Page 1 of 2
set color based on value
Posted: Sunday 12 May 2019 11:03
by Venzent
I searched the forum, but cannot find the right answer.
I want to change the color of a icon when a value of the sensor is between 2 values.
For example, if the value is above 85 it must be green, if it is between 75 and 85 orange, and below 75 it must be red.
I can find some examples with on-off states, but not multiple colors on pre-defined values and ranges.
Some example would be nice.
Re: set color based on value
Posted: Saturday 18 May 2019 17:08
by Lokonli
Below an example of a combined temperature/humidity device with index 56.
Define the styles you want to apply in custom.css:
.warningred {
  color: red !important;
.warningorange {
  color: orange !important;
.warninggreen {
  color: green !important;
In custom.js define the function afterGetDevices() as follows:
function afterGetDevices(){
	 if ((alldevices[56].Temp>=75) && (alldevices[56].Temp<85)) {
		$('.block_56_1 .col-icon').addClass('warningorange');
	 if (alldevices[56].Temp<75) {
		$('.block_56_1 .col-icon').addClass('warninggreen');
	if (alldevices[56].Temp>=85) {
		$('.block_56_1 .col-icon').addClass('warningred');
If you have just a single value device, you can use block_56 instead of block_56_1.
Depending on the kind of device you are using you may change alldevices[56].Temp to something applicable for your device.
Posted: Sunday 19 May 2019 16:20
by HansieNL
I have same kind of question. I have a text block and want to change it depending on message. This is what I have done so far:
In custom.js:
//Buienradar
function getStatus_345(idx,value,device){
  if(device['Data']=="Voorlopig droog") {
            $('div.block_345').addClass('off-stat');
            $('.block_345 .col-icon').addClass('off-ico');
    else {
            $('div.block_345').removeClass('off-stat');
            $('.block_345 .col-icon').removeClass('off-ico');
In custom.css:
.off-stat {
    color: #6A6A6A;
.off-ico {
    opacity: 0.4 !important;
The title and value text change color, but the icon color (png image) does not change.
Please advice how to solve this.
Thanks in advance.
Posted: Sunday 19 May 2019 16:48
by Lokonli
HansieNL wrote: Sunday 19 May 2019 16:20 I have same kind of question. I have a text block and want to change it depending on message. This is what I have done so far:
In custom.js:
//Buienradar
    else {
In custom.css:
.off-stat {
    color: #6A6A6A;
.off-ico {
Thanks in advance.
Dashticz regenerates the icon (and data part) of a block after calling the getStatus function. As a side-effect the off-ico class you applied disappears as well. (block_345 itself doesnt get recreated so the off-stat class persists)
The afterGetDevices function gets called after creating the icon part, so you should use that one if you want to change the icon. If you need an example let me know.
Posted: Sunday 19 May 2019 17:33
by HansieNL
Lokonli wrote: Sunday 19 May 2019 16:48 Dashticz regenerates the icon (and data part) of a block after calling the getStatus function. As a side-effect the off-ico class you applied disappears as well. (block_345 itself doesnt get recreated so the off-stat class persists)
@Lokonli: Thanks for the help. This is code is working ok:
//Buienradar
    if (alldevices[345].Data == 'Voorlopig droog') {
            $('.block_345 .col-data').addClass('off-stat');
    else {
            $('.block_345 .col-data').removeClass('off-stat');
Posted: Sunday 19 May 2019 21:59
by HansieNL
@Lokonli: I wanna change the off color for the blocks Kodi Media Server and StreamPlayer too if possible. I don't have an idea how to fix this. Can you help to fix this please. Thanks in advance.
@Lokonli: Kodi Media Server off color already fixed by using a virtual on/of switch.
Would be great if StreamPlayer can have off color when not playing.
Posted: Saturday 25 May 2019 20:55
by HansieNL
Someone who knows how to set Streamplayer off color?
This is what I already tried, but that doesn't work:
if (alldevices[streamplayer].audio != 'play') {
  $('div.streamplayer').addClass('pause-stat');
else {
  $('div.streamplayer').removeClass('pause-stat');
Posted: Sunday 26 May 2019 9:48
by Venzent
Lokonli wrote: Saturday 18 May 2019 17:08 Below an example of a combined temperature/humidity device with index 56.
.warningred {
.warningorange {
.warninggreen {
Hi Lokonli,
Thanks for the code. I did not find the time yet to implement and test it. But would like to let you know I I've seen it and will try it asap.
Posted: Thursday 30 May 2019 11:02
by Lokonli
HansieNL wrote: Saturday 25 May 2019 20:55 Someone who knows how to set Streamplayer off color?
else {
The streamplayer block is not a Domoticz device, but functionality from Dashticz. Changing the appearance of the block via custom.js requires quite some hacking.
A cleaner solution is to add the playing state as a class to the streamplayer block. Then the styling can be changed easily via custom.css.
I will make the change. It will be merged in the next beta version of Dashticz.
Posted: Thursday 30 May 2019 19:37
by HansieNL
Lokonli wrote: Thursday 30 May 2019 11:02 I will make the change. It will be merged in the next beta version of Dashticz.
Thanks. That’ll make my dashboard almost complete.
Posted: Saturday 23 May 2020 22:20
by jaaap
I want a UV index alert sensor to get a color according to its value. For instance, if the UV is >= 6 I want the title of the block to be red. I tried several things but have not succeeded yet. Here's the code I added to the custom.js:
   // Warnings UV index
	 if (alldevices[165].Data>=6) {
		$('.block_165' .title).addClass('warningred');
         if ((alldevices[165].Data >= 5) && (alldevices[165].Data<6)) {
		$('.block_165 .title').addClass('warningorange');
         if ((alldevices[165].Data >= 4) && (alldevices[165].Data<5)) {
		$('.block_165 .title').addClass('warningyellow');
	 if (alldevices[165].Data <4) {
		$('.block_165 .title').addClass('warninggreen');
In the CSS file I added:
.warningred {
.warningorange {
.warningyellow {
  color: yellow !important;
.warninggreen {
Domoticz gives me the following info about the sensor:
			"AddjMulti" : 1.0,
			"AddjMulti2" : 1.0,
			"AddjValue" : 0.0,
			"AddjValue2" : 0.0,
			"BatteryLevel" : 255,
			"CustomImage" : 0,
			"Data" : "7.4 UVI",
			"Description" : "",
			"Favorite" : 0,
			"HardwareID" : 28,
			"HardwareName" : "UV index",
			"HardwareType" : "OpenUV",
			"HardwareTypeVal" : 94,
			"HaveTimeout" : false,
			"ID" : "001C0003",
			"LastUpdate" : "2020-05-22 08:32:53",
			"Level" : 2,
			"Name" : "UV index - UV Max",
			"Notifications" : "false",
			"PlanID" : "0",
			"PlanIDs" :
				0
			"Protected" : false,
			"ShowNotifications" : true,
			"SignalLevel" : "-",
			"SubType" : "Alert",
			"Timers" : "false",
			"Type" : "General",
			"TypeImg" : "Alert",
			"Unit" : 3,
			"Used" : 1,
			"XOffset" : "0",
			"YOffset" : "0",
			"idx" : "165"
Any ideas where I'm going wrong?
Posted: Saturday 23 May 2020 23:02
by Lokonli
There is a small typo in the beginning:
should be:
		$('.block_165 .title').addClass('warningred');
Further, Data is a string (=text). You first have to create a number from it via:
  var value = parseFloat(alldevices[165].Data);
and then in the if statements you can use:
if (value>=6) {
The only disadvantage is that this is not very efficient: the code gets called at every device update. (but probably not really a problem)
You could rewrite it to a getStatus_165() function. See some examples in the documentation (beta version!)
Posted: Sunday 24 May 2020 0:26
by jaaap
Lokonli wrote: Saturday 23 May 2020 23:02 There is a small typo in the beginning:
should be:
if (value>=6) {
Ouch! A typo...that's painful :oops: I got it working now, thanks! Only the getStatus_165() is still a mystery to me. More to look into the coming evenings ;)
Posted: Tuesday 26 May 2020 11:47
by Ierlandfan
What if I want to change the background of the block based on value?
Do I define those in custom.css and if how?
div.mh.transbg.block_275.col-xs-4.on
(On)
div.mh.transbg.block_275.col-xs-4.off
(Off)
Posted: Tuesday 26 May 2020 11:57
by Lokonli
yes, in custom.css. Try:
.block_275.on {
  background-color: red !important
.block_275.off {
  background-color: green !important
Posted: Tuesday 26 May 2020 11:59
by Lokonli
This is only for the on/off state of switches.
If you want to change the styling based on the value (like temperature) you have to use custom.js
See the documentation for some examples:
https://dashticz.readthedocs.io/en/beta ... -idx-block
Posted: Wednesday 27 May 2020 17:40
by Ierlandfan
The custom.css code did the trick! Small minor question: Can it be done for all blocks in custom.css instead of defining it for each individual block?
Posted: Wednesday 27 May 2020 18:18
by Lokonli
Ierlandfan wrote: Wednesday 27 May 2020 17:40 The custom.css code did the trick! Small minor question: Can it be done for all blocks in custom.css instead of defining it for each individual block?
'.block_275' is indeed a specific block selector.
Luckily all Domoticz block also have the class '.mh' attached, so the following should work if you want to apply the styling to all blocks at once:
.mh.on {
.mh.off {
Posted: Tuesday 17 November 2020 20:18
by Vondee
I want to change the color of IDX 462 based on the status of IDX 460
but
function getStatus_460(idx,value,device){
   if(device['Data']=='Off'){
      $('div.block_462').removeClass('warningred');
   else {
      $('div.block_462').addClass('warningred');
does not work, how should this be programmed in custom.js?
Posted: Tuesday 17 November 2020 21:33
by Lokonli
Vondee wrote: Tuesday 17 November 2020 20:18 I want to change the color of IDX 462 based on the status of IDX 460
but
   else {
https://dashticz.readthedocs.io/en/mast ... -idx-block
https://dashticz.readthedocs.io/en/mast ... ther-block
