Hi, I have a outside screen with a fahar RTS FR45 motor that works with 433Mhz frequentie, i tried several things to ad this to domoticz but it won't work, does any one have experience with this how i can ad this to domoticz
I have raspberry with RFXCom433E
Grt Rool
Screen motor on 433Mhz
b_weijenberg
- Target OS: -
Re: Screen motor on 433Mhz
Is the Faher remote received in RFXmngr using the latest Pro1 firmware and BlindsTx enabled?
RFX-433, RFX-433EMC, RFX-868
Rool
yes indeed, i add the blinds with the RFX manager by tab blinds and then T6 and that works fine.
Now when i add a switch type blinds in domoticz and set the UI then it works fine, i have 3 command that i can give, 1. up 2. down 3. stop and that is perfect.
Now when i set the timer function i can only use 1.up and 2. down there is no option to give the command 3.stop
I need that thirt option for close half my blinds, is there an other sulution available or maybe is that a request for developers.
Regards Ronald
Regards Ronald
