureSensor) -- Call domoticz API
dz.email('Temperature log from device ' .. dz.devices(temperatureSensor).name, resultTable2String(item.json) , emailAddress )
