KNX to Domoticz
Posted: Saturday 11 May 2019 15:00
by emme
GREAT NEWS for KNX users out there....
I'm quite enthusiastic to inform you that I finally found a way to sync status and commands (for switch and blinds/dimmer) between Domoticz and the Bus
You will need a MQTT Broker and NodeRed, nothing you don't have already on a Linux version.
You will also need the Group Address map and a IPInterface/Router on the bus side.
Just few days to finalize the code and I'll post di NodeRED.org and here in the forum
Ciao
M
P.S.
if there are users that willing to test, just contact me
Re: KNX to Domoticz
Posted: Wednesday 05 June 2019 18:26
by burago
Hi, i'm very interested about your topic. I recently performed my knx installation at home and i'm running domoticz since last year.
i would like to be able to perform some exchange between both:
- capture knx device information (light, temperature..) to domoticz
- sent the "time" from domoticz to knx device
- perform push from domoticz to knx device to manage day and night behaviour.
could you please provide support?
thank you in advance.
Philippe
Re: KNX to Domoticz
Posted: Wednesday 05 June 2019 19:01
by Thorgal789
There isn't an easier way, without so much software layer (MQTT + Nodered) ?
For exemple with this lib
https://github.com/XKNX/xknx but with python ?
Re: KNX to Domoticz
Posted: Wednesday 05 June 2019 19:26
by burago
Maybe but i don't knx exactly how. Python is already installed on m'y system tout enable plugins (zigate...) But thé n'est would be to have a plugins ready for domoticz (like it is existing on jeedom)
Do you know how xknx library Can ne used?
Re: KNX to Domoticz
Posted: Wednesday 05 June 2019 19:49
by Thorgal789
I think you need to make a complete plugin with it, it's just a lib.
But there is a plugin for Hass inside, and some exemple to make test, and it's seem realy easier than use mqtt.
"""Example for switching a light on and off."""
import asyncio
from xknx import XKNX
from xknx.devices import Light
async def main():
"""Connect to KNX/IP bus, switch on light, wait 2 seconds and switch it off again."""
xknx = XKNX()
await xknx.start()
light = Light(xknx,
name='TestLight',
group_address_switch='1/0/9')
await light.set_on()
await asyncio.sleep(2)
await light.set_off()
await xknx.stop()
# pylint: disable=invalid-name
loop = asyncio.get_event_loop()
loop.run_until_complete(main())
loop.close()
Re: KNX to Domoticz
Posted: Thursday 06 June 2019 22:52
by burago
Hi, Thorgal, unfortunatelly, my knowledge does not enable me to perform a complete plugin.
Is there somebody who would like to help?
i would be enjoy to support this kind of initiative.
Re: KNX to Domoticz
Posted: Sunday 23 June 2019 15:21
by tex73
Hi emme, I'm waiting for the code to let the knx communicate with domoticz. At the moment I can get the knx to communicate with node-red and it works well; with domitcz I have some problems.
I also have a question: using a virtual switch (dummy) in the "on action" field can I put the ip interface link and the group address of the knx device? If so how?
thanks
Re: KNX to Domoticz
Posted: Friday 28 February 2020 10:52
by leoncornelissen
any update on this one?
Re: KNX to Domoticz
Posted: Friday 28 February 2020 11:27
by burago
Unfortunatelly no solution is easily available. If someone coule help, it would be great
