question about timers
Posted: Sunday 05 May 2019 11:03
by pvklink
I have a question about timers.
When a switch is on for x minutes or must be set to off after x minutes, are these timers deleted when the same switch is manually set to off?
I have a switch hetregent which is set for a period of time and if in the period of time a sensor get's a new signal that it is raining the switch hetregent must be set to on for the new/latest period of time and the old period must be deleted.
    on      =    {devices = {'$tuinwatersensor'}},
    logging =   {
                    level   = domoticz.LOG_DEBUG ,                  -- Uncomment to override the dzVents global logging setting
                    marker  = "Watermeting"
    data    =   {
                    raintable = { history = true,  maxHours = 1 },
    execute = function(dz, device, info)
        local switch        = dz.devices('hetregent')
        local norm          = 5
        local DurTimer      = 800
        local huidwaarde    = device.state
        local now           = os.time(os.date('*t'))
        if huidwaarde == nil then               -- onderstaande checks moeten na de locals omdat ze deze ook gebruiken!
            dz.log("01 Sensor info         = Geen waarde opgehaald")
            dz.data.raintable.add(huidwaarde)
        local aantal = 0
        for i = dz.data.raintable.size,1,-1 do
            aantal = aantal +1
            item = dz.data.raintable.get(i)
            dz.log("00 History data van " .. item.time.rawDate .. " " .. item.time.rawTime ..
                                    " = " .. item.data)
        dz.log("Deviceinfo---------------------------------------")
        dz.log("00 Sensor...........................= " .. device.name)
        dz.log("00 Switch-device....................= " .. switch.name)
        dz.log("00 Uitzetten.na(in.min).............= " .. DurTimer)
        dz.log("Sensor info-------------------------------------")
        dz.log("00 Aantal.norm......................= " .. norm)
        dz.log("00 Aantal gemeten...................= " .. aantal)
        dz.log("00 Aantal.huidige waarde............= " .. huidwaarde)
        dz.log("00 Notificatie.switch.laatste update= " .. tostring(switch.lastUpdate.rawTime)) -- deze is goed
        dz.log("-------------------------------------------------")
    if  aantal >= norm  then
        if switch.state == 'Off' then
            switch.switchOn()
            switch.switchOff().afterMin(DurTimer)
            switch.switchOff()
            switch.switchOn()
        dz.log('Script: ' .. info.scriptName .. ' Regendruppel signalen (' .. aantal .. ') is gelijk of boven de norm(' .. norm .. '), ' .. switch.name .. ' wordt geactiveerd voor ' .. tostring(DurTimer) .. ' Minuten ', dz.LOG_INFO)
Re: question about timers
Posted: Sunday 05 May 2019 11:57
by waaren
pvklink wrote: Sunday 05 May 2019 11:03 When a switch is on for x minutes or must be set to off after x minutes, are these timers deleted when the same switch is manually set to off?
No, timer is not deleted by the On or Off commands. Use cancelQueuedCommands for that.
New code snippet would then look like:
       switch.cancelQueuedCommands()
       switch.switchOn().checkFirst()
Posted: Sunday 05 May 2019 12:26
by pvklink
@waaren: your change works perfect!
thanks again!
My irrigationprogram is stopped now when:
Local weather is 'rain' or
my watersensor measures water...
good for the environment!
