Combine measurements of the same type in a domoticz device
Posted: Sunday 05 May 2019 8:36
by neptunus
Hello Reader,
I have a question about adding creating a plugin with the plugin framework. My goal is to combine a number of values of measurements in a domoticz device.
Create devices example:
    if 1 not in Devices:
        Domoticz.Device(Name="Voltage L1,L2,L3", Unit=1,TypeName="Voltage",Used=0).Create()
    if 2 not in Devices:
        Domoticz.Device(Name="Current L1,L2,L3", Unit=2,TypeName="Current/Ampere",Used=0).Create()
Update devices example:
    Devices[1].Update(0,str(230.1)+";"+str(230.2)+";"+str(230.3))
    Devices[2].Update(0,str(10.1)+";"+str(10.2)+";"+str(10.3))
The code is working with this simple plugin.py
What I just don't understand is why this doesn't work for voltages and it does for currents. I made the assumption that with this constuction you could build any available device with measurements of the same type. Below a number of merged images where you can see what I mean. I have also added the log file for clarification.
Can someone help me to combine measurements of the same type in a domoticz device?
Click image to view full-size:
Logging
sudo service domoticz restart && sudo tail -f /var/log/domoticz.log
2019-05-01 21:19:12.400  (test) onStop called
2019-05-01 21:19:12.466  Status: (test) Stopping threads.
2019-05-01 21:19:12.648  Status: (test) Exiting work loop.
2019-05-01 21:19:12.648  Status: (test) Stopped.
2019-05-01 21:19:12.655  Status: Scheduler stopped...
2019-05-01 21:19:12.729  Status: EventSystem: Stopped...
2019-05-01 21:19:12.737  Status: EventSystem - Python stopped...
2019-05-01 21:19:13.164  Status: PluginSystem: Exiting work loop.
2019-05-01 21:19:13.171  Status: PluginSystem: Stopped.
2019-05-01 21:19:13.229  Status: Mainworker Stopped...
2019-05-01 21:19:13.381  Status: RxQueue: queue worker started...
2019-05-01 21:19:15.406  Status: (test) Started.
2019-05-01 21:19:15.407  Status: EventSystem: reset all events...
2019-05-01 21:19:15.407  Status: EventSystem: reset all device statuses...
2019-05-01 21:19:15.452  Status: Python EventSystem: Initalizing event module.
2019-05-01 21:19:15.452  Status: EventSystem: Started
2019-05-01 21:19:15.452  Status: EventSystem: Queue thread started...
2019-05-01 21:19:15.827  Status: PluginSystem: Entering work loop.
2019-05-01 21:19:15.868  Status: (test) Initialized version 1.0.0, author 'meuk'
2019-05-01 21:19:15.868  Status: (test) Entering work loop.
2019-05-01 21:19:15.869  (test) onStart called
2019-05-01 21:19:15.869  (test) Debug logging mask set to: PYTHON PLUGIN QUEUE IMAGE DEVICE CONNECTION MESSAGE
2019-05-01 21:19:15.869  (test) 'Version':'1.0.0'
2019-05-01 21:19:15.869  (test) 'Port':'0'
2019-05-01 21:19:15.869  (test) 'DomoticzHash':'b47a877f'
2019-05-01 21:19:15.869  (test) 'DomoticzBuildTime':'2018-06-23 16:27:56'
2019-05-01 21:19:15.869  (test) 'HardwareID':'7'
2019-05-01 21:19:15.869  (test) 'Key':'TestPlug'
2019-05-01 21:19:15.869  (test) 'Author':'meuk'
2019-05-01 21:19:15.869  (test) 'DomoticzVersion':'4.9701'
2019-05-01 21:19:15.869  (test) 'HomeFolder':'/home/meuk/domoticz/plugins/testing/'
2019-05-01 21:19:15.869  (test) 'Name':'test'
2019-05-01 21:19:15.869  (test) Device count: 2
2019-05-01 21:19:15.869  (test) Device:           1 - ID: 13, Name: 'test - Voltage L1,L2,L3', nValue: 0, sValue: '230.1;230.2;230.3'
2019-05-01 21:19:15.869  (test) Device ID:       '13'
2019-05-01 21:19:15.869  (test) Device Name:     'test - Voltage L1,L2,L3'
2019-05-01 21:19:15.869  (test) Device nValue:    0
2019-05-01 21:19:15.869  (test) Device sValue:   '230.1;230.2;230.3'
2019-05-01 21:19:15.869  (test) Device LastLevel: 0
2019-05-01 21:19:15.870  (test) Device:           2 - ID: 14, Name: 'test - Current L1,L2,L3', nValue: 0, sValue: '10.1;10.2;10.3'
2019-05-01 21:19:15.870  (test) Device ID:       '14'
2019-05-01 21:19:15.870  (test) Device Name:     'test - Current L1,L2,L3'
2019-05-01 21:19:15.870  (test) Device nValue:    0
2019-05-01 21:19:15.870  (test) Device sValue:   '10.1;10.2;10.3'
2019-05-01 21:19:15.870  (test) Device LastLevel: 0
2019-05-01 21:19:15.870  (test) createDevices
2019-05-01 21:19:25.370  (test) Pushing 'onHeartbeatCallback' on to queue
2019-05-01 21:19:25.391  (test) Processing 'onHeartbeatCallback' message
2019-05-01 21:19:25.391  (test) Calling message handler 'onHeartbeat'.
2019-05-01 21:19:25.391  (test) onHeartbeat called
2019-05-01 21:19:25.391  (test) updateDevices
2019-05-01 21:19:25.392  (test - Voltage L1,L2,L3) Updating device from 0:'230.1;230.2;230.3' to have values 0:'230.1;230.2;230.3'.
2019-05-01 21:19:25.393  (test - Current L1,L2,L3) Updating device from 0:'10.1;10.2;10.3' to have values 0:'10.1;10.2;10.3'.
2019-05-01 21:19:35.372  (test) Pushing 'onHeartbeatCallback' on to queue
2019-05-01 21:19:35.416  (test) Processing 'onHeartbeatCallback' message
2019-05-01 21:19:35.416  (test) Calling message handler 'onHeartbeat'.
2019-05-01 21:19:35.416  (test) onHeartbeat called
2019-05-01 21:19:35.416  (test) updateDevices
2019-05-01 21:19:35.416  (test - Voltage L1,L2,L3) Updating device from 0:'230.1;230.2;230.3' to have values 0:'230.1;230.2;230.3'.
2019-05-01 21:19:35.417  (test - Current L1,L2,L3) Updating device from 0:'10.1;10.2;10.3' to have values 0:'10.1;10.2;10.3'.
