Stop dzvents script when esp is not online
Posted: Saturday 27 April 2019 22:23
by hoeby
I hope somebody can help me.
Did a search on the forum, but couldn't find it. Maybe i am not searching with the right words.
Last week domiticz crashed 2 times. Working with it for 2 years without crash. Needed to search why and found a dzvents script that want toggle an espeasy switch. But the espeasy device was broken, but the script stayed running. And made domiticz crash after a few hours running.
I use this type of command in dzvents
http://192.168.xxx.xxx/control?cmd=GPIO,14,0 but need something which checks the espeasy and stops the script when the device is not online.
Somebody has an idea how?
Re: Stop dzvents script when esp is not online
Posted: Saturday 27 April 2019 22:40
by waaren
hoeby wrote: Saturday 27 April 2019 22:23
Did you see any error message before the crash ?
Can you share the script that crashed domotizc ?
Did the espEasy react to a ping ?
Posted: Sunday 28 April 2019 7:55
by hoeby
I don't had log actieve, which writes a logfile (domoticz.sh, there was an # in front of the log row).
When looking in log of the domoticz dashboard, i couldn't look there. Domoticz was offline. After service stop and start the log was empty.
Don't know if there was an error message.
The espEasy was not reaction to a ping. To power supply was dead and therefor offline.
devices = {'Backlight Dashboard',
'Dashboard Screen Status',
'Dashboard Homepage Trigger'}
if(
domoticz.devices('Backlight Dashboard').state == 'On' and
domoticz.devices('Dashboard Screen Status').state == 'On' and
domoticz.time.matchesRule('on mon,tue,wed,thu,fri,sat,sun') and
(domoticz.time.hour >= 23 or domoticz.time.hour < 7)) then
domoticz.openURL({url = 'http://192.168.xxx.xxx/control?cmd=gpio,13,1'}).afterSec(150)
domoticz.openURL({url = 'http://192.168.xxx.xxx/control?cmd=gpio,13,0'}).afterSec(151)
elseif(
domoticz.devices('Backlight Dashboard').state == 'Off' and
domoticz.devices('Dashboard Screen Status').switchOff().silent()
elseif(
domoticz.devices('Dashboard Screen Status').state == 'Off' and
elseif(
domoticz.time.matchesRule('between 07:00 and 23:00')) then
domoticz.devices('Dashboard Screen Status').switchOn().silent()
elseif(
domoticz.time.matchesRule('on thu,fri,sat,sun') and
domoticz.openURL({url = 'http://192.168.xxx.xxx/control?cmd=gpio,13,0'}).afterSec(1)
elseif(
elseif(
domoticz.devices('Dashboard Homepage Trigger').state == 'On' and
domoticz.devices('Dashboard Screen Status').state == 'Off') then
elseif(
domoticz.devices('Dashboard Homepage Trigger').state == 'On') then
domoticz.devices('Dashboard Homepage Trigger').switchOff().silent().afterSec(20)
Posted: Sunday 28 April 2019 8:54
by SweetPants
This is the main reason I use MQTT with retained messages. ESP modules tend to go offline sometimes, either by it self or when you boot your WiFi router, they loose connection for some time. Using MQTT, Domoticz is always able to send the message to the broker, even if the ESP is offline. When it comes online again, the broker sends the last retained message to the ESP module again. I am using this for years now and it works great. Have around 20 ESP devices running now on MQTT without any major problems.
Posted: Sunday 28 April 2019 10:56
by waaren
hoeby wrote: Sunday 28 April 2019 7:55
I agree with @SweetPants about his preference for MQTT. It is a more robust solution.
Do you have a reason to believe domoticz crashed because of the http calls to a dead system ?
Below script checks a valid response to ping before it does anything else. Can you please check and revert ? Thanks
execute = function(dz)
local espEasyIP = '192.168.xxx.xxx' -- change this to IP of your espEasy
local backLight = dz.devices('Backlight Dashboard')
local backLightOn = backLight.state == 'On'
local backLightOff = not backLightOn
local screenStatus = dz.devices('Dashboard Screen Status')
local screenStatusOn = screenStatus.state == 'On'
local screenStatusOff = not screenStatusOn
local homePageTrigger = dz.devices('Dashboard Homepage Trigger')
local homePageTriggerOn = homePageTrigger.state == 'On'
local homePageTriggerOff = not homePageTriggerOn
local nightTime = dz.time.matchesRule('at 23:00-07:00')
local dayTime = not nightTime
local function sendToEasy(delay)
url = 'http://' .. espEasyIP .. '/control?cmd=gpio,13,'
dz.openURL(url .. '1').afterSec(delay)
dz.openURL(url .. '0').afterSec(delay + 1)
local function osCommand(cmd)
local fileHandle = assert(io.popen(cmd, 'r'))
local commandOutput = assert(fileHandle:read('*a'))
local returnTable = {fileHandle:close()}
dz.log('\nCommand: ' .. cmd ..
'\nReturnCode: ' .. returnTable[3] ..
'\ncommandOutput: ' .. commandOutput)
return commandOutput,returnTable[3] -- rc[3] contains returnCode
local commandOutput, returnCode = osCommand('sudo ping -c1 -w0 ' .. espEasyIP)
if returnCode ~= 0 then
dz.notify('espEasy check', 'ping failed', dz.PRIORITY_NORMAL)
elseif backLightOn and screenStatusOn and nightTime then
sendToEasy(150)
elseif backLightOff and screenStatusOn and nightTime then
screenStatus.switchOff().silent()
elseif backLightOn and screenStatusOff and nightTime then
sendToEasy(150)
elseif backLightOn and screenStatusOff and dayTime then
screenStatus.switchOn().silent()
elseif backLightOff and screenStatusOff and dayTime then
sendToEasy(0)
elseif backLightOff and screenStatusOn and dayTime then
elseif homePageTriggerOn and backLightOff and screenStatusOff then
sendToEasy(0)
elseif homePageTriggerOn then
homePageTrigger.switchOff().silent().afterSec(20)
Posted: Sunday 28 April 2019 12:33
by hoeby
I am for sure that domoticz crashed because calling a dead system.
When not crashed i saw in the log that it tried to send something to espeasy, but got a red row back.
This kept going on. When trying to switch a light at that moment, the icon on the domoticz dashboard went off, but the light itself kept on.
Then disabled the script and services restarted, everything worked OK.
Then let it run for 1 week without problems. Enabled the script and in a few hours the problem was back.
Thanks Waaren, i will look at the script.
But maybe it is better to go working with MQTT, only need to search for documentation how to setup.
Do you maybe have some hints?
Don't know where to start with MQTT and how to send the messages to espeasy from domoticz
Posted: Sunday 28 April 2019 12:56
by waaren
hoeby wrote: Sunday 28 April 2019 12:33
Need to search for MQTT documentation how to setup.
I am not an expert on MQTT but this information got me started
setup MQTT in domoticz and
MQTT in espEasy. There are also already a lot of forum members using this so when you need help for a specific question you can just ask here.
Posted: Sunday 28 April 2019 18:57
by SweetPants
Hmmm, if your ESP module(s) get offline this easy (several hours), maybe you also should look at your WiFi signals. Mine run for days/weeks without loosing connection to the Access Point. I'm not sure if ESPEasy supports a watchdog or something like that. Because i write my own software for the ESP, i have added a watchdog timer that restarts the ESP module when there is no traffic to/from the Access Point for more then 60 sec.
Posted: Sunday 28 April 2019 19:16
by hoeby
The wifi signal is not the problem. A dead power supply was the reason that my espeasy was offline.
But i wanted to find out if that was the reason why domoticz stopped working, when the espeasy is offline. So did a test while keeping the espeasy offline and see how domoticz respons when trying to switch the esp.
@sweetpants, do you have any idea where to look for information about mqtt and esp?
All information is welcome
Posted: Sunday 28 April 2019 19:31
by SweetPants
hoeby wrote: Sunday 28 April 2019 19:16
You might take a look at
https://github.com/arendst/Sonoff-Tasmota/wiki/Domoticz it supports out of the box domoticz MQTT. You need to install a MQTT broker and add MQTT hardware in domoticz
Posted: Sunday 28 April 2019 21:15
by hoeby
Got it working with MQTT.
But do i Always need to make a dummy device, to get the switch functional?
Or is it possible to send only codes?
From what i found i Always need a device, because i need to fill in an idx number
