Extract Max and min temperature from a temperature device
Posted: Sunday 05 May 2019 10:03
by acaonweb
Hi, there is a way to extract max and min temperature in a day using dzevents in native way i mean using data are stored by domoticz?
Having a look to the day temperature graph, i can see the max and min are already calculated/extracted
So maybe is possible to extract them from database...
Thanx in advance 😄
Fabrizio
Re: Extract Max and min temperature from a temperature device
Posted: Sunday 05 May 2019 20:47
by waaren
acaonweb wrote: Sunday 05 May 2019 10:03 Hi, there is a way to extract max and min temperature in a day using dzevents in native way i mean using data are stored by domoticz?
This could be a way to do it.
local scriptVar = "minMaxTemp"
    on      =   {
                    timer = { "every 12 minutes" },
                    httpResponses = { scriptVar .. "*" }
    logging =   {
                    level           =   domoticz.LOG_ERROR,
                    marker          =   scriptVar,
    execute = function(dz, item)
        -- ****************************** Your settings below this line ***************************************************
        temperatureDevice = dz.devices(xxxx)          -- Replace with ID of temperatureDevice you want to track
        minMax = dz.devices(yyyy)                     -- Create as virtual text sensor
        -- ****************************** No changes required below this line *********************************************
        local function logWrite(str,level)
            dz.log(tostring(str),level or dz.LOG_DEBUG)
        local function getGraphData(id)
            local  url = dz.settings['Domoticz url'] .. "/json.htm?type=graph&sensor=temp&range=month&idx=" .. id
            dz.openURL({ url = url,
                         method = "GET",
                         callback = scriptVar .. "_" .. id})
        local function getMinMax(rt)
            for idx, v in ipairs(rt) do
                if rt[idx].d == dz.time.rawDate then
                    return dz.utils.round(rt[idx].tm,1) , dz.utils.round( rt[idx].te,1 )  -- min, max
        local function formatText(min,max)
            return (    os.date("%A ") .. dz.time.day .. " " .. os.date("%B ") .. " " .. dz.time.year .. "\n" ..
                        "min. temp: " .. min .. " °C\n" ..
                        "max. temp: " .. max .. " °C") -- full-Dayname  day full-Monthname yyyy
        if not item.isHTTPResponse then
            getGraphData(temperatureDevice.idx)
        elseif item.ok then                                      -- statusCode == 2xx
            minMax.updateText(formatText(getMinMax(item.json.result)))
            logWrite("Could not get (good) data from domoticz. Error (" .. (item.statusCode or 999) .. ")"  ,dz.LOG_ERROR)
            logWrite(item.data)
Posted: Monday 06 May 2019 16:12
by acaonweb
Many Thanx,
i'll have a look deeply to the code ;)
Fabrizio
